67ctbug Samba Member
Posted: Thu Sep 01, 2016 4:06 pm Post subject: What To Do About That Rust |
There's some rust around the washer bottle area. It looks a little major and I don't know what to do about it.
Also there's some on the apron. That I can get from Wolfsbürg west.
And on a side note I fixed this with a panel I got from another member.
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
grandpa pete Samba Member
EVfun Samba Member
Posted: Thu Sep 01, 2016 6:08 pm Post subject: Re: What To Do About That Rust |
When it comes to local rust that is not compromising the integrity of the car you have a couple good choices. You can repair the area and bring it back to good condition. If you choose that route hopefully you find someone who can do it properly. The other choice to to remove the corrosion and repaint what is left to stop the progress.
You can just leave it too, the "patina look," but unless you keep the car dry it will continue to progress. Enough rust there could compromise the front body support. _________________
Wildthings wrote: |
carcrazed Samba Member
Posted: Sun Sep 04, 2016 7:19 am Post subject: Re: What To Do About That Rust |
I would poke around and get the all the rot out, then cut it out and weld a new piece in. Won't have to worry about it anymore. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Sun Sep 04, 2016 7:00 pm Post subject: Re: What To Do About That Rust |
Drill out the spot welds, if you can find them?
sand/blast/kill all the rust, and replace with new steel.
_________________ If you can't join them, beat them! |
Posted: Sun Sep 04, 2016 7:18 pm Post subject: Re: What To Do About That Rust |
Did you fabricate that piece? If you didn't, where'd you get it from? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Tue Sep 06, 2016 12:12 pm Post subject: Re: What To Do About That Rust |
I'll look for donor metal, that stamping doesn't look very good. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Fri Nov 18, 2016 2:49 pm Post subject: Re: What To Do About That Rust |
Oh boy, here we go again... here's some more I found after undoing some fiberglass and undercoating
It's really as bad if not worse as it looks...
The hole at the left of the picture goes through into the interior _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
Posted: Fri Nov 18, 2016 5:27 pm Post subject: Re: What To Do About That Rust |
67ctbug wrote: |
The hole at the left of the picture goes through into the interior |
yikes!!! at this point dont do any more repairs until you have inspected everything for rust, then you need to decide if the car is worth fixing or not. you need to head into rust repairs with eyes wide open, this could be big can o worms.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Nov 18, 2016 5:44 pm Post subject: Re: What To Do About That Rust |
The car is definitely worth fixing! This is the only majorly bad area on the car... I've inspected the other side. It wouldn't of been this bad if it wasn't for a PO with a can of undercoating and fiberglass . Tomorrow I'll inspect some more... how would I go about fixing this? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
Posted: Fri Nov 18, 2016 6:50 pm Post subject: Re: What To Do About That Rust |
67ctbug wrote: |
The car is definitely worth fixing! This is the only majorly bad area on the car... I've inspected the other side. It wouldn't of been this bad if it wasn't for a PO with a can of undercoating and fiberglass . Tomorrow I'll inspect some more... how would I go about fixing this? |
finding a donor car would be the way for the easist fix I think maybe some one makes a repro panel? id hate to make lots of little patches, lot of work for that. I commend your pashion to get her fixed. good luck!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Nov 18, 2016 7:05 pm Post subject: Re: What To Do About That Rust |
I'll look for some patches or a donor, and thanks! I really love this car, being my first ACVW and being a rarer model. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
bluebus86 Banned
bluebus86 Banned
Posted: Fri Nov 18, 2016 7:30 pm Post subject: Re: What To Do About That Rust |
The last one looks best for me, but it's in California... I'd rather something local. Maybe I'll call up the CTVWA tomorrow and see if any members have what I need. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Nov 19, 2016 10:14 am Post subject: Re: What To Do About That Rust |
No one has used them? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
bluebus86 Banned
Posted: Sat Nov 19, 2016 1:27 pm Post subject: Re: What To Do About That Rust |
67ctbug wrote: |
No one has used them? |
try a whole new lost inquiring about the part quality, you mkght get more replies that way rather than tagging on your request to this older rust repair post.
good luck PS also do a seacrh on all the bug forums for quality advice from this company, I beleive they make parts for different year bugs, it someone with a newer bug has had good results wkth thismpart (or other parts they make) that would be a good indication that this part is likely good too
of course check out local wreckers for this part too, (used of course, but watch for rust!) and call the vendor and inquire on what thickness steel they use, you dont want this part to be really thin. and ask what the issues are with their warning about shock tower mount location needing modification. you dont want any surprises.
