Engine cuts out under load
metoooo
metoooo is offline
PostPosted: Fri Dec 25, 2020 6:03 am    Post subject: Engine cuts out under load Reply with quote
Hi. My 1600cc twin carb engines starts recentelly to cut-off under load at high gears. When i rev it up in standing, it works perfect. I've replaced spark plugs and adjust the ignition, carbs and valves, but the problem stays. Any sujestions how to solve this issue? Could bad fuel pump cuase this issue?
gt1953
gt1953 is offline
PostPosted: Fri Dec 25, 2020 6:44 am    Post subject: Re: Engine cuts out under load Reply with quote
Try replacing the condenser. I also had an issue like that, swapped out the whole distributor with spare one. Then one component at a time. It was the condenser .
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 68, 69 type ones 68 & 69 type two, 68 Ghia all sold})
metoooo
metoooo is offline
PostPosted: Fri Dec 25, 2020 8:10 am    Post subject: Re: Engine cuts out under load Reply with quote
The condencser only have 2,000 km on it, but i'll replace it anyway. Hope it solve the problem. Thanks
vwfye
vwfye is offline
PostPosted: Fri Dec 25, 2020 9:18 am    Post subject: Re: Engine cuts out under load Reply with quote
Condensor not condensing...
64 No'back Speedster
65 Sunroof Notchback
Little Giant Killer III
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Dec 25, 2020 12:43 pm    Post subject: Re: Engine cuts out under load Reply with quote
Plugged up fuel sock in the gas tank.
All the crud will settle around the fuel sock.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
gt1953
gt1953 is offline
PostPosted: Fri Dec 25, 2020 2:10 pm    Post subject: Re: Engine cuts out under load Reply with quote
Yup clogged fuel filter would cause it to run out of fuel under load.
72 type 1
73 type 1
72 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Sat Dec 26, 2020 12:59 pm    Post subject: Re: Engine cuts out under load Reply with quote
A coil going bad will do this too. Especially under load. I've had that happen to me back in 2004 right be going to the Invasion. Took me a couple of days to find it (went thru every system on the engine), because the engine would idle perfectly, but under load would run like crap. In my case it was a German blue coil trying to die (the last thing I checked). Swapped it with a German black coil, and everything was fine again.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Hokie87
Hokie87 is offline
PostPosted: Tue Jan 12, 2021 7:28 am    Post subject: Re: Engine cuts out under load Reply with quote
I had the same problem. After reading this thread, I put in a new condenser and it's fixed.
QRP
QRP is offline
PostPosted: Tue Jan 12, 2021 9:36 am    Post subject: Re: Engine cuts out under load Reply with quote
Also check fuel tank vent, could be clogged.
Easy to check, just drive it with the gas cap off.
metoooo
metoooo is offline
PostPosted: Tue Jan 12, 2021 9:51 am    Post subject: Re: Engine cuts out under load Reply with quote
It was the condenser... problem solved
vwfye
vwfye is offline
PostPosted: Tue Jan 12, 2021 10:12 am    Post subject: Re: Engine cuts out under load Reply with quote
It used to be that condensors either worked, or did not. These days partially failed condensors seem to be the new norm.
