Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Mon Nov 19, 2018 4:17 am Post subject: Re: Overlanding a VW Bus Around The World?! |
These don’t work very well on a vehicle with an open differential. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Nov 19, 2018 5:04 am Post subject: Re: Overlanding a VW Bus Around The World?! |
video shows it comes in pairs so you have to hook up both sides- effectively locking the diff. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Mon Nov 19, 2018 5:37 am Post subject: Re: Overlanding a VW Bus Around The World?! |
williamM wrote: |
video shows it comes in pairs so you have to hook up both sides- effectively locking the diff. |
And you control torque by holding it at2500 rpm and slipping the clutch
No,thanks. _________________ .ssS! |
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Mon Nov 19, 2018 6:16 am Post subject: Re: Overlanding a VW Bus Around The World?! |
richparker wrote: |
Why are you concerned about the weight of the winch? IMO they don’t weigh much and having one is better then not having one. As stated above, install it behind the bumper, cut a hole in the bumper and run the cable through. Seen it done, there is a guy in Cortez who has with this set up. Clean and reliable. |
The one we have is pretty heavy, I think it was the heaviest thing in our bus. That's probably due to the cable, which I might replace. Mounting behind the bumper out of sight would be very cool. Seen it done on many an overlander but not a bus. is there space for a winch behind the front bumper?
Xevin I'm hoping I don't need to use the winch that often and you are right I made it all that way and probably only needed it 5 times in 5 years, and I always found a way out without it...eventually _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
Posted: Mon Nov 19, 2018 6:25 am Post subject: Re: Overlanding a VW Bus Around The World?! |
https://us.maxtrax.com.au _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Nov 19, 2018 8:10 am Post subject: Re: Overlanding a VW Bus Around The World?! |
https://www.google.com/search?source=hp&ei=H9L...dH27q4DYs4
An alternative to have a winch on the front of your vehicle. Lighter, simpler, and much cheaper. Just throwing it out there. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
CarlosZ Samba Member
Joined: April 23, 2016 Posts: 319 Location: Los Angeles
Posted: Mon Nov 19, 2018 9:18 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Assume that almost everything hanging outside the bus will eventually be stolen. Take what you can carry inside or afford to lose by theft (hoping to use at some point before being stolen). Anything fluorescent will attract more unwanted attention. |
Xevin Samba Member
Posted: Mon Nov 19, 2018 10:58 am Post subject: Re: Overlanding a VW Bus Around The World?! |
Ben, Just a tip when driving on soft ground off road. Modern off road guys will often drop tire pressure to 15 PSI. Not sure what appropriate PSI deflation would be for a bus. I’ve only had to drop it to 20psi. That’s when the little air compressor comes in handy. Plus should you get multiple tires with leaks. Or get a flat tire in a spot to soft to jack up bus. You would have air on demand to possibly help you get out of there. Just a thought. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Mon Nov 19, 2018 1:57 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
I air down to about 22 psi on dirt roads and wash board, lower for sand or off road conditions in a 4x4 vehicle. In the winter I run studded tires and 30 psi. If I am still slipping around or it is especially sketchy, I will go down to the mid 20's. Lower tire pressure equals larger tire contact patch for traction. Tire deflators are an easy and accurate way to deflate. Terrawagen sells them.
https://www.terrawagen.com/products/terrawagen-ez-deflator
Also I carry a plug kit it the car, they are pretty cheap and I have one in each car. For a Bus tire, you can pump it back up with a bicycle pump. Good exercise too. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
Posted: Mon Nov 19, 2018 3:49 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
yep I have an onboard compressor for that purpose waiting to be installed. It's a good suggestion.
I also would like to purchase one of those deflators as shown in that video (thanks for posting that), but to be honest that one looks a little clumsy. I've have nothing to compare it to though...EDIT - a quick search showed that was pretty typical.l? It would be good to be able to connect the compressor to the same device so you can have the same benefit of the gauge when airing up too
Ever seen something like that? _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Nov 19, 2018 4:01 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
HastaAlaska wrote: |
Ever seen something like that? |
Not sure it would be practical for your trip with charging batteries and such (unless maybe you had other tools that used the batteries and bought the car charger), but I have a Ryobi tire inflater that you hook up the pump to the tire, then set the desired PSI and it turns off when it hits that.
