Brendel20 Samba Member
Joined: October 21, 2010 Posts: 300 Location: Troy, IL
Posted: Sat Aug 06, 2016 8:27 am Post subject: Brendel20's 1954 Beetle Build |
I picked up this really cool little oval back in April from a great guy who had it stored away for about 30 years. It was given to him by a neighboring farmer who drove it around his property. After three months of waiting, the birth certificate arrived from the Stiftung Auto Museum indicating it left the factory on September 24, 1954 and was delivered to the Rossel Volkswagen dealer in Wiesbaden, Germany. The car was originally Iceland Green L213.
While the car has rust and is (was) missing a few of the 54-55 specific parts, the price was right and I was ready for a new project.
I'll let the pictures do most of the talking but this project required removing the body to really tackle things correctly. I also had to source (which has been a fun challenge) a few items to make it correct: drivers fender, hood, engine lid, seats , and the heart taillights. After some wanted adds, I've pretty much found everything needed. I was able to find a 55 parts car that had the front seat frames, hood, and drivers fender I needed. The rest got parted out.
Here is the lid and rear seat I was able to find:
The car came apart pretty easily, only broke off one bolt. The pan and body are matching, however the 36hp is a later 1960 case. More on that later.....
The interior had some creative coverings and platforms inside. The engine did not want to come off the trans housing, so I had to leave it together until the body was off. Wait till you see what was hiding inside. Here are some pics:
Got the tunnel cleaned up somewhat and built a rotisserie.
While my plan is to sort out the chassis first, I decided to have the body, fenders, etc blasted and primed early on so I knew exactly what metal I'd need to start slowly start sourcing.
The tunnel is pretty solid other than some rust areas near the head. That's where I'm at currently, cutting out some rust spots and welding in donor metal. Then onto the pans. I'll add pictures of this once I'm made some progress.
While I've done work on a couple busses, this is my first attempt at a beetle. So installing pans, heater channels, etc. will all be new territory.
Any advice or suggestions are welcome. |
René R. Samba Member
Joined: July 06, 2015 Posts: 1712 Location: No. Calif.
Posted: Sat Aug 06, 2016 10:47 am Post subject: Re: Brendel20's 1954 Beetle Build |
I am looking forward to following this build! Do you plan a stock restoration or modified? _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Sat Aug 06, 2016 3:46 pm Post subject: Re: Brendel20's 1954 Beetle Build |
100% stock. 36 hp (already found a 54 case), 6 volt, non-synchro trans, correct 54 everything.... |
sled Samba Member
Posted: Sun Aug 07, 2016 9:15 am Post subject: Re: Brendel20's 1954 Beetle Build |
a 54 would have a synchro transaxle would it not? _________________ drive your split. |
Posted: Sun Aug 07, 2016 9:43 am Post subject: Re: Brendel20's 1954 Beetle Build |
1st is not syncro |
sled Samba Member
Posted: Sun Aug 07, 2016 9:58 am Post subject: Re: Brendel20's 1954 Beetle Build |
correct. generally non-syncro refers to a full crash trans of split beetles. 54 is the same trans from 53-59ish right? interesting that the second gear also had no syncros in standard model bugs of '54. _________________ drive your split. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Aug 07, 2016 5:44 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Someone correct me if I'm wrong
Deluxe 54's have no synchro 1st, synchro 2-4
Standard 54's are full crashbox-no synchros |
sled Samba Member
Posted: Mon Aug 08, 2016 7:20 am Post subject: Re: Brendel20's 1954 Beetle Build |
Ive never owned an all originnal standard 54..just read the owners manual that says it has syncro 3 & 4 _________________ drive your split. |
Bruce Samba Member
Posted: Mon Aug 08, 2016 11:36 am Post subject: Re: Brendel20's 1954 Beetle Build |
sled wrote: |
...just read the owners manual that says it has syncro 3 & 4 |
Can you post a scan of that?
The 52-57 original VW repair manual only shows two gearboxes. The full crash box and the synchro 2-3-4. _________________
aa390392 Samba Member
Posted: Mon Aug 08, 2016 2:20 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Looks as if your doing it proud keep us posted with anything new.
Thomas _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
txoval Samba Member
Posted: Mon Aug 08, 2016 4:10 pm Post subject: Re: Brendel20's 1954 Beetle Build |
I was reading the repair manual as well, but I believe the Owners manuals posted on this site under Technical, state the same
Bruce wrote: |
sled wrote: |
The 52-57 original VW repair manual only shows two gearboxes. The full crash box and the synchro 2-3-4. |
Bruce Samba Member
Posted: Mon Aug 08, 2016 6:01 pm Post subject: Re: Brendel20's 1954 Beetle Build |
I know what the confusion is!
When they say "silent", they don't mean the gear change is silent. It means the gears are silent when driving. IOW, the silent gears are helical cut. Engaging them is still noisy. 1st gear in the Deluxe's gearbox is straight cut. 1st and 2nd in the full crashbox are straight cut. _________________
Posted: Sun Aug 21, 2016 12:53 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Rust repair continues on the frame head. Should be good for another 60 years I hope.
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sun Aug 21, 2016 11:19 pm Post subject: Re: Brendel20's 1954 Beetle Build |
This is gonna be good. I'll be watching!
And envious because you seem super handy.
Congrats on the car and finding the parts you need! _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Mon Aug 22, 2016 7:36 pm Post subject: Re: Brendel20's 1954 Beetle Build |
TheLadyBug wrote: |
Congrats on the car and finding the parts you need! |
Handy Andy indeed. He came over a couple of weeks ago and helped me install safari windows in my 65 bus. Nice clean welds. Hard core VW enthusiast and super nice person. |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Tue Aug 23, 2016 5:45 am Post subject: Re: Brendel20's 1954 Beetle Build |
Nice job on the frame head. _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
Posted: Tue Aug 23, 2016 6:12 pm Post subject: Re: Brendel20's 1954 Beetle Build |
caleb0101, TheLadyBug, René R, Mike (3foldfolly).... I appreciate the well wishes. I'll try and keep the thread rolling. It definitely motivates me when I know people are following!!! |
Posted: Tue Aug 23, 2016 6:42 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Just got my case back from the machine shop. Thank you Hazetguy for a great deal on a case for this build.
Line bored and ready to start building. I need lots of engine parts... Pretty much everything :/
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Aug 24, 2016 6:19 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Glad it finally made it to your house! |
Posted: Mon Sep 26, 2016 10:09 am Post subject: Re: Brendel20's 1954 Beetle Build |
Finally finished up the frame head and sealed it. Now I'm onto fitting the pans in. These are from wolfsburg west and fit almost perfectly.
