Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Tue Oct 24, 2017 6:36 am Post subject: Re: Overlanding a VW Bus Around The World?! |
1998-2005 Passat steel wheels in 15" fit by enlarging the center bore. I suggest steel wheels due to the fact that they bend instead of cracking in an extreme impact, if bent, they can be straightened with a BFH _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Tue Oct 24, 2017 8:31 am Post subject: Re: Overlanding a VW Bus Around The World?! |
TDCTDI wrote: |
1998-2005 Passat steel wheels in 15" fit by enlarging the center bore. I suggest steel wheels due to the fact that they bend instead of cracking in an extreme impact, if bent, they can be straightened with a BFH |
This is for sure what Id go with for the actual rim - I found a 15" Passat pair in ET38 I belive where the Bus has an ET of 37? Of vise versa. Point is I found a rim thats near dead nuts not needing any spacing.
In a stock bus wheel well Id imagine the closer to 195 you can get in an AT tire the better off you will be long term - rough road. Im personally going to shoot for a 215 for my 77 when I get to it. You sacrifice some track width by ding so but for what I do driving wise it wouldn't matter. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
haydenslides Samba Member
Joined: December 03, 2013 Posts: 18 Location: Port Angeles WA
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Oct 29, 2017 3:20 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
sorry to have neglected this thread for so long-
Been trying to get the bus "road ready" so Ben n Leah can drive round S Cal and W Arizona for the required parts. Have provided secure storage for their stuff, and found a recently rebuilt front beam with new calipers and ball joints. But waiting for Ben to see them before there put in.
Just put a new key switch in electrical, and need to fix the wiper switch and drivers door handle- so if any one has one- please speak up. But at least it starts up now from the comfort of the front seat.
As Ben n Leah have a limited time, I'm doing the hard part of finding the correct parts- and If there parts are OK- I've a 78 in need of stuff.
Getting the ride height correct for rutted roads and swamp land- is our next hurtle. using a water proof grease for bearings and tie rods will be a big improvement (after watching how many times co-pito spent wading thru the brackish swamps- I'm hoping they avoid the broken bearings, bad CV's (I found some 181 's) and general malfunctions you can not avoid when truly exploring.
So- here are some recent pics and any suggestions from bracing the swivel seat to why didn't you ??? while you were there. will be appreciated.[img]
Believe it when I say- this is the ONLY rust thru- and have the weld in plat to replace it. Now just gotta get "Fabricator John" involved --(hurray- he beat throat cancer this summer- ) but the 118* weather probably helped-
It's currently running a 1800 with a center carb but plenty of FI available should you want to go that way- I'm also in the middle of a 2.0 mystery cam motor nearly complet- and enough parts to put together an 86a cam motor with Amc heads and an 701 hyd cam motor also with Amc heads. SO- the choices are plenty but in reality- hope they can get a factory motor of some sort. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Manfred58sc Samba Member
Posted: Tue Dec 19, 2017 9:06 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Adventure Wagon? _________________ Fat chick owner/operator |
Posted: Wed Dec 20, 2017 10:07 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Well mine has served me for 32 years and just shy of 700K miles , may you have such good fortune. The interior layout is a bit "clunky" in my book, but the high roof sure is nice. I only kept the head-banger,table, fridge/cookstove..the rest was too in the way. _________________ Fat chick owner/operator |
Posted: Thu Dec 21, 2017 3:09 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
OK, I am guessing you will be charging forth with a T-4 engine. Bigger is not necessarily better in this realm. The 1800 is a good performer and can run well with a single progressive carburetor. I would suggest the following 1- bring an extra set of heads 2- make sure your distributor is a properly rebuilt unit from one of the samba re-builders 3- install a tachometer so you drive in the correct rpm range at all times.
In this day and age you must treat the T-4 engine like rare wine, easy to enjoy-hard to replace.
How about some interior pictures? _________________ Fat chick owner/operator |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Dec 21, 2017 7:33 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
I've got a spare water buffalo if you wAnt to connect to people _________________ .ssS! |
Posted: Thu Dec 21, 2017 7:46 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Abscate wrote: |
I've got a spare water buffalo if you wAnt to connect to people |
to much bull shit-- it is a bull right? _________________ some days I get up and just sit and think. Some days I just sit.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Fri Dec 22, 2017 2:29 am Post subject: Re: Overlanding a VW Bus Around The World?! |
williamM wrote: |
Abscate wrote: |
to much bull shit-- it is a bull right? |
Yes- they seem to be more than 90% based in Asia, by population statistics.
Still, don't step in any…
www.airschooled.com |
Posted: Fri Dec 22, 2017 4:54 am Post subject: Re: Overlanding a VW Bus Around The World?! |
williamM wrote: |
Abscate wrote: |
It is. I was thinking on that swivel seat..have you tried to make some use OG under seat space fir something? Even 8 tracks storage? I think there was a thread on that ****somewhere**** _________________ .ssS! |
Posted: Fri Dec 22, 2017 6:50 am Post subject: Re: Overlanding a VW Bus Around The World?! |
swivel seat is in and working. It came with the flat bit of the Vanagon wheel bucket it originally bolted to- and the dimensions were perfect for being welded to the top of the original seat rails.
This retained the bit of original storage and produced another storage under the mounting plate. They seem very happy with it.
Posted: Fri Dec 22, 2017 8:41 am Post subject: Re: Overlanding a VW Bus Around The World?! |
williamM wrote: |
We are, not 100% sure what Australia import people will say about it. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
Xevin Samba Member
Posted: Fri Dec 22, 2017 10:43 am Post subject: Re: Overlanding a VW Bus Around The World?! |
[quote="HastaAlaska"]
williamM wrote: |
We are, not 100% sure what Australia import people will say about it. |
Well. That could make a good episode when the bus is impounded But
Seriously. Were will this bus be registered and licensed when you plan on bringing to Australia? This is going to be interesting. If You having a car registered in the US but are an English citizen how to you apply for a Carnet for Australia. US citiens do it through Ottawa Canada will it be the some for you? Hell what about all the Asian import laws when you ship It there. I’m sure you’ve already done your homework. Carry on
Read through this Ben. If you haven’t already.
https://www.homeaffairs.gov.au/Importingandbuyingg...s-faqs.pdf
Importing your dog is going to take some forward planning as well
http://www.agriculture.gov.au/cats-dogs/frequently-asked-questions
Hopefully it all works out. Cause “Hope is not a plan”
Calm down I’m just busting your balls a little Hopefully some of those links help _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Fri Dec 22, 2017 11:06 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Will the Australian inspectors care you put FI on an orginal Carb Bus? Or is it all
About meeting safety criteria? Are you leaving bus there for some lucky winner?
Still not sure why you want to dick around with FI issues in Asia should they arise. If you going 2.0L Type 4 I’d put a pair of Weber 40 IDFs on for your particular trip and bring a couple of rebuild kits. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Sat Dec 23, 2017 7:18 am Post subject: Re: Overlanding a VW Bus Around The World?! |
I read an article in Haggerty magazine lately pertaining to this..https://www.hemmings.com/blog/2017/08/04/crackdown-on-asbestos-essentially-halts-collector-car-exports-to-australia/
They may not let you in..have a gander,Braking system alone will probably cause denial of entry. _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
