Steering Boxes: VW vs. TRW; VW Teardown & Rebuild
Page: Previous  1, 2, 3 ... 19, 20, 21, 22  Next
OKType3Tim Premium Member
OKType3Tim is offline
PostPosted: Thu Feb 06, 2020 4:36 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Grego, and others:
Thanks for the kind words.
I've worked with Marcel @ VWNOS to find another batch of bearings. Fortunately, Marcel was able to located a small supply that he should have available soon. As with all things, they will be a bit more expensive than the batch I found 3+ years ago.
Also, Wolfsburg West has the gasket for the top cover. It might have been out of stock for a bit, but their web site shows it being available now.
Tim
'69 Squareback restoration
'69 Fastback restoration
'66 Type34
raygreenwood
raygreenwood is offline
PostPosted: Thu Feb 06, 2020 5:17 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
OKType3Tim wrote:
Grego, and others:
Tim
Tim...I will check but I think these are the same part number bearing for my type 4 box. Would it be possible to buy a set/pair when you get them in hand?
Ray
Grego in Sac
Grego in Sac is offline
PostPosted: Thu Feb 06, 2020 5:56 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Tim,
Do you think we could try using a timkin taper roller bearing instead of the ball bearing ones?
And are the two bearings the same?
PostPosted: Thu Feb 06, 2020 6:59 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Grego in Sac wrote:
Tim,
The bearing in this steering box only has one race. The opposing race is provided by the worm shaft. This is true for the bearings at both ends of the worm shaft. Thus, a taper roller bearing isn't going to have a race to bear against unless you machine the worm shaft to provide that race.
'66 Type34
PostPosted: Thu Feb 06, 2020 7:01 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Ray
Ray, Yes we visited about them being the same way back there 3 years ago. Sure, check with VWNOS to get a set.
Tim
'66 Type34
raygreenwood
PostPosted: Fri Feb 07, 2020 11:43 am    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
OKType3Tim wrote:
Ray
Tim
Perfect! Thanks!
Ray
Tvättbjörn
Tvättbjörn is offline
PostPosted: Wed Feb 12, 2020 10:48 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
What would be the cross reference part number for the bearings? Can not find any SKF or FAG numbers online. I am sure that they sold them "aftermarket" also and not only thru VW
vw 311 415 227 to SKF or FAG
Grego in Sac
PostPosted: Thu Feb 13, 2020 9:17 am    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
In the US, you will find just a few sets of original ones available. You can find some in Europe but depending on where you live postage can get expensive.
There is this ad
https://www.thesamba.com/vw/classifieds/detail.php?id=2323084
It’s in Australia but the postal fee is very reasonable
PostPosted: Thu Feb 13, 2020 4:41 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
For "late steering box"; part numbers are about half-way down on first page of this thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=660446&highlight=
There is this ad
I believe those are for the "early" steering box, different from the "late" steering box.
'66 Type34
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sat Feb 15, 2020 2:52 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
I received the bearings in industrial packaging. I'll repackage them as they sell.
They are available here: https://www.vwnos.com/508620b
If ya'll need anything else I can look at sourcing it.
www.vwnos.com
New NOS OEM Parts. Classic Brands. Classic Quality
Not all parts are made the same. We are a supplier of NOS OEM parts made mainly in West Germany, Early Germany, and Early Brazil. These locations are where VW early on produced the best quality parts and best fitting products.
Aluminum and Cast Iron Restored Distributors Available (<--Click here)
PostPosted: Wed Feb 26, 2020 3:58 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Since the kits are used up---The question has been posed several times of "what to do?", "where can I get ________?"
The following is a fairly complete list, provided that the bushings in your unit are still good:
Bearings:
Plugs:
https://www.vwnos.com/311-415-133
Gasket:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311415135A
Upper seal:
https://www.avxseals.com/Shaft-Oil-Seals-TC16x24x7-p/tc16x24x7.htm
Lower Seal:
https://www.avxseals.com/ProductDetails.asp?ProductCode=TC24x37x7
Worm Shaft:
https://socalautoparts.com/product/worm-drive-roller-style-for-steering-box/
Roller Shaft:
https://www.thesamba.com/vw/classifieds/detail.php?id=1967535
'66 Type34
Tvättbjörn
PostPosted: Fri Feb 28, 2020 8:33 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
I did contact the guys for the rollershaft, but shipping was like $80 which kills the deal. Based on that and the cost of all other parts it is maybe better just to buy a new TRW unit and recheck everything before it is being installed ?!?
sjbartnik
sjbartnik is offline
PostPosted: Sat Feb 29, 2020 7:30 am    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
And then what if something is not right? By opening the unit you will have voided any warranty. But you will have to open the unit to disassemble it, clean out the grease they use, then reassemble with proper shims and corn head grease.