Or hopefully it gives you an idea of something similar to find.
https://www.amazon.com/Ryobi-P731-Function-Inflato...0811110475 _________________ Dave Cook
1973 Wild Westerner
My Thing |
honestcharlie56 Samba Member
Joined: September 24, 2017 Posts: 87 Location: Houston, Tx
Posted: Mon Nov 19, 2018 5:47 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
TDCTDI wrote: |
These don’t work very well on a vehicle with an open differential. |
Well, you can put them on the wheel that doesn't have traction. Or you can ride the brake a little bit to push power to both wheels. I get it, its not a high dollar setup that can handle any situation. That being said, its a pretty simple and reliable setup. |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Wed Nov 21, 2018 2:33 am Post subject: Re: Overlanding a VW Bus Around The World?! |
I think you're looking for something like this.
https://smile.amazon.com/AstroAI-ATG250-Compressor-Accessories-Resolution/dp/B07528LFCT/
As to your winch question... I think this is your winner.
Manfred58sc wrote: |
How about a good $50 come-along, a mess of straps, and 4 foot section of heavy rebar as a dead man. Mechanical systems don't rely on running engines and operating electrical systems. A section of chain with 2 binders ( to "walk the dog" ), just in case your hopelessly stuck. Plus nobody is likely to steal it. |
simple, compact, multi use
isn't that some sort of overlander trifecta?
There are also winch mounts that go into hitch receivers. Then you could store it on top if you wanted it out of the way/sight when not in use. Metal cables are also very heavy. If you don't need the larger load rating, go to a kevlar cord instead. _________________ ~Kevin
My 1968 Campmobile |
Posted: Tue Nov 27, 2018 6:11 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
That's exactly what I was thinking, thanks very much! |
I should have got you some "draw tape" when you were here- It's used by the power company to feed big wire thru conduit and can handle 1800 #-- also its soaked in silicone oil - so it will slide easily- Usually comes in big length -very compact- good for tying down tarps and shades- you do need to knot the ends or they pull thru any knot. _________________ some days I get up and just sit and think. Some days I just sit.
Zonkey Samba Member
Joined: November 01, 2018 Posts: 21 Location: Elko, NV
Posted: Fri Nov 30, 2018 3:07 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Ben
I just got an 1970 Adventurecamper not too long ago and I love your videos, thank you for making them! As far as getting unstuck, have you ever seen these things? Lightweight, probably won't get stolen, pretty cheap. I'll try and put a link here...
Good luck and can't wait to see the next series! _________________ =================================
1970 Adventurewagon |
Posted: Sun Dec 02, 2018 4:22 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
That looks like a lightweight solution and the video is promising. But 30% 1 star reviews on Amazon doesn't tell a good story
Speaking of good stories. We've been working hard at documenting the whole process of finding and building our bus for our new series.
I think I will post it in a different dedicated thread so people can enjoy the series.
Here is a little tease from one of the scenes that we filmed during the search:
If you haven't watched our previous series I just put together a mini series of 3 short videos which will allow you to catch up about 6 years of the story so far.
https://www.youtube.com/watch?v=nIr7PqvbUUk&list=PL3-CFitnEZXpNBszDyTENz8Wpjd1hEOxd _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
VOLTWAGEN Samba Member
Joined: May 24, 2014 Posts: 118 Location: Perth, Australia
Posted: Tue Jan 08, 2019 5:19 pm Post subject: Re: Overlanding a VW Bus Around The World?! |
Hikelite wrote: |
There are also winch mounts that go into hitch receivers. Then you could store it on top if you wanted it out of the way/sight when not in use. Metal cables are also very heavy. If you don't need the larger load rating, go to a kevlar cord instead. |
Forget Kevlar rope, it's a bit 80's now, it snaps without warning and doesn't like to be bent and needs an outer cover on it, go for bare Dyneema, the UV and wear rating has improved over the years, it's very light and very easy to splice, can also put a wear jacket on the main wear points to make it last even longer. |
