Urchinn Samba Member
Posted: Sun Jun 15, 2014 5:55 pm Post subject: Hood keeps popping open! |
Okay...new cable, hood mechanism is oiled and working, but everytime I hit a bump the hood pops open? WTF (what the fudgesickles)? Any clues? I can't seem to correct this. In an unrelated topic....here is my dog enjoying a ride in Gloucestor, Mass. https://vimeo.com/98288122 |
kubelmann Samba Member
Posted: Sun Jun 15, 2014 6:13 pm Post subject: |
Two separate possible fixes for this:
1. Lengthen the latch rod ( loosen the lock nut, screw out the latch bolt, tighten lock net
2. screw in the rubber tension bumpers to give more slack and allow complete latching.
Both of these will allow the latch to complete its job. Then the adjustment might need to be reversed os tha the hood does not rattle as you “rollin’ on down the road... |
Posted: Sun Jun 15, 2014 6:16 pm Post subject: |
Thanks, Kubelman...I'll be on it in the morning! |
Posted: Sun Jun 15, 2014 7:11 pm Post subject: |
If you have any issues post again and I will add pictures, Extreme Sport Latch Adjusting is one of my long-time passsssssions. |
ratpanel61 Samba Member
Joined: November 04, 2003 Posts: 345 Location: Va Beach, VA
Posted: Mon Jun 16, 2014 7:56 am Post subject: |
How convient! Mine is doing the exact same thing. It's about to drive me nuts too. It's like every time I stop somewhere I have to check it and re-latch it. now I know what I can try after work today. _________________ - '57 Sunroof Beetle (project)
- '73 THING |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Mon Jun 16, 2014 8:41 am Post subject: |
With mine I have to push down on the hood to get it latched-I can't just slam it shut. |
Posted: Mon Jun 16, 2014 9:01 am Post subject: |
If you screw in your rubber tension bumpers. This creates enough free-play to fully latch the hood latch post. |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Tue Jun 17, 2014 1:38 pm Post subject: |
Great point. Herr Kubelmann had the same issue with the handle getting stopped by the locking bracket tab. If you have the correct tension to the latch cable and the tab is straight and aligned with th bracket and it is properly lubricated. Not to mention getting the nylon shearing adjusted or even worse if your has the end crumble off so you are unaware that the collar on the tube is still another magical, mystery of the Thing hood latch engineering challenge. I have want to remove the entire mess and replace it with one of tow latches. the through the hood latches with the barrel key. offloading dzus fast lead captive screws, pin and clip latches or the best for last side mounting, rubber latches with metal brackets like atvs have or even military jeep hood latches. Anything is simpler to adjust and easier to open than the mess of an assembly VW created. HA!! |
wojo12 Samba Member
Joined: April 30, 2016 Posts: 9 Location: Bundaberg, Australia
Posted: Tue Aug 23, 2016 1:26 pm Post subject: Re: Hood keeps popping open! |
I wish to replace both parts of the hood latch and then try to tune it to stay down. The top part of the latch on my Thing has been welded and so I am unsure what it should be. I have found a source for the bottom part, but where can I buy the top part? |
cat1pro Samba Member
Joined: December 05, 2014 Posts: 91 Location: Florida
Posted: Wed Aug 24, 2016 9:08 am Post subject: Re: Hood keeps popping open! |
My hood opened doing 65mph on the highway....very bad sunday but everyone was safe and sound....thanks for the tips |