Another option is it may be economical to buy the TRW unit just for the worm and roller, then scrap the rest and build the new box up in your old housing.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Tvättbjörn
PostPosted: Sat Feb 29, 2020 8:57 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
That is what I was talking about. Just for the roller and worm shaft. You can check first if the steering arm fits the splines before you take it apart. Just to be on the safe side.
I am at the point that I actually check and measure parts / open boxes and inspect items at the stores whenever possible, because quality and quality control has gone down across the board. Had factory sealed undamaged boxes with beat-up items in it which was not transport damage. The bad parts / tools / items were put in boxes at the factory. Appears too many people do not care anymore.
VWNOS.com
heimlich is offline
PostPosted: Sun Mar 01, 2020 4:12 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
If you buy them from me I can take them back if they have been opened. You will need to document why they are bad. You have to prove it came from the manufacturer like that. It's a case by case basis.
For example, the only issue I have seen is they sent out a bad steering spline once. This was a steering box Tim has purchased from me. He sent it back and I sent him out a new one.
www.vwnos.com
VWNOS.com
heimlich is offline
PostPosted: Sun Mar 01, 2020 4:15 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
If you need bushings let me know. I can have them copied but I will need a quality original to match up the metal. It should be a VW one. I did this for Bosch distributors.
www.vwnos.com
EVfun
EVfun is offline
PostPosted: Sat Mar 14, 2020 8:08 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
This is THE thread on theSamba for steering boxes. Any more current info about the non TRW replacement boxes?
I'm also interested in what diagnostic testing I can do on assembled boxes. What I can measure? For example, I suspect where the tightest spot in the adjustment is located is a hint about wear in the worm shaft bearings that is being taken up by adjustment. There has been discussion about how the height of the adjuster screw shows how much roller adjuster range is left. What else can be figured out while assembled?
Wildthings wrote:
duncan1958
duncan1958 is offline
PostPosted: Sun Mar 15, 2020 4:15 am    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
The only real way to to clean and strip down and inspect and measure for wear on the various parts and bearings,
Read through all the pages here there is a wealth of information on how and where to look for wear.
EVfun
EVfun is offline
PostPosted: Sun Mar 15, 2020 4:38 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Before I start tearing into a box I would rather plunk money down for a new or rebuild box. If I go that route I may go with an older work and sector box. It's going in a buggy that will see a couple thousand miles a year.
I'm holding a reproduction box that doesn't say TRW on it and while it feels smooth when turning the rag joint it doesn't feel as smooth when pushing the arm back, notchy feeling especially returning a full right turn (more so than from full left.) I've been looking for info about this boxes, but only a little here or in other threads and not much recent.
I have an older worm and roller box, the kind with the pipe plug on top designed for oil. I will adjust it before rating it but the roller is turning when I turn the rag joint. The strait STP I filled it with a couple years ago seems to have greatly slowed leakage. A little has escaped out the bottom but it's still mostly covering the roller and is nicely drug over and around it when I turn the rag joint.
I am hoping the experience here, this thread in particular, could offer some info about what problems feel like.
Wildthings wrote:
koiboy
koiboy is offline
PostPosted: Sun Apr 19, 2020 2:25 pm    Post subject: Re: Steering Boxes: VW vs. TRW; VW Teardown & Rebuild Reply with quote
Hi,
First of all thanks for the great thread its been really useful during the tear down of my steering box.
I have now completely dis assembled my steering box.
The issue I have is there was no shim on the worm gear.
It is an original vw steering box and still had genuine vw oil seals fitted. Prior to the rebuild the steering box felt smooth. I decided for a rebuild as I am doing a full restoration of my 1970 beetle.
What are the diementions of the shims. I saw earlier in thethere are varying widths but no mention of od or Id.
I guess I am going to have to buy the varying width of shims to work out which I need to take any play out?
Also what length of grub screws do you uses to replace the plastic plugs?
Any tips would be much appreciated
Elliot
Page 20 of 22
