Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Mon Jul 03, 2017 6:13 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
The first pulley had issues from the time I got it, it was original and already quite warped. I think it's failure was impending from the get go.
The second was a reproduction pulley bought here on thesamba. I believe the spot welds on that pulley failed. First one weld and then the failure passed onto the next and so forth.
The Crank is true. Each failure occurred with a different crankshaft as well. My belts are the same as I've done for 20 years and done according to factory specs.
The second pulley, the reproduction, was great until one day it suddenly appeared slightly loose. Then I would adjust a shim, then soon it would be loose again...this continued. Now that I look back, I believe it was in the process of bending or braking loose of spot welds. I personally would purchase another reproduction (even though I haven't yet), but I would carefully inspect it and TIG weld the backside of the spot welds. There are a few other factors that may have been in play, but I think the basic story is to carefully inspect early pulleys both upper and lower. Don't tolerate much wear on the upper pulley and the related pieces of that because that can lead to pulley movement/vibration when driving. Talking to folks, old timers knew these 25hp style pulleys were prone to failure...now I understand why VW upgraded them with the rolled lip style for additional rigidity.
I am driving my car quite a lot, some of these issues that owners had with early parts get exposed in that process. _________________ https://instagram.com/mr.ogpaint
Patrick Hall
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Fri Aug 04, 2017 10:44 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
A crashbox update
Thankfully a friend had this NOS bearing to replace the failed bearing in my gearbox. This is the same bearing as regular splitcase trans
Decided to replace all other bearings, except one, while it was apart. The rear pinion bearing was perfect and nicer than an NOS one I sourced from the same friend. All other bearings were replaced with SKF or FAG.
Redid the axle tubes with flattened Imron. Axle tubes are a little too glossy, but didn't have time to repaint them again. Seamless boots from Wolfsburg West
It drives even better now since the rebuild. Shifts better, quieter.....recently driving it since the rebuild including a trip to Seattle for Vintage Meet, camping in Leavenworth WA, and this quick picture by a vintage sign in Monroe WA on our way home to Oregon. _________________ https://instagram.com/mr.ogpaint
Patrick Hall
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Sun Aug 06, 2017 8:04 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Nice work Patrick!
Thanks for letting me drive it. I found it super easy to learn to drive a full crash, and fun, maybe it's because of how good your transmission worked. |
52 split Samba Member
Joined: December 19, 2007 Posts: 150 Location: the best island in the world, vancouver island
Posted: Mon Aug 07, 2017 2:02 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
thank you again Patrick for taking me and my daughter for a cruise on the I-5 and watching you masterfully double clutching. both of us left the rose city bug in pumped. |
Posted: Mon Aug 07, 2017 4:48 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
campingbox wrote: |
Nice work Patrick!
Thanks Greg. I just think you're a natural (and it's not as tough as some people wanna make it sound)
52 split wrote: |
You're so welcome Boris. It was really nice meeting you both and sharing the car with you. Good luck on your car, please let me know however I can be of help.. Hopefully next time we meet up you'll give driving the split window a chance. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
D-train Samba Member
Posted: Mon Aug 07, 2017 6:17 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
What coating did you use on the case? _________________ shiny paint doesnt make it worth any more |
Posted: Tue Aug 08, 2017 3:47 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
An aluminum etching coating and alodine _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Sun Sep 17, 2017 12:30 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Sad face. _________________ shiny paint doesnt make it worth any more |
OvalinAz Samba Mini Tech
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Sep 17, 2017 2:41 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Care to share?, some of us don't do FB or IG, I'm assuming there's something to be sad about on there? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Sep 17, 2017 4:08 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
busdaddy wrote: |
Care to share?, some of us don't do FB or IG, I'm assuming there's something to be sad about on there? |
It's a story for mr ogpaint to tell.. _________________ shiny paint doesnt make it worth any more |
Posted: Mon Sep 18, 2017 8:02 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
The story has been told, I'm not sure if Patrick will repost it here, if you are not on IG you can google search #chestnutthesplit and find photos. Not sure if you can read the text/comments.
Patrick and Rachael were in a multiple car accident on the way to the Yakima show this past weekend. It was not their fault. The damage to the car was pretty significant. From an insurance standpoint it may be considered to be a total loss, but I expect it could be fixed and used again one day with some serious effort. They walked away bruised and sore but with no broken bones. They made it to Yakima in another vehicle, and they do seem to be in good spirits considering. It was very impressive. It was good to see them. Their always contagious positive attitude was surprisingly intact.
I am looking forward to seeing you guys soon. |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Mon Sep 18, 2017 8:21 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
I feel sorry with you!
You gave the car the right therapy it deserved, doing so many good things to that survivor. Driving also belongs to it, no riding - no fun. These cars need to be driven, also to stay present for public.
I drive my '50 every dry and shiny day, at my way to work, being also aware of the risk every time, especially when many mad people drive behind me without any reasonable distance, a big illness today. But I can't help it but keeping driving. It's also a kind of addiction...
I really hope, no, I'm sure that you will find a good way getting out of this. Now, this car is still more a survivor than before, as it looks to be fixable.
All best wishes for you and your patient!
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
wcfvw69 Samba Purist
Posted: Mon Sep 18, 2017 9:43 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
X2 on hearing no one was seriously hurt, especially with low back seats where your head can be whipped back being rear ended and cause spinal injuries.
The bug took a serious impact but for its rarity, it can certainly be fixed with some donor metal and a talented body guy. _________________ Contact me at [email protected]
The Samba member since 2004.
René R. Samba Member
Joined: July 06, 2015 Posts: 1712 Location: No. Calif.
Posted: Mon Sep 18, 2017 9:55 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Wow. That is really distressing. I'm so glad they came through okay. The car is most definitely worth saving. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Mon Sep 18, 2017 10:07 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Oh Man!, that's definitely sad face news.
Sorry to hear about the car but glad they are OK, you can repair/replace metal, but the meaty bits inside are priceless. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Sep 18, 2017 10:26 am Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
Hi Folks- I will be posting this info soon, just had a lot to do the last several days. 7 vehicles involved in the accident so it's basically all day long on the phone right now.
I plan on catching up the story of the last couple things I've done on Chestnut before this happened....it was a 100% done split, 100% the way I liked it, 100% able to drive it anywhere at anytime in any condition, 100% original metal, completely correct car. And such an original and unmolested Beetle before this accident. After a post to catch up the storyline, I'll post the accident photos and info, but It's sad. It will be documented here though, thesamba is such a great forum for preserving the history of these cars and showing the ups and downs of restoration and ownership. Thank you Everett. I believe this car will be saved, I will do my best to see that it's documented here even if I'm not involved with the resurrection.
Thanks for the support, I expect to make a couple posts explaining everything in the next day or two...and I will have the time, because I'm not feeling up for work right now. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Mon Sep 18, 2017 6:25 pm Post subject: Re: Chestnut Brown 1952 Crotchcooler, been parked since the 70s |
so sorry to hear the news. stay strong. |
