cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Mon Jul 23, 2018 9:01 pm Post subject: Re: Restoration: 1960 Single Cab |
davidmelton wrote: |
We did figure out that the butterfly valve on the choke was sticking. We took it off and cleaned and polished the edges. Now it doesn’t stick.
And of course I stripped the head on one of the screws. Fortunately it drilled out nicely. And replaced both screws. |
Those screws must be peened and/or loctite-ed. You do not want them to fall out and go through your engine at speed.
Also, whatever combo of wire and hose that is on the left side of the carb, get rid of it and install a proper vacuum plug. Just like the black one sticking out the rear of the carb.
Remember Front is Front. _________________ nothing |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 24, 2018 6:47 am Post subject: Re: Restoration: 1960 Single Cab |
You will need the tube thru the fan shroud and the front tin. Can use the early one you had in there without the spring and its collar, or use the later design. Supposed to be a rubber grommet in the front tin to grip the throttle tube from getting cut on the front tin edge, and grip the tube to keep it from sliding backward to jamb the carb linkage. Can use a fender washer and small hose clamp instead of the grommet on the tube in front of the fan shroud to keep the tube from sliding rearward. _________________ In Stereo, Where Available! |
davidmelton Samba Member
Posted: Tue Jul 31, 2018 1:15 pm Post subject: Re: Restoration: 1960 Single Cab |
We took the advice of cdennisg and loctited the butterfly valve screws.
Also replaced the funky looking plastic tube with the pop-rivet with the appropriate plug. Funny, it was on the original carb that came with the SC.
While working on the butteryfly valve, I took the carburetor off, but kept the fuel hose connected. Essentially, the carb went on its side. Put it back together and on the test drive, the motor kept coming to a sputtering halt. It was like we were out of gas.
We pulled the carb back off and there was some junk in the bottom of the bowl. We think turning it sideways clogged one of the jets. We took everything apart and cleaned the carb and jets. Replaced the fuel filter which also had some junk inside. Put everything back together and it runs great. We have all new fuel lines and what I thought was a new tank. I may need to pull the tank out and make sure it is clean.
Adjusted the back drum brakes.
We are going to take Eric&Barb’s advice and install the accelerator cable tube through the shroud. However, this may be easier to do with the engine out of the SC. We will put it on the “to do” list.
Posted: Mon Aug 06, 2018 12:48 pm Post subject: Re: Restoration: 1960 Single Cab |
I was enjoying a Sunday morning drive until I wasn’t. Henry had been running great. Cool wind (no CA Forrest fire smoke) running through my hair (or what is left). About a mile from my home, the SC stalled and would not restart. Thanks to the kindness of strangers, we pushed it into a nearby by park parking lot.
Everything seemed okay in the engine compartment. I took off the air cleaner, but all else looked fine. About 15 minutes later, it started right up and I was able to make it home. I pulled the carburetor back off and was convinced there was more junk inside. The inside appeared clean, but this time I removed every possible needle, jet, and bolt and cleaned everything thoroughly.
Next, I decided to pull and inspect the on/off/reserve valve and fuel tank. Both had some sediment and other junk inside. If this is making it past the in-line fuel filer, it can’t be good.
The valve:
Fill tube:
It looks like something is peeling from the filler neck and inside the tank.
There is also one last 2-foot section of metal gas line that I had not replaced that may also be rusty inside. I will replace it.
This not running so good and having to trailer, rope tow, or push the VW is starting to kill my awesome vibe when driving the Single Cab. I need to get it running better. I’m hoping I can clean up the tank rather than spend $180 to replace it. On the other hand, I am contemplating the purchase a rebuilt German carb. However, I realize it is not EMPI’s fault if I’m running sediment it, but it has had other issues such as the choke butterfly valve sticking along the edges. Anyone disagree with this approach? |
Posted: Mon Aug 06, 2018 2:16 pm Post subject: Re: Restoration: 1960 Single Cab |
Clean the tank. Get a German carb. All too often original parts from Germany are much better quality, and so better to clean up, rebuild, and repair such. _________________ In Stereo, Where Available! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Mon Aug 06, 2018 6:28 pm Post subject: Re: Restoration: 1960 Single Cab |
^^^ What they said. Aftermarket parts are generally crap. _________________ nothing |
djkkmelton Samba Member
Joined: July 12, 2016 Posts: 13 Location: Huntsville AL
Posted: Mon Aug 06, 2018 6:59 pm Post subject: Re: Restoration: 1960 Single Cab |
Wonder if someone had previously sloshed the tank and it is now flaking off? |
Posted: Mon Aug 06, 2018 7:48 pm Post subject: Re: Restoration: 1960 Single Cab |
This looks like the aforementioned fuel tank sealer applied without proper metal prep. Those peeling chunks will definitely cause issues. _________________ nothing |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Mon Aug 06, 2018 7:55 pm Post subject: Re: Restoration: 1960 Single Cab |
cdennisg wrote: |
This looks like the aforementioned fuel tank sealer applied without proper metal prep. Those peeling chunks will definitely cause issues. |
X2. Sloshing tanks is time-consuming, aka prone to short-cuts.
