tzepesh Samba Member
Posted: Mon Aug 08, 2016 12:07 am Post subject: How to remove Dellorto Jet Doctors lead balls |
Hello,
This might be stupid question, but how can I remove the lead balls from the small air pipes that I had to plug with lead balls, without messing the air pipes diameters?
I want to remove the Jet doctors as I can not tune the carbs right after installing them. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
Bruce Samba Member
Posted: Mon Aug 08, 2016 12:02 pm Post subject: Re: How to remove Dellorto Jet Doctors lead balls |
A tiny drill in your dremel will do the job. _________________
Posted: Tue Aug 09, 2016 11:34 pm Post subject: Re: How to remove Dellorto Jet Doctors lead balls |
I have 1mm, 1.5mm and 2mm drills. I'll start with the smallest one.
I did not find anywhere a very small tap. That way I would have tapped the 1mm or 1.5mm hole and create a small press with a screw... Maybe I will find small wood screws that would lock in the lead and use them to pull the plugs. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
Bruce Samba Member
Posted: Wed Aug 10, 2016 3:32 pm Post subject: Re: How to remove Dellorto Jet Doctors lead balls |
Strip the carb down and use a small torch to melt the lead. _________________
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Aug 10, 2016 9:46 pm Post subject: Re: How to remove Dellorto Jet Doctors lead balls |
Bruce wrote: |
Strip the carb down and use a small torch to melt the lead. |
too close to the lead plugs that cause the "dellorto drip" in my opinion. Get the carb too hot for a second, loosen those by accident, and then you've made an awful mess of things..
They're not hard to get out, I've done it. once you get through it with a small bit you can pretty much pick the ball out with a dental pick. _________________ modok wrote:
Posted: Mon Aug 15, 2016 10:51 am Post subject: Re: How to remove Dellorto Jet Doctors lead balls |
I managed to remove all lead balls. I used a 1mm drill then a 1.5mm drill and then a dental pick. I also changed the jets and now it runs sooo smooth with smaller jets. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
