BarryL Samba Member
Joined: November 01, 2004 Posts: 14218 Location: Casa de Oro, California
Posted: Wed Jan 25, 2017 9:40 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
Eric&Barb wrote: |
...that tin is to close off the side keeping the flow of cooling air flowing from the cylinders above, and keeping water/dirt/rocks kicked up by the rear wheels from the underside of the cylinders and push rod tubes. |
Then it isn't used on split busses unless you discard your heater boxes and run J-tubes or do you use it with heater boxes? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jan 25, 2017 4:24 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
BarryL wrote: |
Will not fit with HEs and used only with J-tubes. _________________ In Stereo, Where Available! |
davidmelton Samba Member
Posted: Sun Feb 05, 2017 3:38 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We added a t-handle to the engine lid. It is not period correct, but makes it so much easier to open the lid.
Next, we add the missing rear-engine tin.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22573 Location: NYC/Upstate/ROW
Posted: Sun Feb 05, 2017 6:07 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Add some 7 mil nitrile gloves and clear safety goggles to,your Valentines Day gift list from Dad, Young LadyBus Mechanic. Good job on the hair tie back!
When you start rolling under you want to keep junk out of your eyes.
Do you have the Muir Book? Good section on safety there _________________ .ssS! |
Posted: Mon Feb 20, 2017 6:47 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We took time over the 3-day weekend to start removing parts in preparation of media blasting and painting with an epoxy primer.
My wife came out to help!
I was able to remove the engine today. For the most part, it was easier than I anticipated, except for removing the nut on the top right. It was a pain to remove.
Some concerns about metal shavings inside the housing. Not sure where the shavings came from.
Also found where the metal gas line is supposed to go through. This piece was not previously used or connected.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20233 Location: Sandpoint, ID
Posted: Mon Feb 20, 2017 6:54 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
^^^ Not for the fuel line. That is the tube the throttle cable passes through.
Metal shavings are likely leftover from using the flywheel to clearance the bellhousing during the 6-volt to 12-volt flywheel fitting. _________________ nothing |
Posted: Mon Feb 20, 2017 6:59 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Metal shavings are not a big deal. You can see where the flywheel has barely touched the transaxle bell housing.
Clutch throw out bearing looks like it is not L/R even in relation to the input shaft. Needs to be shimmed over or the bearing will not last long.
Tube is for the throttle cable, not fuel line. Supposed to be a rubber seal to keep cooling air from leaking out around the throttle tube at the shroud, can use a fender washer clamped up against the shroud with that hose clamp to help with that.
Looks like you are missing front engine tin and dog house exhaust tube. Need a bolt in that slot of the tin at base of the cooler to keep shroud from opening up there, and probably need the foam seals for the shroud to oil cooler, exhaust shell and seals for the exhaust tube.
Need to get the spark plug clips for the rear of the shroud to both close up the three holes in the shroud to plug up cooling air from escaping and keep the plug wires from chaffing and shorting out.
Find stock rear tin that uses the sealing tin pieces around the heat riser tube. _________________ In Stereo, Where Available! |
Posted: Mon Feb 20, 2017 7:07 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Also missing the spring for the thermostatic flaps. _________________ In Stereo, Where Available! |
Posted: Mon Feb 20, 2017 7:16 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Here the fuel line goes around the left side of the shroud. Note there should be a bracket bolted to the left side of the shroud to hold the metal line from vibrating. Stock grommet in front tin keeps the metal line from getting cut on edge of tin hole.
Posted: Mon Feb 20, 2017 8:03 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
Eric&Barb and cdennisg, thank you for the detailed info!
1. My metal fuel line is pretty short and a rubber hose is attached to it and then to the fuel pump. Do you have a photo of the path for the metal line and how close it runs to the fuel pump?
2. I thought we had installed the front engine tin. The rear apron with the rubber that goes between is not depicted in my photos.
3. What does the dog house exhaust tube look like and where does it go?
4. Spark plug clips are on hand, but not yet installed!
Thanks again!
David |
Posted: Mon Feb 20, 2017 8:43 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
1. Well the image posted above shows most of the route for the metal fuel line. Gets to about 2" from the pump.
2. #17 in the diagram on page 3.
