Replacing tunnel internals
Kubelwagen Chris
Kubelwagen Chris is offline
PostPosted: Sat Aug 13, 2016 11:56 am    Post subject: Replacing tunnel internals Reply with quote
Hey guys,
I might have bitten off more than I can chew on this project. My kubel's chassi spent a couple years outside exposed. A hole rusted in the bottom tunnel cover. Over the years this allowed water and rust to destroy the cable guides and fuel line. i am looking for someone that can replace these 12mm and 8 mm tubes. Any ideas?
Also there is rust inside the fork that mounts the engine. Are there any options for getting at this? Acid dipping perhaps?
Martin Southwell
Martin Southwell is offline
PostPosted: Sun Aug 14, 2016 3:19 pm    Post subject: Replacing tunnel internals Reply with quote
I suspect that this chassis has spent more than 'a couple of years' outside. Looking at the chassis backbone, especially where the floorpans attach, the metalwork is mighty pock marked & remarkably thin in places. Is this project viable?
esde
esde is offline
PostPosted: Sun Aug 14, 2016 5:45 pm    Post subject: Re: Replacing tunnel internals Reply with quote
I would use some phosphoric acid to neutralize the rust that you can't see. I've been using it in many "blind" areas for a few years and have been very happy with the results. As for the tube, I replaced all of the cable guide tubes on a split bus last year, and Wolfsburg west carries lengths of the different diameters. Proper tube length, bracing, and securing the ends is critical.
Best of luck.. SD
modok wrote:
Kubelwagen Chris
PostPosted: Thu Sep 12, 2019 5:31 pm    Post subject: Re: Replacing tunnel internals Reply with quote
Three years later....
Martin Southwell
PostPosted: Fri Sep 13, 2019 1:12 am    Post subject: Re: Replacing tunnel internals Reply with quote
Full steam ahead now then?
mikeandkirsti
mikeandkirsti is offline
PostPosted: Fri Sep 13, 2019 4:31 am    Post subject: Re: Replacing tunnel internals Reply with quote
My 1945 Kübel got the same treatment:
splitjunkie
splitjunkie is offline
PostPosted: Fri Sep 13, 2019 2:21 pm    Post subject: Re: Replacing tunnel internals Reply with quote
This guy did it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=703609&start=60
Chris
nshaddox
nshaddox is offline
PostPosted: Sat Sep 21, 2019 2:56 pm    Post subject: Re: Replacing tunnel internals Reply with quote
Yea. Kind of a big job. Hardest part is finding the right tubing though. There’s a place in Toledo that has it in 20’ sticks. But you have to get them in person to get them long enough to not be splicing.
Just like everything else it’s pretty satisfying when it’s done. I’d probably do it again.
