davidmelton Samba Member
Posted: Sun Aug 07, 2016 12:25 pm Post subject: Restoration: 1960 Single Cab |
We just purchased a 1960 Single Cab ("Henry"). We found it near Los Angeles, CA and trailered it home to Folsom, CA. This is 3 generation project: grandfather, father, & daughter. We have enjoyed reading all of the Single Cab and bus posts on The Samba for the last few years.
I grew up learning how to drive on my parents 1971 yellow Bay Window bus. My first car was a 1968 Squareback. We recently restored a 1978 SuperBeetle Convertible. This is our first split window and our most ambitious project.
Henry was pretty clean when we picked him up. It looks like it went through a restoration a few years back and then the process was started again in the last few years. I don't have a lot of information on its history. It was painted with the primer when we picked it up.
Some areas of bondo have cracked.
The interior is clean. It has an after market steering wheel.
And a replacement turn signal switch.
From the M-Plate the exterior color was "Sealing Wax Red." Was the interior also painted the same color to match? The interior now seems to be a shade of white or ivory.
The wiring is a bit messy. It looks like an after market fuse box was used to bypass the old one.
Some repairs were made to the interior floor sheet metal using fiberglass.
The bed sheet metal needs to be replaced along with a few of the rusted cross-members. Overall, the gates are in nice shape. I need to figure out how to replace the "pin" type fastener. I'm not sure what this looks like. All of the hinges now have bolts or screws. One even has an Allen Wrench holding it together.
We think it has a replacement 1600cc motor. It was running when we picked it up, but we haven't had time to start it at home.
Look forward to your comments and good advice to help move this project forward! |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Aug 07, 2016 12:43 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
I've had our '60 sc since 1995... paid $350... has been completely redone mechanically... our son in the picture is now 24. He grew up with this sc too... set it up in his trust... he'll have it for a lifetime.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 902 Location: Las Vegas, NV
Posted: Sun Aug 07, 2016 5:59 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Congratulations on the new project. Your truck should be sealing wax red inside and out. The pin for the rear truck gates is called a roll pin.
You have your work cut out for you, but they are great trucks.
Here is picture of Kurt's gorgeous 1959 single cab in sealing wax red. This truck should be your inspiration if you want to restore yours back to stock.
_________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Sun Aug 07, 2016 8:53 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Congratulations, looks like a great place to start. I restored a car with my daughter, what great memories.
I decided to leave ours patina'd, so much easier to keep clean.
_________________ 73 914 2.0 - sold
63 single cab
73, 73 and 74 Thing - gone
64 notch - gone
60 23 window - gone
57 oval - gone
plus a few others I should have kept |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Tue Aug 09, 2016 6:57 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Thank you for the responses.
oldthingguy the Single Cab looks great next too Poor Red's! Both are classic! I love the front bumper.
ZENVWDRIVER that's a lot of wood! We have some relatives that live in Muskogee.
ronjonlasvegas thanks for the help with the roll pin. Wow, Kurt's 1959 looks awesome!
EverettB thanks for the tip on the inside paint. And for running this fantastic Samba website!
David |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Aug 10, 2016 5:47 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Looks like a great project. When it was originally painted SWR it would be inside the cab and outside. Grey in the tool bay and underside. _________________ In Stereo, Where Available! |
Posted: Sat Aug 13, 2016 5:19 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We decided to start off with an easy project. We removed the old and damaged door panels.
There is nothing to stop the door from opening to wide or closing too easily. I'm guessing we are missing some parts?
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sat Aug 13, 2016 5:27 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Congratulations on the single cab! It looks like a nice truck. I really like seeing family projects like this, my dad got me into working on vw's when i was 13 (i'm 40 now).
I have a 60' panel bus originally sealing wax red like your truck. My front cab doors are the same way. As far as i know that is how they are. Lots of knowledgeable folks here so i'm sure others will chime in on that.
Keep up the good work and making lifetime memories! |
Posted: Sat Aug 13, 2016 5:29 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Nope, nothing missing, that is how the doors are until 1964.
1964 models got a check strap to stop the door from opening too far and keep it open at the same time. _________________ How to Post Photos
davidmelton wrote: |
There is nothing to stop the door from opening to wide or closing too easily. I'm guessing we are missing some parts? |
No parts missing, that came in 1964... _________________ In Stereo, Where Available! |
Posted: Sun Aug 14, 2016 4:11 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We bought a replacement reproduction steering wheel. It is black in color and made by Flat 4. Purchased it from CB Performance along with a black horn button with the Wolfsburg logo. The old aftermarket steering wheel was more difficult to remove than I had expected.
After we removed the old steering wheel and mounting bracket there was a long bolt/nut that is welded to the steering shaft. I tried to break the weld by using a chisel and drill with small bit.
Then I finally noticed welds on both sides (on the body) of the long bolt/nut. This isn't coming off without a struggle. It may be easier to replace the steering shaft or replace all of it with a rebuilt steering box. Disappointing.
Posted: Sun Aug 14, 2016 4:24 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Would try a Dremil to carefully remove that adapter in pieces off the original steering shaft. Finding good or even rebuildable steering boxes is getting hard, so do try not to FUBAR the one you have up. _________________ In Stereo, Where Available! |
Posted: Tue Aug 16, 2016 6:34 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Thanks to the helpful advice from Eric&Barb, my dad used a cutting tool and was able to remove the aftermarket steering adapter. We might have to finesse the threads a bit. But, all in all, happy with the result. Fortunately, my dad has a steady hand and is full of guile!
Posted: Tue Aug 16, 2016 6:48 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Looks much better! If you can find a thread file for that size or at least a good triangle file to work those threads back into shape. _________________ In Stereo, Where Available! |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Wed Aug 17, 2016 6:02 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
I remember seeing your ad on C.L. a while back, looking for a family project. Cool to see things finally come to fruition! There are a lot of us (Type II kids et al) in the Sacto area, if you need to pick someone's brain or come out to local gatherings. Get Henry back on the road! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
lightice Samba Member
Posted: Wed Aug 17, 2016 7:01 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
2 thumbs up on the effort and its great to see a family getting in on the project. |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Wed Aug 17, 2016 9:10 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
Does the stamped VIN near the battery match the one on the two tags you show? It is weird that there is no sign in the cab of the Original SWR. Also odd that the m-code plate is bare metal but not the screws. And where is the build plate mounted? The condition of it doesn't match what it is mounted to. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
oakman Samba Member
Posted: Fri Aug 19, 2016 1:08 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
cru62 wrote: |
Does the stamped VIN near the battery match the one on the two tags you show? It is weird that there is no sign in the cab of the Original SWR. Also odd that the m-code plate is bare metal but not the screws. And where is the build plate mounted? The condition of it doesn't match what it is mounted to. |
SWR here on the inside of the nose?
cru62 Samba Member
Posted: Fri Aug 19, 2016 2:22 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Could be. And it kind of looks like the repainted maybe chipped off on the defroster pipe-
Is this really where a SC M-code plate is usually mounted?-
