oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Mon Aug 01, 2016 6:25 pm Post subject: welding - I did something wrong |
I was welding some holes up in my single cab today, they turned out fair but the real problem came afterwards. I went to start it and the gauges come to life but when I turn the key to the start position nothing happens. I have 12v at the battery and coil......any thoughts? All fuses look good too. Ugh!! _________________ 73 914 2.0 - sold
63 single cab
73, 73 and 74 Thing - gone
64 notch - gone
60 23 window - gone
57 oval - gone
plus a few others I should have kept |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Aug 01, 2016 6:32 pm Post subject: Re: welding - I did something wrong |
was the battery disconnected during welding? _________________ 1957 Beetle
1966 Bus |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Mon Aug 01, 2016 7:06 pm Post subject: Re: welding - I did something wrong |
Yes, you probably fried the ecu. _________________ modok wrote:
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Mon Aug 01, 2016 7:25 pm Post subject: Re: welding - I did something wrong |
There are lots of EC........U in the classifieds, no worries _________________ .ssS! |
jason Samba Member
Posted: Mon Aug 01, 2016 8:13 pm Post subject: Re: welding - I did something wrong |
You hook it back up correct? Does nothing include cranking over? |
Posted: Mon Aug 01, 2016 9:15 pm Post subject: Re: welding - I did something wrong |
Silly me did not disconnect the battery. I went underneath it tonite and jump started the starter with a screw driver....it turned over. I went in and the car turned over with the key. I tried it again and nothing. Went under again and did the screw driver trick again, the Bendix spun but not the starter. I went in the cab and it started with the key, did that about 5 times and all was well. Maybe the starter going bad? Did I do something to the Bendix May have to get a new starter?? Thanks for the replies. _________________ 73 914 2.0 - sold
63 single cab
64 notch - gone
60 23 window - gone
57 oval - gone
BarryL Samba Member
Joined: November 01, 2004 Posts: 14259 Location: Casa de Oro, California
Posted: Tue Aug 02, 2016 9:57 am Post subject: Re: welding - I did something wrong |
oldthingguy wrote: |
Did I do something to the Bendix |
When you turn the key to start it begins a chain reaction and doesn't actually send full juice through the ignition to turn the start armature. The start solenoid has a fine winding of copper wire that creates a magnetic field strong enough to pull a metal cylinder that is connected to the Bendix. When the Bendix is fully pulled in it makes contact with the big battery wire and that sends full current to the armature through a metal contact.
When you weld there are super strong jolts of stray current sent through the metal of your bus and theoretically it returns to the ground you clipped on from your welder. If you didn't disconnect your busses battery ground then some of the jolts can find their way around through places that shouldn't get jolted. It's possible that a little tit formed on the solenoid contact that created a tiny insulation point that you corrected by operating it over and over. Worst case is there is a break in the fine winding. Time will tell.
Or it might be something as simple as a Gremlin that went back into hiding. |
kintail Samba Member
Posted: Tue Aug 02, 2016 2:58 pm Post subject: Re: welding - I did something wrong |
Did you weld in an area that the wiring harness is in and burn the wires? Seen it done...... _________________ Scott |
Posted: Tue Aug 02, 2016 7:53 pm Post subject: Re: welding - I did something wrong |
BarryL - thank you for the explanation and hopefully it was a simple item like you described. Today it started just fine, I'll keep my fingers crossed. Eventually I will replace the starter as I know nothing of it's history and none came from the previous owner.
BTW - some have asked about wires, I was welding some holes in the top portion of the bed floor.
Thanks for all your replies....... _________________ 73 914 2.0 - sold
63 single cab
64 notch - gone
60 23 window - gone
57 oval - gone
