k9hdlr Samba Member
Posted: Tue Apr 04, 2017 2:11 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
Robert Chambers wrote: |
Sqmalt46 what I should have said is the case with the cylinders and heads installed is wider than the 40 horse. That is why the 1300/1500/1600 tins are wider. With a 69 mm crank the cylinders are longer. That is why the engine is wider. Therefore the 1300 intake is wider than the 40 hose intake. That was my intent. By the way when I said block, I meant the long block. That means the case with the cylinders and heads installed. And I do know what I am talking about. I am a former VW of America Unit Shop Mechanic. |
I read somewhere that the top headbolts needed to be longer to properly fit the 1300 head on my 1200 40hp. Is that right? Or no? Be nice if it just fits. |
k9hdlr Samba Member
Posted: Sun Apr 02, 2017 12:35 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
Mr. Motorhead wrote: |
earthquake wrote: |
I think you can do it, if it was me I would try to find a set of DP 1300 heads, they were used on European motors.
Casey |
Just in case anyone is interested, I have a pair of freshly built 1300 DP heads that don't have a home. PM me for a price if you want them. |
Do you still have the DP1300 heads? |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Wed Aug 10, 2016 12:08 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
earthquake wrote: |
Casey |
Just in case anyone is interested, I have a pair of freshly built 1300 DP heads that don't have a home. PM me for a price if you want them. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Thu Aug 04, 2016 11:07 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
johnr156 wrote: |
Does the angle of the intake port on the head come into play? I'm not certain when VW started putting the 20 degree angle on the heads. |
Yes, 1966 1300 type 1 was the first type 1 angled. I think 1963 type 3 started the angled intake. Not sure about type 2. I think 1963 1500 type 2 was angled? That was the early 1500 engine similar to the 1967 type 1 if I remember correctly. |
'63 Type 3s are angled, '62s are not.
'63 1500cc Bus is angled. _________________ How to Post Photos
Robert Chambers Samba Member
Posted: Thu Aug 04, 2016 5:29 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
johnr156 wrote: |
Yes, 1966 1300 type 1 was the first type 1 angled. I think 1963 type 3 started the angled intake. Not sure about type 2. I think 1963 1500 type 2 was angled? That was the early 1500 engine similar to the 1967 type 1 if I remember correctly. _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
johnr156 Samba Member
Joined: April 06, 2013 Posts: 144 Location: Dixon, Ca.
Posted: Thu Aug 04, 2016 4:20 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Thu Aug 04, 2016 2:55 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
gotcha that makes sense _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Thu Aug 04, 2016 1:52 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
Sqmalt46 what I should have said is the case with the cylinders and heads installed is wider than the 40 horse. That is why the 1300/1500/1600 tins are wider. With a 69 mm crank the cylinders are longer. That is why the engine is wider. Therefore the 1300 intake is wider than the 40 hose intake. That was my intent. By the way when I said block, I meant the long block. That means the case with the cylinders and heads installed. And I do know what I am talking about. I am a former VW of America Unit Shop Mechanic. _________________ '63 OG 117 Herbie Replica
'63 OG 117 |
Posted: Thu Aug 04, 2016 12:52 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
the 40hp case and the 1300 case are the same size i dont know what the other guy is talking about. the motor is wider not the case.and i hate when they call a engine case a block! yes the 1300 heads and manifold will go right on. its a good upgrade. just need the 1300/1500/1600 cylinder tin.which makes the motor a little wider.has nothing to do witk the crank inside _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
Posted: Wed Aug 03, 2016 4:12 pm Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
The 1300 block is wider than the 40 block. Also the stroke is longer 69 mm verses 64 mm. So the 1300 intake manifold has to be wider than the 40 intake manifold. I guess you can do it by modifying the 1300 manifold? _________________ '63 OG 117 Herbie Replica
'63 OG 117 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Aug 03, 2016 11:36 am Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine |
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Pirulero1986 Samba Member
Posted: Wed Aug 03, 2016 1:01 am Post subject: 1300 heads and 1300 manifold on 1200 40 hp engine |
it's possible to use a sinlge port 1300 manifold on a 1200 40 hp engine with 1300 sp heads?
i want to know because 1300 manifold have a bigger diameter than the 1200 and the openings of the heads are different
thanks
michele |