I am running a very nicely rebuilt Solex carb. Very well-worth the money. |
Posted: Mon Aug 20, 2018 7:10 pm Post subject: Re: Restoration: 1960 Single Cab |
After cleaning the old gas tank I was worried more of the inside coating would eventually flake. I decided to replace the tank.
I also replaced the reserve valve with a simple tap. I will try to clean-up and rebuild the old reserve valve and eventually use it.
I replaced the rest of the fuel lines and moved the fuel filter up higher (but still out of the engine compartment).
I replaced the fuel pump.
I replaced the EMPI carb with a German Solex rebuilt by VolkzBitz.
I ran out of time on Sunday night and will try to start the SC next weekend. |
Z Samba Member
Posted: Mon Aug 20, 2018 8:03 pm Post subject: Re: Restoration: 1960 Single Cab |
I should have said that my carb came from Volksbitz...you’ll be happy. |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Tue Aug 21, 2018 11:43 am Post subject: Re: Restoration: 1960 Single Cab |
The Volkzbitz carb i put on my Crewcab was a game changer. It ran amazing right out of the box |
Posted: Wed Aug 22, 2018 12:10 pm Post subject: Re: Restoration: 1960 Single Cab |
Thanks Z and norcalmike! The Volkzbitz carb looks great and just feels better than the EMPI carb. And Tim at Volkzbitz was great to work with. |
Posted: Mon Aug 27, 2018 2:41 pm Post subject: Re: Restoration: 1960 Single Cab |
After installing a new gas tank, new fuel lines, new fuel filter, new fuel pump, and sweet rebuilt carb from VolkzBitz the SC would not start. Fuel was coming out of the fuel pump. No fuel in the carb bowl. The needle valve was sticking shut. We replaced it and it fired up. It is running good so far!
And hopefully no more of worrying about this! :0
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Aug 27, 2018 5:17 pm Post subject: Re: Restoration: 1960 Single Cab |
I'm still having issues with my 1961 SC, here's the contortions I've gone through:
https://www.thesamba.com/vw/forum/viewtopic.php?t=687468&highlight=single+cab
seems to be a gravity feed issue of some sort. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Mon Sep 17, 2018 1:04 pm Post subject: Re: Restoration: 1960 Single Cab |
The Single Cab has been running great since the gas tank replacement (and every other part that deals with gas).
We added another plate under the passenger side lower door hinge. This raises up the door and makes it easier to shut.
Drove the VW to work. Someone asked me if I cut apart a bus to make a truck. :0
Using the VW to deliver donations.
Cars & Coffee at the Palladio in Folsom, CA.
It may be time to start looking for the next project! |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Mon Sep 17, 2018 1:36 pm Post subject: Re: Restoration: 1960 Single Cab |
Been asked the same thing many times in my DC...I "wow'd" people with my exceptional metal working skills, since it looked factory...I explained it was the first few times but stopped when they knew more about VWs than I and said it wasn't hahaha (they had never seen or heard of a VW truck).
Glad it's treating y'all well and hitting the road! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Sep 17, 2018 2:59 pm Post subject: Re: Restoration: 1960 Single Cab |
62DoKaGuy wrote: |
Glad it's treating y'all well and hitting the road! |
probably due to the famous "chicken tax" from 1964:
https://en.wikipedia.org/wiki/Chicken_tax _________________ regards
Uli
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Truck looks great!!! _________________ Brandon |
