campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Sat Apr 17, 2021 4:06 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
I'd suggest leaving the old pedal pad in place to grant more "Rocket Box cred." Onlookers will know you're a serious boxer and in no way a noob when they see you plant your muddy boots on a pad with some obvious miles on it. _________________ '87 Westy in Wolfram Grey Metallic |
TurtsMcSlow Samba Member
Joined: August 07, 2015 Posts: 78 Location: Derby City, Cantuckee
Posted: Sat Apr 17, 2021 8:43 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
Um, is this something that you are going to be selling? |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Apr 17, 2021 9:22 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
TurtsMcSlow wrote: |
Took the words right out of my mouth! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Last edited by Jake de Villiers on Sat Apr 17, 2021 9:43 am; edited 1 time in total |
jimf909 Samba Member
Posted: Sat Apr 17, 2021 9:33 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
campism wrote: |
I'd suggest leaving the old pedal pad in place to grant more "Rocket Box cred." Onlookers will know you're a serious boxer and in no way a noob when they see you plant your muddy boots on a pad with some obvious miles on it. |
Look at the wear on that step. That dude is so OG I'll bet he calls a hashtag a pound sign. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Sat Apr 17, 2021 9:48 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
I’m all about street cred.
And thats the clutch pad which I mistakenly chose’cuz it was less worn.
I might have to switch it back to the brake pad which had more “cred”.
Incidentally this brake pedal came from the “Vanabolt”. 🤣🤣 _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat Apr 17, 2021 2:30 pm Post subject: Re: Made a step to access rocketbox (with slider door open) |
Sodo wrote: |
Incidentally this brake pedal came from the “Vanabolt”. 🤣🤣 |
Street cred AND unique provenance. Cool. _________________ - Jim
Abscate wrote: |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 501 Location: Hi-top Country
Posted: Sat Apr 17, 2021 3:11 pm Post subject: Re: Made a step to access rocketbox (with slider door open) |
I like the latest rev. For some reason having a pedal floating midship doesn't raise any questions for me, lol! Any issue with the screws loosening up over time? I suppose Riv-nuts could always be added down the road to remedy that. _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Sodo Samba Member
Posted: Sat Apr 17, 2021 8:37 pm Post subject: Re: Made a step to access rocketbox (with slider door open) |
I used M8 riv nuts.
I had to re-weld the pedal to square it up.
Washers the thickness of the door card.
Otherwise it would pull the rivnuts out.
Its really stable, it doesn't move at all.
I don't think it will come loose. _________________
Posted: Sat Apr 17, 2021 9:47 pm Post subject: Re: Made a step to access rocketbox (with slider door open) |
I must have missed when you switched from sheetmetal screws to M8's. Lining up riv-nuts with countersunk hardware is always a fun endeavour. Well done! _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Sodo Samba Member
Posted: Sun Apr 18, 2021 8:01 am Post subject: Re: Made a step to access rocketbox (with slider door open) |
uberaudi wrote: |
I must have missed when you switched from sheetmetal screws to M8's. Lining up riv-nuts with countersunk hardware is always a fun endeavour. Well done! |
I used 1/8 pilots with a rotabroach holecutter, it was dicey.
And luckily the rivnuts came down at center.
Ideally this would have a triangular 3-holer nutplate with an "extension handle" maneuvered from the ashtray hole. _________________