3. #14 in same diagram.
Ignore the fuel line shown in the below images.
4. Get R Done! _________________ In Stereo, Where Available! |
Posted: Mon Feb 20, 2017 8:59 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
This about the best image from the gallery for the pump end of the metal fuel line.
1200 cc engines has a threaded in end of the fuel line into the fuel pump. 1500cc engine went to the short section of rubber between metal line and pump inlet. _________________ In Stereo, Where Available! |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Feb 21, 2017 10:34 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
davidmelton wrote: |
If you do one thing to modify the engine, I'd recommend nutserting that top left (DS) engine mount --- listened to the old man (my dad) after years of young-man's stubbornness and realized he might know what he's doing...you're moving along, though. Badass! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Tue Feb 21, 2017 10:38 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
hmm, i think your metal shavings come from running a 1600 in a bus that came with a 1200. The larger flywheel will clearance the transmission, just a tad, the first time you start it.... _________________ regards
Uli
Posted: Tue Feb 21, 2017 10:57 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
The driver's side top engine bolt boss should already have a nutsert in it. If not definitely put one in there. It can be nearly impossible to get a nut/bolt combo installed, much less removed, from that location with the offset oil cooler and proper shrouds in place. _________________ nothing |
Posted: Wed Mar 08, 2017 10:08 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We just got the SC back after media blasting and epoxy primer coating. Some areas were better than I expected. Some areas were a lot worse. The prior primer was hiding a lot of bondo and holes.
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1254 Location: Yulee FL
Posted: Thu Mar 09, 2017 6:00 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
Wow that thing is solid!!! |
Posted: Sun Mar 19, 2017 7:59 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
We added the tabs to hold the rails for the front safari windows. We used screws to temporarily hold them in place until our welding skills are good enough to weld the tabs. We have a lot more practicing to do on the welder!
We are going to add a retro-style reproduction fuel gauge (not pictured). We added a fuel sender to the gas tank.
Replaced the oil screen and replaced 2 studs and all 6 nuts with gaskets and rings.
Found the rubber stopper to go under the accelerator tube. Eric&Barb should be happy!
Added a panel van style grab bar to the front dash. Purchased it from Der Bus Hause who makes reproductions and advertises on The Samba. I had the handle powdered coated glossy black. This makes it so much easier to get in the Single Cab.
We installed the rear safari window. We purchased it (along with the front windows) from Wolfgang International. The install was similar to the front windows, but the rear-window locks open all the way or it closed (unlike the front windows).
Found a used spring the for the missing one for the thermostatic flaps.
Posted: Mon Mar 20, 2017 6:46 am Post subject: Re: New project: 1960 Single Cab ("Henry") |
Found the rubber stopper to go under the accelerator tube. Eric&Barb should be happy! |
Nice find!
If you use the clamp there you will need to use a fender washer on the pipe to protect that rubber stopper from the clamp. Other wise the clamp will turn with the pipe and shove the rubber stopper inside, then the pipe will shift front/rear. VW originally used a grommet in the front tin to help lock the pipe from sliding, plus kept the pipe from getting cut thru.
Have you gotten the kind of accelerator boden tube that goes up front of the pipe. Without that the cable will often cut into the nose of the transaxle. _________________ In Stereo, Where Available! |
Posted: Sat Apr 01, 2017 7:06 pm Post subject: Re: New project: 1960 Single Cab ("Henry") |
The PO had installed non-VW tail lights. And (sadly) had made the hole too big for the stock tail lights.
So, I decided to install the 1963 stock tail lights because I could make the hole oval in shape and just a bit bigger.
Unfortunately, we miscalculated the size of the hole by tracing around the tail light. And now the hole is too big. (Not followed: Measure twice and cut once.)
Now we are thinking about using the correct 1960 tail lights and welding in some new sheet metal to hold them properly.
We purchased a good-sized compressor so we can start doing some body work with pneumatic air tools. Our old compressor was too small.
After the disappointment at the tail-light-hole debacle, I decided to do something that was easy. We replaced the spark plugs, wires, and rotor cap.
Next, we replaced the front and rear shocks.
While replacing the shocks we learned that we were completely missing a Zerk fitting and several fittings were painted over on the front axle. |
