furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sun Aug 07, 2016 4:09 pm Post subject: Rounded proboscis proof of concept testing |
Wind noise is always comes up when discussing cabin noise in the van.
I had a theory that a rounded proboscis could reduce that noise.
I built a "proof of concept" apparatus to test my theory.
I was correct.
Certainly hard on the eyes, and may seem slightly unscientific, but absolutely unquestionable results;
Without apparatus wind noise become discernible at 32-34mph and rises significantly with increase in speed.
WITH apparatus wind noise becomes discernible at 45-48mph.
Noise level is approximately 1/3 the amount present without the apparatus.
Also, I might be imaging this but I would swear the van took less power to maintain speed and seemed to coast further.
I was not surprised my theory was proven correct, I WAS surprised by the extreme difference.
I am now designing a permanent, removable apparatus for my application.
FYI this one is made of a satellite dish, pvc boards,duct tape and fiberglass resin over fleece, held on with a strap and bungee cord.
Neil2 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Aug 07, 2016 4:16 pm Post subject: Re: Rounded proboscis proof of concept testing |
Wow...just, wow.
Kit available...???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Merian Samba Member
Posted: Sun Aug 07, 2016 4:53 pm Post subject: Re: Rounded proboscis proof of concept testing |
this will work well when the Tesla upgrade kit becomes available
until then, you'll want to find a wrecked BMW for the LED headlights to be faired in, and set an air scoop underneath to feed the radiator _________________ .... |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Sun Aug 07, 2016 5:56 pm Post subject: Re: Rounded proboscis proof of concept testing |
furrylittleotter wrote: |
Certainly hard on the eyes... |
Call it The Hannibal...
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Sun Aug 07, 2016 6:42 pm Post subject: Re: Rounded proboscis proof of concept testing |
Hello , clarice....
Sssssshhhhhhhhhhppppppp _________________ .ssS! |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Sun Aug 07, 2016 8:03 pm Post subject: Re: Rounded proboscis proof of concept testing |
I clicked out of curiosity. It's a grab bag in most cases. My thoughts: If you round it off enough and make it more aerodynamic, you might end up with a Eurovan. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
Merian Samba Member
Posted: Sun Aug 07, 2016 9:00 pm Post subject: Re: Rounded proboscis proof of concept testing |
rubbachicken Samba Member
Posted: Sun Aug 07, 2016 9:20 pm Post subject: Re: Rounded proboscis proof of concept testing |
give another try, without the probiscus or what ever it's called, but properly seal up all the vent holes, everything on the front, except the radiator, and try that, on mrs rubbachickens carat, air noise is directly relate to the front vents, i played about taping bits off, and we cut down some of the noise, we don't have a db meter to know for sure. _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
jimf909 Samba Member
Posted: Sun Aug 07, 2016 9:45 pm Post subject: Re: Rounded proboscis proof of concept testing |
I love science! Time to get the db meter. _________________ - Jim
Abscate wrote: |
Posted: Mon Aug 08, 2016 12:33 am Post subject: Re: Rounded proboscis proof of concept testing |
rubbachicken wrote: |
give another try, without the probiscus or what ever it's called, but properly seal up all the vent holes, everything on the front, except the radiator, and try that, on mrs rubbachickens carat, air noise is directly relate to the front vents, i played about taping bits off, and we cut down some of the noise, we don't have a db meter to know for sure. |
Are you referring to hhe fresh air vent alone, or are ther other vents to tape off? I've taped off the fresh air vent and noticed some reduction in noise but I have more duct tape if there are more vents to tape up. _________________ - Jim
Abscate wrote: |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Aug 08, 2016 1:17 am Post subject: Re: Rounded proboscis proof of concept testing |
Is the taped together aluminum on the ground in your second photo proboscis prototype version 1? lol
Blocking up the vents might reduce the noise but your Subaru engine isn't gong to like it if you run for too long with the radiator air flow blocked off. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1884 Location: Montreal
Posted: Mon Aug 08, 2016 3:39 am Post subject: Re: Rounded proboscis proof of concept testing |
I bet a lot of"noise" is created by the front windshield seal and the vertical rain gutter.
Early Jettas had an aftermarket foil that mounted on the rain gutter, did wonders. |
Posted: Mon Aug 08, 2016 4:41 am Post subject: Re: Rounded proboscis proof of concept testing |
Your Vanagons are noisy. I can hear you in my tomb like EV..
( suit on) _________________ .ssS! |
Posted: Mon Aug 08, 2016 6:47 am Post subject: Re: Rounded proboscis proof of concept testing |
Mellow Yellow 74 wrote: |
...your Subaru engine isn't gong to like it if you run for too long with the radiator air flow blocked off. |
The radiator is gone -- moved to the rear of the engine bay as I recall.
This is not your father's Vanagon. |
Posted: Mon Aug 08, 2016 6:53 am Post subject: Re: Rounded proboscis proof of concept testing |
I don't have the stock vanagon fresh air intake. Everything on the front was already sealed, fat matted and covered in EZ -cool, bedlined, even added some Soundown, new carpet and floor mats, good door and window seals.
I had also already sealed off the lower grill opening with aluminium and the upper behind the grill with coroplast.
The entire under- nose area is panelled with Aluma-corr.
All of that made a difference, like maybe 1/3 or 1/4 quieter overall, but trivial in comparison to this.
My radiator does not live there. I don't need cooling intake.
My Subaru engine has run thousands of miles with rear and now mid radiator that "will never work"
I would've used my iPhone Db meter if the difference wasn't dramatically different but it was.
I have tried rain gutter foils in the past but results were inconclusive.
This new development might merit a revisit of that area as well as door leading edge.
The duct straps on the ground are the first attempt at the prototype.
They were replaced with duct tape.
This is my first attempt working with glassfibre and it was fun.
The process of construction using resin over fleece is quite versatile and allows for relatively fast mock ups such as this.
Neil2 |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Mon Aug 08, 2016 9:00 am Post subject: Re: Rounded proboscis proof of concept testing |
Without intending to reduce noise, I put new foam on my heater box and found freeway wind noise reduced dramatically. I was surprised by it and apparently our heater boxes are letting air through that makes a variety of noises at a broad spectrum of speeds. So, something else for folks to consider doing, which has another benefit of making the heater into a virtual tornado as it was when new. Amazing output both in heat and in air movement.
This is a pretty cool modification and bit of research!!
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Mon Aug 08, 2016 9:24 am Post subject: Re: Rounded proboscis proof of concept testing |
You are going to get terrible reception with the dish in that position.
I would LOVE to see some well done MPG data (same route, same time of day, same ambient temp, etc.)
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Mon Aug 08, 2016 10:25 am Post subject: Re: Rounded proboscis proof of concept testing |
raoul mitgong wrote: |
-d |
This!
I bet it will help. These vans have terrible aerodynamics.
I removed my "luggage rack" and that reduced wind noise and helped MPGs. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Aug 08, 2016 11:21 am Post subject: Re: Rounded proboscis proof of concept testing |
Fortunately for you, you do not have to see it while driving down the road. Unfortunately, I cannot say the same thing for the people on the road.
Sorry, I understand it's a prototype, but it looks hideous. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
For some reason this came to mind.
_________________ ☮️ |
