67ctbug Samba Member
Posted: Tue Aug 16, 2016 4:04 pm Post subject: Patch or Replace |
I'm replacing the pans in the bug and noticed this.
Now should I replace it or patch it? My pans did not come with this piece so I don't know where to get one anyway. Here's the bottom
As you can see its very rusty. So what should I do? _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Aug 16, 2016 5:03 pm Post subject: Re: Patch or Replace |
I think the pan kits from WW come with that piece. I have seen many replacement pan adds with that piece is included. Just look around. But remember you get what you pay for. Cheep often means thinner metal. While more expensive does not always mean thicker metal. Make sure to contact the vendor for the pan metal thickness before buying.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Aug 16, 2016 5:12 pm Post subject: Re: Patch or Replace |
I already bought the pans. They are thick metal, not Wolfsbürg west pans but they are around the same gauge. They definitely aren't thin. They don't have that piece on them and I can't find a vendor that sells that piece. If anyone knows a place that sells it please tell. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Aug 16, 2016 5:25 pm Post subject: Re: Patch or Replace |
Did you try calling WW? Maybe they have them in stock. Just not listed online. I can clearly see them in the adds that have on line.
Never hurts to call. You may get good news.
Good luck. _________________ I have learned over the years.
Buy Once, Cry Once!
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Tue Aug 16, 2016 5:35 pm Post subject: Re: Patch or Replace |
Can you return the pans? _________________ '65 Sunroof Bug |
Posted: Tue Aug 16, 2016 6:06 pm Post subject: Re: Patch or Replace |
I'll call Wolfsbürg west tommorow. No I can't return them I bought them from Johns Car Corner. I don't really want to return them either since they're good quality. I just need that one thing so I'm not really going to return something for one piece. If I can get that piece from Wolfsbürg West it would be great. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
Posted: Tue Aug 16, 2016 6:12 pm Post subject: Re: Patch or Replace |
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=112701062K
it appears per above link that wolfburg west sells the pan and the brace together, but they are seperate parts. i would thi k ylu might be able to buy the brace seperatly, so give them a call, then you can use the pans you already bought and add the brace from wolfsburg west. the part is not listed on the website seperatly so give them a call , they do apparently have them as part of a kit.
also note many pans come with paint on them, often this is an inferior paint only meant to prevent rust in storage, you will want to paint them properly with a tough automotive type paint, you will want to strip the paint that came on the pan first, as often it is sprayed over an unclean part that may have manufacturing oils on it under the temporary paint. thus it may be poorly adhered and all the good paint in the world over it will still fail when it fails.
so plan on stripping it bare prior to welding, then paint it. a tough epoxy type primer like DP is a good choice.
dont paint over the temporary paint that comes with the pan as a general rule.
good luck, hope wolfsburg will be able to accomidate your need for the support brace only. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Tue Aug 16, 2016 6:22 pm Post subject: Re: Patch or Replace |
ps, you have a duplicate thread running, pls delete it via the delete soft key to save having the admins do it for you. all the replies so far are to this one so the other should be deleted _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Boom Samba Member
Joined: September 29, 2007 Posts: 1119 Location: Houston by God Texas
Posted: Tue Aug 16, 2016 6:47 pm Post subject: Re: Patch or Replace |
Alright, duplicate thread gone. I'll give Wolfsbürg West a call tommorow. I really hope I can get the piece. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
TYBUGGER Samba Member
Joined: August 23, 2015 Posts: 28 Location: Long Island New York
Posted: Wed Aug 17, 2016 5:48 am Post subject: Re: Patch or Replace |
I have a set that I did not use when I replaced my pans recently. I have no use for them if you want them you can have them. I live on Long Island you could pick up or pay the shipping and I will get them to you. Ty Maple |
Posted: Tue Aug 30, 2016 10:49 am Post subject: Re: Patch or Replace |
Alright here is the napoleons hat.
As the title says, patch or replace. They are pretty bad, but I read that new napoleon hats are not very good. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Aug 31, 2016 4:53 pm Post subject: Re: Patch or Replace |
Any new napoleon hat is better than that one..I'd cut the rotted shit out and graft in the same pieces from a new one or just replace the whole piece with new.
Could do like this:
_________________ 1963 Ragtop Bug |
Posted: Wed Aug 31, 2016 5:31 pm Post subject: Re: Patch or Replace |
That's what I'm thinking, graft in new pieces. Anyone have experience with mtmfg? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
