Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Thu Oct 12, 2017 10:22 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Sodo wrote: |
Everyone should be careful taking my typing out to be gospel, I'm just having fun in a Samba discussion, pushing the envelope. It's almost like my buddy 'gears' who says: "I want to make the Vanagon trans strong enough so I can drop the clutch with my SVX, and romp on 2nd gear anytime I want." That's perhaps a little ambitious on the other end but if it's his guiding light that will take us all a little further. Keep i mind this is a guy who built a beetle trans up to survive 440Hp. He's been there before. |
gears wrote: |
.err .. I did say romp in 2nd & 3rd, but we'll never be able to drop the clutch with our heaviest Vanagons without paying a penalty. |
OK yeah thats only a slight exaggeration ...... but it's based on what the gleam in your eye said....
Edit: It was like this. Tom Lengyel said (referring to 'gears') "He wants to make it strong enough to dump the clutch", to which gears replied without hesitation, "No I want to romp on 2nd gear, or 3rd whenever I feel like it". But gears had just been regaling us with stories of dumping 440HP thru a beetle trans at 7,000 rpm.... _________________
....KTMs, GasGas, SPOT mtb
Syncro Jael Samba Member
Posted: Thu Oct 12, 2017 11:00 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
gears wrote: |
nJael, could you please provide a link to that cooler? It looks similar to the automatic coolers with too small an oil passage .. would be "cool" if it fits our needs. |
Gears, here is the link at Summit Racing.
https://www.summitracing.com/parts/mor-41200 _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 575 Location: Santa Fe, nm
Posted: Thu Oct 12, 2017 11:58 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
No worries sodo - not trying to call you out, just wondering if you had any Inside info that contradicted magnom's experiments as I did a lot of reading before going with the magnom thing. Anyhow agreed, more filtering the better! And I like the way gears thinks!!
I'm getting ready to chip my 1.8t so I'm counting on gears to come through with some more innovations! Perhaps bring back the casting for all aluminum cases and barrel drilled main shafts?
So far I've got 16,000 miles on my rebuilt unit with cooling and filtering and plenty of 200 ft/lb miles with almost no particles on my 8 micron filter and magnom. Here's hoping |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Oct 12, 2017 2:50 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
I think that Moroso filter is for automatic transmissions with thinner fluid. Probably too restrictive for good flow / delivery to all the various oiling points.
Sneak preview sketch of gun-drilled mainshaft. Two prototypes might be ready in a couple weeks.
The prototype billet intermediate housing with bonus features may also be ready in a couple weeks. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Oct 12, 2017 4:14 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Gears you rock!! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Thu Oct 12, 2017 8:33 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Just some photos of the Drain plug adapters and the size of AN fittings vs a Banjo Fitting when using the 2.1 WBX engine and exhaust.
This is a fitting I got from Sodo I am using for the Fill Port, but it measures the same length as other adapters I had for the AN8 JIC Flare. These are EATON fittings. 90° going into AN8 "T". Obviously not enough room!
With the exhaust installed you cannot install the fittings. Previous picture I removed the exhaust to mount the fittings.
Another problem is that any version of the 90° fitting cannot be installed because you have to rotate it and it hits the rib on the Bellhousing above it.
This is the the Banjo Fitting installed on Alika's adapter. This Banjo flare size is an AN6 (all I could find locally.) The Banjo from Pegasus that is referenced by Alika is a AN8 which will give a better flow rate being a size larger.
A side view showing the AN6 Banjo and the AN6 size "T" fitting. I am using a "T" fitting so I still have a drain port.
Alika's adapter and the Banjo fittings are the best way to go if you have the 2.1 WBX.
(These pics are just for the unenlightened who might be thinking about doing this mod. You enlightened guys already know all this stuff.) _________________ This free advice is worth exactly what you paid for it.
Sodo Samba Member
Posted: Thu Oct 12, 2017 9:08 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Steve I though you were using that fitting on the fill port. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu Oct 12, 2017 9:13 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Sodo wrote: |
Steve I though you were using that fitting on the fill port. |
I am, I was trying to find a combination that worked for the drain port and yours measured out to be the same length as others I had returned.
I just used it for the photos. _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Oct 13, 2017 5:42 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Here is a link to a possible sight gauge that could possibly be used on that rectangular oil tank I referenced in previous post. That would depend on the length between the fittings, they make different lengths.
sight gauge-Lovejoy
https://www.ebay.com/p/Lovejoy-84527101703-Hydraul...0005.m1851
There are many variations of this vertical type from different mfg's where the sight tube is enclosed and protected inside a housing.
However, I would prefer this one installed on the side of the gearbox itself if there was a location available at the height of the oil on the gearbox when full of oil.
Round window plug. The main advantage is if it leaks it is only going to leak down to the bottom of the window. Whereas on vertical sight gauges you would loose all the oil.
http://www.ebay.com/itm/3-8-NPT-Male-Brass-Sight-G...mp;vxp=mtr _________________ This free advice is worth exactly what you paid for it.
Posted: Fri Oct 13, 2017 6:22 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
gears wrote: |
I think that Moroso filter is for automatic transmissions with thinner fluid. Probably too restrictive for good flow / delivery to all the various oiling points. |
I agree. I was planning to remove the filter and use the aluminum housing as the heat sink and for the extra volume of gear oil.
Possibly it could be lined with magnets?
Just a thought.
