ldj1002 Samba Member
Posted: Tue Aug 23, 2016 11:31 am Post subject: Gas heater |
I read that if engine stalled and died heater would quit. I also read not to run heater without engine running for long because it would discharge battery. OK, if heater quits when engine stalls then how can I run heater with engine not running? Am I not understanding because am I miss reading? |
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Tue Aug 23, 2016 11:54 am Post subject: Re: Gas heater |
Gas heater (Eberspaecher BN4) as equipped on a Type 181 will operate independent of the engine. If the heater switch is in the first position (past full off), it will come on when the ignition is swiched on. If the switch is rotated past the first position (past full off), a mechanical timer is activated and the heater will run without the ignition on. The timer will theoretically shut down the heater before you run down the battery (assuming the timer works properly, and your battery is in good shape, and you do not re-activate the timer too many times without re-starting the engine to charge the battery).
These heaters are known as stationary heaters and were meant to supply heat without the engine running. _________________ Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket |
Posted: Tue Aug 23, 2016 12:13 pm Post subject: Re: Gas heater |
tallman206 wrote: |
These heaters are known as stationary heaters and were meant to supply heat without the engine running. |
Thanks. I am trying to start my heater and it won't start. I am getting fuel up to the inlet by the igniter. The igniter is sparking. I have pulled the heat knob out. I have turned the switch full clockwise. The ignition switch is on. When I pull the hose off the inlet by the igniter smoke comes out so there bound to be something going on. How can I tell if it is working? I feel the air coming out and it isn't hot. Does it make a noise when it is working (burning). I don't know what to check now. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Tue Aug 23, 2016 3:38 pm Post subject: Re: Gas heater |
I read that and don't really understand, maybe read again tonight. Any way update. I thought maybe I wasn't getting fuel in there and the little smoke was from residue. I squirted a little fuel in to try it. I turned switch on and it went boom, not real loud like a explosion but definitely a boom. Pretty sure it was running because whole unit got pretty warm maybe a little hot and then it shut down after, oh, maybe 15 seconds. I thought that the little breaker on back had tripped. It hadn't. I blew the fuse in the fuse panel. I put another in and it blew it right away. That is where I am now. Oh BTW I checked thermostat switch, the one you pull on the dash. It doesn't look anything like the one in the pictures I see here. Instead of being spiral it is a coil spring and it works. Any ideas? |
Posted: Wed Aug 24, 2016 8:50 am Post subject: Re: Gas heater |
Went out this morning thinking that heater intake or exhaust might be stopped up. The little short one close to the end of heater that connects to flexible hose T's off and one side goes under fender well. The other one goes into a empty space you can't get access to. I started looking under dash and found this (photos). What would this be?
KAmes Samba Member
Joined: February 16, 2014 Posts: 877 Location: Illinois
Posted: Wed Aug 24, 2016 6:32 pm Post subject: Re: Gas heater |
That is where air is drawn in to be heated and returned to the cabin. The hose into the fender well is the intake for combustion. I don't know what the T into the empty space is for, maybe to drain off water splashed or sucked into the intake? |
Posted: Wed Aug 24, 2016 7:57 pm Post subject: Re: Gas heater |
KAmes wrote: |
Thanks very much.
Now the heater apparently has 1 blower. How does that 1 blower blow air for combustion and exhaust and draw and blow heated air in the car? |
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Wed Aug 24, 2016 9:09 pm Post subject: Re: Gas heater |
ldj1002 wrote: |
The link below is to a BN-4 installation manual from The Samba, it goes into great detail about the unit, to include diagrams of the unit and how gasoline is used to create heat . . .
http://www.thesamba.com/vw/archives/manuals/bn4ins...ctions.pdf |
