jtrashy Samba Member
Joined: November 27, 2005 Posts: 129 Location: SF, CA
Posted: Sat Aug 06, 2016 3:14 pm Post subject: Anyone have the new Gowesty LED headlights? |
How do you like them?
please post a pic of the beam pattern at night.
Thanks |
drj434343 Samba Member
Joined: January 31, 2016 Posts: 401 Location: Portland, OR
Posted: Sat Aug 06, 2016 5:51 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
FYI, I noticed that they look almost exactly like the Truck-Lite 27270C.
https://www.amazon.com/Truck-Lite-27270C-Headlamp/dp/B007K8AA7I
If they are, I have a pair on my Vanagon and another on a motorcycle. Light pattern, brightness, and color are excellent. The Truck-Lites have been around for a while and are considered some of the best LED headlights for the money. I highly recommend them. |
artacoma Samba Member
Joined: January 11, 2014 Posts: 121 Location: Victoria BC Canada
Posted: Sat Aug 06, 2016 6:33 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Mine should be delivered on monday I'll report back _________________ Cheers
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sun Aug 07, 2016 9:54 am Post subject: Re: Anyone have the new Gowesty LED headlights? |
This is an exact copy the Truck-Lite 27270C, just priced $66.00 higher than the real deal on amazon. I have heard that Truck-Lite resells their lights to other companies, but they wouldn't confirm that when I emailed them.
There are quite a few knock-offs of the JW Speaker 8700 Evolution 2 headlamp that will outperform these at a lower price. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Sun Aug 07, 2016 12:24 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
No brackets and mods are needed for the TruckLite right? I have a square TruckLite on my BMW motorcycle - good looking and very good light. _________________ Learn to ride. Ride to learn. |
Posted: Sun Aug 07, 2016 1:57 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Truck-Lite and most other 7" round LED headlights are plug and play for 80-85 vans and South African Grill. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
zandr Samba Member
Joined: April 07, 2014 Posts: 28 Location: Berkeley, CA
Posted: Sun Aug 07, 2016 8:06 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
On a related note, has anyone found a good LED solution for the inner/high beams on the SA grill? _________________ '87 EJ22 Full Westy "Hamish" |
Posted: Mon Aug 08, 2016 8:47 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Heres before and after , I won't have a chance to do any aiming or night pics till the weekend, the build quality seems to be there with the bulbs and the GW buckets , took about 2 hrs to swap the whole works
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Mon Aug 08, 2016 9:02 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Artacoma,
That really looks good. I am so tired of my dim squares, even with relays and high watt bulbs.
I'm hoping someone in the Denver area gives them a try, posts here, and then lets me bother them some evening.
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Skidub Samba Member
Posted: Tue Aug 09, 2016 9:02 am Post subject: Re: Anyone have the new Gowesty LED headlights? |
These LEDs look great. I understand that they are plug and play if you've upgraded to SA set up, which I have with Jay's in-line wiring harness, but are these LEDs also okay to run if you have high powered headlight relays too? No need to "un-wire" the relays? _________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler |
Altoona Samba Member
Posted: Tue Aug 09, 2016 9:04 am Post subject: Re: Anyone have the new Gowesty LED headlights? |
Skidub wrote: |
These LEDs look great. I understand that they are plug and play if you've upgraded to SA set up, which I have with Jay's in-line wiring harness, but are these LEDs also okay to run if you have high powered headlight relays too? No need to "un-wire" the relays? |
No need to remove the relays. |
WestyKlaus Samba Member
Posted: Tue Aug 09, 2016 1:14 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
thatvwbusguy wrote: |
There are quite a few knock-offs of the JW Speaker 8700 Evolution 2 headlamp that will outperform these at a lower price. |
Jay, Can you point to any knock-offs of the JW Speaker 8700 Evo2 that you speak of?
Thanks! |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Tue Aug 09, 2016 10:23 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
zandr wrote: |
On a related note, has anyone found a good LED solution for the inner/high beams on the SA grill? |
X2 - Any good 5.5" LED lights available for SA high beams ? _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
Posted: Wed Aug 10, 2016 3:25 am Post subject: Re: Anyone have the new Gowesty LED headlights? |
No idea, my DIY SA Grill doesn't use 5.25" inners. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Posted: Tue Aug 16, 2016 3:45 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
artacoma wrote: |
looks good, how about those night pics |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Tue Aug 16, 2016 4:00 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
A guy from gowesty did say that they do not build these lights in house and that they are in fact just being resold. I'd say that the trucklites are most likely the ones they are re-selling. Amazon is the obvious better deal for the same product. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Aug 16, 2016 7:47 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Hey guys check out this LED with DRL.
I've got them on my 86 and very happy with them for around town in traffic and freeway driving. I have them on the S.A. grill.
I'm not wildly enthusiastic about it's high beam, but I have the S.A. High beam and together it is really good providing light to see the road in front of you with oncoming superbright projection beams.
https://www.amazon.com/dp/B01DLLAJOQ?psc=1
There are more then one DRL 7" brand on there, I bought by highest output rating. |
Mike760 Samba Member
Joined: November 19, 2015 Posts: 43 Location: Oceanside, CA
Posted: Tue Aug 16, 2016 8:56 pm Post subject: Re: Anyone have the new Gowesty LED headlights? |
Those look great Steve.
Anything additional needed for the DRL or is that an always on on the light? _________________ 1984 Westfalia |
eplater Samba Member
Posted: Wed Aug 17, 2016 4:15 am Post subject: Re: Anyone have the new Gowesty LED headlights? |
ThankYouJerry wrote: |
zandr wrote: |
X2 - Any good 5.5" LED lights available for SA high beams ? |
I went with 4 - JW Speaker for inners and outers. The inners are P/N 8360 and slight mods (they're 5 3/4") to the buckets need to be made but nothing to serious. Outers are the 8700 Rev 2. Kept everything on relays, modified the pigtails - works great and as others have mentioned, vastly improved over the squares!
[/img] _________________ '90 Syncro Westy EJ22 w/ decoupler & rear locker
'12 Touareg TDI
'08 RS4 Cabriolet |
