Rocky Mountain Westy Samba Member
Joined: April 17, 2008 Posts: 1031 Location: Fort Collins Colorado
Stephenmarklay Samba Member
Posted: Mon Aug 29, 2016 9:59 am Post subject: Re: Exhaust support welding? |
Ahwahnee wrote: |
If it is the support itself that broke... I have made replacements for missing supports from electrical conduit flattened at each end and painted black.
Have lasted for years and would require close scrutiny to tell they are not original. |
Very cool. I like this fix. Yes mine is an upper one however. _________________ 1985 Westfalia. Project 2017. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Mon Aug 29, 2016 8:02 am Post subject: Re: Exhaust support welding? |
Posted: Mon Aug 29, 2016 7:23 am Post subject: Re: Exhaust support welding? |
Stephenmarklay wrote: |
Thank you Wildthings. Can you give me any more info? That sounds like a good thing! |
Basically you are only wanting to attach the support arms at their ends so there are no bending moments on them. If one arm attaches to another somewhere besides at its end then that will cause the arm to flex and potentially break. My system never lent itself well to taking pictures, but I will look and see what other pictures I can find. |
Posted: Mon Aug 29, 2016 4:20 am Post subject: Re: Exhaust support welding? |
Thank you Wildthings. Can you give me any more info? That sounds like a good thing! _________________ 1985 Westfalia. Project 2017. |
Posted: Sun Aug 28, 2016 10:01 pm Post subject: Re: Exhaust support welding? |
I altered the arms on my 83 1/2 so that the arms were either in tension or compression with no or very minor bending moments. Never had a problem with the arms breaking again.
Terry Kay Banned
Posted: Sun Aug 28, 2016 8:47 pm Post subject: Re: Exhaust support welding? |
If they have a welder--why not?
Ask them first. _________________ T.K. |
Posted: Sun Aug 28, 2016 8:01 pm Post subject: Exhaust support welding? |
Draining my coolant I noticed that one for he exhaust supports snapped up at the flange bolted at the block. Can a muffler shop weld likely weld that back? _________________ 1985 Westfalia. Project 2017. |
