Shortened Clutch Cable
Page: Previous  1, 2
Bermoco
Bermoco is offline
PostPosted: Sun Aug 28, 2016 8:29 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
All are great ideas and posts. Here is another: West Marine supply sells stuff to make cables and also lets you crimp your own. I went to West Marine boating supply and took a VW clutch cable , cut it 14 1/2 inches shorter at the end that hooks on to the pedal assembly and used the thimbles for cables they supply and swaged the cable around the thimble with the crimp they sell. Seems to work OK for over a year now. I used the West Marine route because I found the common cable shortening devices had too much flex and had too much play which did not release clutch fully. I like how it looks stock.
I carry a spare stock cable and will use Dales technique if mine breaks.
The pictures you see of buggies without Bowden tube probably have solid trans/motor mounts.
Bart
Goshen
Goshen is offline
PostPosted: Sun Aug 28, 2016 9:26 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Bart
Post photos so we can see what you are talking about
My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870
JiI
JiI is offline
PostPosted: Tue Oct 25, 2016 5:28 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Hey guys, here are the parts at HF I saw today.
Jeff
MrGoodtunes
MrGoodtunes is offline
PostPosted: Wed Jan 10, 2018 11:58 am    Post subject: Re: Shortened Clutch Cable Reply with quote
MrGoodtunes wrote:
tgodber wrote:
...I used the shortener that bends the cable over and a nut tightens up against it. That broke in 3 months...
Me too. Mine broke while in the parking lot of Lowe's home improvement store. So I had a store full of things like threaded rod, long nuts, and good strong but also flexible garage door opener cable. Did the fix right there in the parking lot. That was 1999 and this rig is still holding today.
Well, that rig finally broke. And again, it happen'd in a parking lot where I fix'd it with an upgraded rig. Not as elegant as what @saw2 came up with (earlier in this thread), but probably will last. Used an eye bolt this time, along with the smooth end loop guide that came with the little cable clamps, completely doing away with all parts of the old cable shortening kit:
veeweeman
veeweeman is offline
PostPosted: Wed Jan 10, 2018 2:19 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Very cool idea. ..I'm surprised that the VW industry hasn't thought of this yet...very clean finished look. ..when they do...expect to pay like $20 for it Laughing Laughing Laughing Laughing
Thanks for the tip.
cbeck
cbeck is offline
PostPosted: Fri Jan 12, 2018 4:32 am    Post subject: Re: Shortened Clutch Cable Reply with quote
Looks like somebody raided the bins on my company truck. Here is another tip, never saddle a dead horse, er cable. The saddle should ride on the working side of the cable and the u bolt should be on the other side. The u bolt will crush, deform, and slightly unravel the cable when tightened. You don't want that to happen on the working side of the cable.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
joescoolcustoms
joescoolcustoms is offline
PostPosted: Fri Jan 12, 2018 7:57 am    Post subject: Re: Shortened Clutch Cable Reply with quote
I am at 50,000 + miles on this set up. Same cable, same clamps, same wing nut. 2 different transaxle configurations. I do silver solder the ends of the cable so they do not frey and the silver gives the clamps something to "bite" into and not slip. This same set up will get driven across the US again and race the April NORRA 1000 this year.
I still carry a spare cable everywhere I go.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
rodjr
rodjr is offline
PostPosted: Mon Jan 22, 2018 7:10 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
I just sent a factory clutch cable to California Push Pull, they shortened it proper with a new hook end. The end is a tiny bit different and required that i sand about 1/8" off the end (which has plenty of meat on it), took about 10 seconds with a disc sander.
They also made me a spare from scratch (cost a fraction more), but it's cheaper to just have them shorten a new cable.
Other than the tiny trim job i did to the end, it is absolutely a new cable in every way, exactly the right length, strong as the original and they charged me a whopping $20.00 plus shipping.
I can't imagine screwing around with clamps and loops or searching for ends when $20 will get you a perfect new custom cable, while you work on something else.
Now that i have seen what a nice job they do, my emergency brake cables are going to them as well.
http://push-pull.com/
markdam
markdam is offline
PostPosted: Mon Oct 29, 2018 1:30 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
did you happen to measure the new shortened cable length? did you tell push pull how much to cut?
joescoolcustoms
PostPosted: Mon Oct 29, 2018 4:09 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Update. Cable now has over 62,000 miles and the NORRA race on it. Do have to state that I use the Classic Bug Parts front Big Foot extender with he bushed roller tip to help save the front stock loop.
mr_bill
mr_bill is offline
PostPosted: Mon Oct 29, 2018 5:20 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
will make "custom-length" to YOUR specs....have clutch & throttle cables from Push-Pull on my "OldManx" & my "tunnell-buggy" resto-mod Quite reasonably priced & QUICK tour around
sent them THIS pic.........less than a week (2) cables showed-up 2 my door (one is a "spare")
I ALWAYS prefer a "stock" type set-up.. Rolling Eyes Rolling Eyes
see ya' on the trail........
"Mr Bill" "OldManx"
Dos Perros Motorsports
Orange, CA
Class 11/Stock Bug
"Original, Survivor" 1965 Meyers Manx
'60's era "vintage" Tunnell-Buggy
"...WE all...BOZO'S on this bus..."
Motor = electric
Engine = internal combustion
www.class11coalition.com
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
rodjr
rodjr is offline
PostPosted: Mon Oct 29, 2018 6:06 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
I shortened my 1972 beetle chassis 14 5/8", I purchased a 1972 beetle clutch cable and sent it to push/pull with a note that said "shorten 14 5/8" over all, and make one more cable to match".
They returned them and they fit absolutely perfect. Under $40 for both plus shipping.
markdam
markdam is offline
PostPosted: Mon Oct 29, 2018 6:43 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Awesome I guess I asking if they're all not more or less the same on a shorten buggy chassis. Or do I have to actually measure mine
Q-Dog
Q-Dog is offline
PostPosted: Tue Oct 30, 2018 5:29 am    Post subject: Re: Shortened Clutch Cable Reply with quote
You have to measure. VW used different lengths of cable over the years. Plus, some buggies don't get shortened the same amount. Add that together and you need to measure to be sure.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
markdam
markdam is offline
PostPosted: Tue Oct 30, 2018 7:18 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Is there a way to measure it with the pedal assembly already removed and sent off to be rebuilt all I have is the hole in the tunnel
MrGoodtunes
PostPosted: Wed Oct 31, 2018 1:15 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
Measure your wheel base @Markdam, axle-to-axle (center of front wheel to center of rear, with steering wheel straight ahead center'd). It's probably 80 inches. If so, you can go with the standard dune buggy cable length, which is ~14.5 inches shorter than stock VW cable.
EVfun
EVfun is offline
PostPosted: Wed Oct 31, 2018 4:43 pm    Post subject: Re: Shortened Clutch Cable Reply with quote
I used a "ground split bolt" easily found with a google search and readily available at your local hardware store. The clutch cable was cut and both ends passed through the split. I can adjust the length and then tighten it down. I installes a second one about an inch behind the first for extra security. It worked for 10 years, the cable doesn't see extra stress because it isn't bent or folded over.
Wildthings wrote:
Page: Previous  1, 2
Page 2 of 2
