TheDangerZone Samba Member
Posted: Mon Aug 29, 2016 9:10 am Post subject: Testing Monitor Panel? |
The monitor panel in my '95 EVC stopped working after I replaced the reigniter on the fridge. The water pump still works, and it appears that the power for the monitor comes off of that switch. Any idea how to test if the problem lies within the PC board before I spend $50 on a new one? The wires are all firmly connected, the aux battery works fine. |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Tue Aug 30, 2016 6:01 am Post subject: Re: Testing Monitor Panel? |
Pretty sure that on a 95 the pump doesn't work off of that board. It just has a switch on the panel. Only the water level meter Connects to that panel
Either way, if your fuses are all in place and you're still not getting power to the board it's a 99% chance that it has died.
Likely you scratched the back of the light board when you were reinstalling that panel after doing your relighted board. I've done it a few times, and those light boards can be pretty fragile at this point in time in their life span. I scratched off one of the copper leads Doing exactly that on Saturday. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Posted: Tue Aug 30, 2016 10:00 am Post subject: Re: Testing Monitor Panel? |
Photos of my busted panel: that little broken copper lead shorted and blew when it rubbed against the bracket that holds that panel in place.
Posted: Wed Aug 31, 2016 10:10 am Post subject: Re: Testing Monitor Panel? |
After I saw your reply, I looked over the circuit board carefully. I pulled the wire connectors off the circuit board and noticed that under one of them there was what appeared to be a burn mark or something. I cleaned it off with some alcohol, reattached the connectors, and voila, it just works! |
Jrcooke2001 Samba Member
Joined: January 29, 2017 Posts: 1 Location: Seattle, WA
Posted: Sun Jan 29, 2017 4:32 pm Post subject: Re: Testing Monitor Panel? |
Wow, same thing happened to me. Just a few minutes with a soldering iron will save me $90. Thanks! |
caselhall Samba Member
Joined: August 08, 2018 Posts: 10 Location: Lakewood, WA
Posted: Sat Aug 11, 2018 10:06 pm Post subject: Re: Testing Monitor Panel? |
TheDangerZone wrote: |
Okay where do you find that circuit breaker board for sale? I need one and can’t find it anywhere on the interwebs. HELPPPPPPP!!!!! |
Posted: Sun Aug 12, 2018 12:45 pm Post subject: Re: Testing Monitor Panel? |
Hey danger, could tell me how you found that pc board for the monitor system? I’ve been on the internet for hours now and I can’t seem to find one and I even found the part # and still can’t pull anything up! Thanks Casey |
Dhurcomb Samba Member
Posted: Tue Mar 31, 2020 1:32 pm Post subject: Re: Testing Monitor Panel? |
I have a inoperative monitor panel circuit board that needs repair or replacement. it was likely shorted during refrigerator maintenance. Anybody have any info on service or sources for a 97 eurovan monitor panel board? |
Gar4ever Samba Member
Posted: Wed Feb 24, 2021 5:54 pm Post subject: Re: Testing Monitor Panel? |
I'm currently removing and replacing the control panel on our 1995 EVC. I'm updating the whole panel with a proper battery monitor (renogy) and really only need to keep tabs on the fresh water tank, add some USB chargers and a switch for the water pump. I'm hoping to just get a single (small) water level monitor, but does anyone know if I can hook up a single panel display if I source out the wires? or would I need to replace the actual tank level sensor too?
dazey77 Samba Member
Joined: May 11, 2020 Posts: 163 Location: Other side of the pond.
Posted: Thu Feb 25, 2021 5:05 am Post subject: Re: Testing Monitor Panel? |
Gar4ever wrote: |
Hi, I can answer this. The tanks do not have a level sensor, they have multiple water operated switches. You can't use a generic level sensor(unless you fit a new sensor).
I redid my panel, I have a seperate battery monitor so I didn't need this. I did just keep the old test panel behind the plate but only cut LED holes for the tanks as thats all I needed. Fitted a better LPG meter using the existing sensor.
You can see my plate at the below link:
http://www.dazedproductions.co.uk/Vanity/uncategorized/another-eurovan-new-switch-plate/ _________________ My van modification blog:
www.dazedproductions.co.uk/Vanity |
Elcapytan Samba Member
Joined: October 05, 2021 Posts: 1 Location: Washington
Posted: Thu Oct 14, 2021 5:42 am Post subject: Re: Testing Monitor Panel? |
I’m still looking for a circuit board. Any leads on who has them?
Who works on them? Or if I can even find them anymore? |