It is great to see some of the engineering and manufacturing of these vital components for our transaxles. Hats off to you Gears! _________________ 1987 Syncro Westfalia Hightop - NAHT
gears Samba Member
Posted: Fri Oct 13, 2017 7:11 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
To be quite honest, I'm just a backyard mechanic applying solutions that are obvious to me. I'm relying on pros for manufacturing and engineering, which includes what you guys are arriving at in threads like this .. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Sodo Samba Member
Posted: Fri Oct 13, 2017 11:11 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Syncro Jael wrote: |
Possibly it could be lined with magnets? |
My internet-x-ray vision doesn't see any undue restrictions in that cooler. I think quick-release fittings are prob much more restrictive. Can you remove the end cap and look inside? If the end comes off easily (not epoxy'd?) that might answer the restriction questions, and others too. Depending on the size of the cavity maybe a magnetic element can be designed to fit in there. _________________
flomulgator Samba Member
Joined: March 07, 2013 Posts: 950 Location: Leavenworth, WA
Posted: Fri Oct 13, 2017 11:26 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Gears if you recall from last weekend we were discussing a potential issue with the fin cooler I've been using was that all of the dual pass coolers use 1/4" passages (~AN6), which is fine for ATF but I'm worried is too restrictive for thicker gear oil. Well lo and behold, I found that if you go single pass, the passage and fitting size increase to 3/8" (~AN8). My new plan is to replace my existing finned cooler and 1/4" hose with two of these connected by a U-bend at the front end, all still strapped to my driveshaft bar:
https://smile.amazon.com/gp/product/B00S75F8U2/ref...OMP4BEHXVH
The whole system will be ~AN8 or 3/8" throughout the entire circuit now.
And folks, after having Gears walk me through some of his design ideas, I can tell you the billet intermediate housing will be a must-have on any 094 rebuild. _________________ She's built like a steakhouse, but she handles like a bistro! |
Sodo Samba Member
Posted: Fri Oct 13, 2017 11:53 am Post subject: Re: Manual Transaxle oil cooler: FILTERING |
That "Assault Racing Products" cooler is welded shut. Which is good for reliability, but difficult to stuff with magnets..... if'n someone was so inclined....seeing as the subject of this thread is filtering. Also would be difficult to clean it (someday).
I'm quite curious what's inside of one that has bolted ends. It seems to be a good size for under the van, or inside either of the rear fresh air intake pillars. Will a 15" get around the corner to go vertical in the fresh air intake? _________________
Posted: Fri Oct 13, 2017 12:16 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Ha! between stuffing coolers in the air intake and this picture I see inspiration for a future cooling circuit:
I'm also going to change up my filtering. My in-fitting Setrab 250 screen did a good job of grabbing a couple large particles before the pump, but I want to do more after the pump. I'm gathering ideas from this thread, the $12 10 micron drop canister looks attractive if I can figure out a way to mount it, and then follow it with this 3/8" magnet thing:
https://smile.amazon.com/gp/product/B072PQ2XKD/ref...QJY9IZUN8K
My long-sought goal is to have an effective system with a final build cost of < $500. _________________ She's built like a steakhouse, but she handles like a bistro! |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6348 Location: Honolulu,Hawaii and France
Posted: Fri Oct 13, 2017 12:28 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Flomulgator, the magnet filter is for automatic transmission or hydraulic fluid like power steering, it might be too restrictive....
For the single pass cooler, you can always mount to in series straight shot or back to back with lebows in one end to do a connecting loop
Steve M, good to see you're getting there, it is looking good!!
Keep an eye out for leaks, fingers crossed!
Paul, are the shafts drilled twice perpendicularly at 180° ?
Aloha!
Alika _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Fri Oct 13, 2017 12:45 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
Folks in this thread are advocating filtering to incredibly small particle sizes, without very large filter areas wouldn't that also be excessively restrictive? _________________ She's built like a steakhouse, but she handles like a bistro! |
Sodo Samba Member
Posted: Fri Oct 13, 2017 1:04 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
flomulgator wrote: |
Folks in this thread are advocating filtering to incredibly small particle sizes, without very large filter areas wouldn't that also be excessively restrictive? |
The other function of an oil cooling system being "FLOW", so combining cooling and filtering from one pump is a balancing act.
A good-running trans should NOT be making any particles bigger than (wild-ass-guess here) "25 microns", I've decided to focus on magnetic capture, and sequestering of the much TINIER particles that otherwise circulate in the trans repeatedly, forever. 25 microns is visible to the eye. It's 1/4 of a mm, or about 8 thousandths.
I currently have a 10µ filter that was cheap used on eBay. But I'm thinking that if a guy has a 25µ mechanical filter, and a magnetic-reservoir type filter to catch hold the really small stuff nightly, that could be a good economical system. The magnetic filter doesn't have to reduce flow like stuffing gear oil thru tight filter media.
Saving money is rarely cheap but if you can build stuff it just costs time. Lots of time,,,,, but not as much as attending a forum.... _________________
ejimmi Samba Member
Posted: Fri Oct 13, 2017 1:20 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
gears wrote: |
To be quite honest, I'm just a backyard mechanic applying solutions that are obvious to me. I'm relying on pros for manufacturing and engineering, which includes what you guys are arriving at in threads like this .. |
GAwd Paul you are so humble......your threads spawned these threads. |
Posted: Sat Oct 14, 2017 5:15 pm Post subject: Re: Manual Transaxle oil cooler: FILTERING |
For those concerned about flow rates - o thought I’d post mine.
I have this filter (8micron) https://www.pegasusautoracing.com/productdetails.asp?RecID=11514
With about 4 quick disconnects in the system and a magnom mini filter, setrab radiator, powered by a weddle (turbowerks) pump.
I get pretty much exactly 2 gal/min flow rate |
