SGKent Samba Member
Posted: Fri Aug 12, 2016 7:37 pm Post subject: how long to charge a battery |
Besides the normal cautions when charging - no frozen batteries, water level correct, no smoking or sparks due to hydrogen, eye and skin protection from acid. here is a way to roughly calculate how long to charge a battery. You should know this because some chargers may say they are automatic but they aren't always as promised. Another way is to check the specific gravity if you have the bulb and access to the battery acid.
First you must know if your battery is AGM, maintenance free, or calcium based. If so you will use a different part of the chart. Second you must know the Reserve Capacity of your battery, which you can usually find online if you know the battery manufacture and model. In my case it is an Interstate Mega-Tron Plus 48 / h6, That is a calcium silver battery with AGM construction and is meant to be maintenance free although I do check water levels. This battery has a reserve capacity of 115.
Multiple the RC x .6. In my case that is 115 x .6 = 69
Measure the voltage with no load on it - called open cell voltage. Mine is 12.55 volts.
Check the battery temperature with a laser gun if you have it. It is 90 F here.
On the chart that shows the battery is appx 60% charged which sounds about right as it has been sitting awhile.
Multiple 40% needed to get to 100% (100% - 60% = 40%) X the total we got of (RC x .6) so 40% x 69 = 27.6. [remember the 69 came from 115 RC for my battery x .6)
Add 15% for battery internal resistance, This is a standard. 27.6 + 15% = 31.74.
Divide the number (in this case 31.74) by the amps you will be charging at per hour and that is how long to charge. I will charge at 10 amps so 31.74 / 10 = about 3 hours to get to a full charge. If I charged at 2 amps it would be about 15 - 16 hours.
I like to remove the battery once a year, check fluid level and charge it to 100% unless it has been driven often. Then I wipe the area around the battery with water and baking soda to neutralize any acid that is on the paint and metal. Don't get any in the battery or it will kill it. I then clean the terminals and put a little Vaseline on them before putting it the cables back on. If you have a label printer you can mark + and - on the side of the battery as on a bus it is hard to see that if the marks are on top.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SGKent Samba Member
Posted: Sat Dec 23, 2017 7:38 pm Post subject: Re: how long to charge a battery |
just had to charge the battery since it has been sitting awhile. Formula works like a champ. Be sure to measure before you start charging because the surface voltage will throw the resting open cell voltage off. Once can also measure the battery acid however that is harder in a VW bus because one has to pull the battery to be able to do that. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SGKent Samba Member
Posted: Sun Jul 15, 2018 1:53 pm Post subject: Re: how long to charge a battery |
correction - 48 Mega-tron MTP 48/H6 is wet cell. Holding up well. I added a CTEK MXS 5.0 battery maintenance charger to it for when the bus sits too many weeks and the charge drains. CTEK makes the Porsche labeled maintenance chargers. It also has a step that can remove sulfates from the battery, extending its life. I chose this model based on reviews and an article where someone watched the charging pulses on an oscilloscope to determine which chargers were best designed for maintaining a vehicle battery.
Interstate MTP 48-H6 battery
Part Number MTP-48/H6
Group Size H6
Cold Cranking Amps 730
Cranking Amps 910
Reserve Capacity (RC) @ 25 hr 115
Amp Hours (Ah) @ 20 Hr 70
Length 11
Width 6 15/16
Height 7 1/2
Weight 38.8
Termination Code Common Code A
Voltage 12
CTEK charger
Porsche charger
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Sun Jul 15, 2018 5:46 pm Post subject: Re: how long to charge a battery |
Good stuff!
The most important point is that full charge specific gravity INCREASES with lower temperature. Not intuitive!
Not clear if the pulse charging commonly sold actually helps sulfate removal or not. I built a couple of experimental units and the best I can say is that it dosen't hurt. The most viable technique seems to charge the battery for a while, then discharge it a bit. This seems to even out the metalic lead deposit on the battery plates. The main drawback is it is slow (two forward, one back) and it wastes a bunch of energy, as you have to dump that discharge energy somewhere. Now maybe a dual battery charger setup where the discharge phase of one battery dumps its energy into the charge phase of a second battery, and vis versa. Don't know. Will take a bunch of parts and time to find out...(some day). _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
