Sift Shaft Seal or Main Shaft Seal?
BayCreamPuff
BayCreamPuff is offline
PostPosted: Sun Aug 28, 2016 5:52 pm    Post subject: Sift Shaft Seal or Main Shaft Seal? Reply with quote
What seal goes here? Also any secret in removing this seal with the transmission in place? I had to dig it out with a scalpel and pliers.
I bought this one, but having a hard time getting it in.
http://www.autohausaz.com/pn/001301227
Is this the one I should have bought?
http://www.autohausaz.com/pn/113311113A
Thanks!
Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
old DKP driver
old DKP driver is offline
PostPosted: Sun Aug 28, 2016 6:04 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Is this from your 79 091 trans?
Your bushing is damaged which is also the seal holder
Bushing # 001 301 209
Seal # 001 301 227
V.W.owner since 1967
SGKent Premium Member
SGKent is offline
PostPosted: Sun Aug 28, 2016 6:19 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
the 091 uses just a rubber seal. The sealing area on your nosecone is damaged. The proper repair is to remove the transmission and engine, then the transmission nosecone and replace it with an undamaged one. The redneck repair is to file the damaged burrs away with s small file, insert the new seal and fill the gouges with RTV.
seal: http://weddleindustries.com/products/1000199/1000701
nosecone: may be hard to find one. This one is pre-machined for the steel plate that helps when the nosecone wears (they all do)
http://weddleindustries.com/products/1000287/1001958
Steel thrust plate:
http://weddleindustries.com/products/1000292/1002215
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
old DKP driver
PostPosted: Sun Aug 28, 2016 6:35 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
That's why i asked if it was an 091 since it appears in the picture that
there is brass around the lip where the seal was pried out
75 was the last year for the 001 301 209 bushing/seal holder
BayCreamPuff
PostPosted: Sun Aug 28, 2016 7:15 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Thanks for the suggestions.
This is for the 091 on my 79. It was already chewed up and leaking, so if possible I'd like to just put the new seal in and deal with the engine drop / nose cone replacement another day.
Problem is I can't get the new seal in. Can you tell from this photo if I've gotten it all out? It looks like there's an inner ring or is that part of the old seal?
Cream Puff
Earl Grey
Marsha Mellow
BayCreamPuff
PostPosted: Sun Aug 28, 2016 7:17 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
I believe I have the correct seal
Cream Puff
Earl Grey
Marsha Mellow
old DKP driver
PostPosted: Sun Aug 28, 2016 10:14 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Yes you have the correct seal but, you really need to try to clean up the
damage 1st. Enough to remove some of the inner damage.
maybe using a small Sharp knife or a razor blade and some sealant when
installing the seal.
And recheck your fluid level when finished.and until you can repair it properly.
SGKent is offline
PostPosted: Mon Aug 29, 2016 7:24 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
special bearings, they are supposed to be there. What Old DKP Driver said is the only way you will do this in the car. The blue seal your link goes to has a steel ring. It may be less compressible that the factory seal with the rubber outside. Either way you have to fix the damage without causing new damage.
BayCreamPuff
PostPosted: Mon Aug 29, 2016 9:34 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Awesome, thanks again! I'll definitely get some sealant in there when I figure out how to get this new seal in.
The seal I have is rubber all around like the original (see my photo above).
Does that bearing move at all? I can't see how the seal will be able to fully seat with that bearing in place.
I'm wondering if I may have just scraped off the rubber part of the old seal leaving behind whatever is inside the seal. Is it metal inside? Could that inner ring possibly be the remains of the seal?
Ratwell's photo
Mine won't go any further than this
Cream Puff
Earl Grey
Marsha Mellow
SGKent is offline
PostPosted: Mon Aug 29, 2016 9:53 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
the seal are appears to be bent from being dropped. that is probably what you are fighting.
again - I believe this is the part you are seeing as a steel lip: http://weddleindustries.com/products/1000175/1001750
BayCreamPuff
PostPosted: Mon Aug 29, 2016 10:41 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Okay. One more question Smile
Is the lip of that bearing meant to fit in the slot in the rubber seal? Or does the seal just sit flush up against it?
Doesn't seem like there's enough room in there for the seal to just sit flush up against it.
Cream Puff
Earl Grey
Marsha Mellow
SGKent is offline
PostPosted: Mon Aug 29, 2016 10:48 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
take a depth measurement and compare it to the seal. Mine sits flush with the exterior. I believe you are fighting a damaged seal race. You may need to clean that up first.
here is an old one someone gave me.
BayCreamPuff
PostPosted: Mon Aug 29, 2016 11:46 am    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Thanks for that picture. I've been looking for a shot just like that. Very helpful.
Took a measurement and there's definitely not enough room for the seal.
Took a flash photo with my phone and it looks like you can see the bearing behind this ring. I'm now convinced this is the skeleton of my dead seal.
Cream Puff
Earl Grey
Marsha Mellow
Tcash
Tcash is offline
PostPosted: Mon Aug 29, 2016 1:22 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
You have not gotten all the seal out. The seal is a metal collar that is encased in rubber.
That is the metal collar in front of the bearing that you can see that has the (K) on it.
This is the arrangement
thnx to mayor ratwell
seal https://weddleindustries.com/products/1000199/1000701
bearing https://weddleindustries.com/product/1001750
You should be able to pry it out with a flat blade screwdriver on its side. Put a piece of metal or rags against the aluminium so you do not damage it anymore.
You can use a paint can opener as well.
Good luck
Tcash
BayCreamPuff
PostPosted: Mon Aug 29, 2016 2:02 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
Thanks Tcash!
I'll try to paint can opener. If that doesn't work may try one of these.
https://www.amazon.com/Lisle-58430-Shaft-Type-Puller/dp/B000FPYW4K
Cream Puff
Earl Grey
Marsha Mellow
BayCreamPuff
PostPosted: Mon Aug 29, 2016 5:33 pm    Post subject: Re: Sift Shaft Seal or Main Shaft Seal? Reply with quote
I was able to get it out with the tool I linked to above. That thing is magical.
New seal went in (with a bit of a fight due to the bent opening).
I was then able to do what I actually set out to do which is replace the bent shift coupler and torn, incorrect front bushing.
I didn't know shifting could be so smooth on a bus.
Thanks for all your help!
Cream Puff
Earl Grey
Marsha Mellow
