ctroutma Samba Member
Joined: October 13, 2005 Posts: 158 Location: Atlanta, Ga
Posted: Sat Sep 03, 2016 11:40 am Post subject: Diagnostic - Engine Cranks But Won't Start - Solved |
First thing I did wrong was to let the bus sit for 6 months. It's always been a very strong starter though, and I am now at a loss for what to try next.
1965 6 volt. When I crank the engine, it turns over strong, but never catches. I went through the "Engine Won't Start" procedure in the Muir book twice, and just completed a full tune up, and still nothing. Replaced the fuel pump, and it's pumping fuel when I crank it.
What am I missing?
Thanks _________________ 1965 EZ Camper
Starbucket Samba Member
Posted: Sat Sep 03, 2016 12:23 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
make sure you got spark. pull a plug wire and connect an old sparkplug and have someone crank the motor while you ground the plug to a good ground. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Sep 03, 2016 12:42 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
A test light connected between the primary terminals of the coil is always a good place to start, does it light up when you turn on the key?, does it blink when you crank? stay on steady?, go dark? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Sep 03, 2016 12:50 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
I do have spark from spark plug wire to ground.
Lights up between terminals on coil at first click, blinks while cranking. _________________ 1965 EZ Camper |
Mos6502 Samba Member
Posted: Sat Sep 03, 2016 1:40 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Switched plug wires?
If you pull a plug is it wet with gas after cranking? |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Sat Sep 03, 2016 1:45 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Always check for fuel. The fuel pump could have gone dry then cracked in the diaphragm not allowing fuel to the carb. Is the bowl full? Check for fuel, spark, and spark in the right order. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
Posted: Sat Sep 03, 2016 2:07 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Fuel was checked first, filter is quarter full. Have not looked in carb yet. _________________ 1965 EZ Camper |
Posted: Sat Sep 03, 2016 2:09 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Plug wires are good. Only pulled one plug but it was dry and looked good. _________________ 1965 EZ Camper |
Posted: Sat Sep 03, 2016 2:16 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Try to pump about a pint in container to make sure the gas line from the tank hasn't gotten plugged and smell the gas as gas goes bad real quick if you didn't put gas stabilizer. If all else fails buy a can of sure start and spray some down the carb throat and crank it up, it will run for 30 sec.s on the sure start. Did you make sure all the carb plugs are in place and the electric cyl. on the carb clicks when the key is turned on. You know your bus will get mad at you if you let it sit so maybe washing and waxing it will make it happy and it will start. |
Posted: Sat Sep 03, 2016 2:18 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
The wash and wax may be best idea, I know there are hard feelings. I have wondered about needing to purge the fuel tank. _________________ 1965 EZ Camper |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Sep 03, 2016 2:28 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Starbucket wrote: |
I know it sounds kinda a silly but...
I have had my 60 Beetle too deep into the garage for the past 2 1/2 years. I recently installed a new battery and nothing, no lights no cranky no nothin. Gave it a wash and the next day it started... just sayin. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Fredrok Samba Member
Joined: July 06, 2014 Posts: 227 Location: Under the evergreens. CO
Posted: Sat Sep 03, 2016 9:37 pm Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
Look at Herbie. You think someone just made that shit up? |
Clara Samba Member
Posted: Sun Sep 04, 2016 7:43 am Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
pour a little gas down the carb and try again.
FWIW, I don't drive my 53 very often. It easily sits 6 months between being started up. I do turn the fuel tap to Zu (to/closed/off) when parking it, and let the carb run dry. Then to start it I turn the tap to Auf (from/open/on) and it has to pump gas into the carb before it starts, which gives it time to pump oil round the bearings before starting. If the battery is not dead, I count slowly to 20 while pressing the starter button, and that's about right.
A 65 doesn't have a fuel tap, but generally the gas disappears from the carb if sitting for months, often leaving behind a gooey deposit. So you will have to sit there slowly counting while the engine cranks over.
I have not washed it in years, and it starts.
If you have fuel in the carb, when you pull the accelerator arm, does it actually squirt fuel down the throat?
just dump a little gas in the carb(I use the top of a a rattle can to dump a couple spoonfuls in) and see if it starts. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Sep 08, 2016 8:25 am Post subject: Re: Diagnostic - Engine Cranks But Won't Start - at a loss |
FYI - it was the float valve in the carb - sprayed it with some carb cleaner and it fired up.
Thanks for the help - I did also give her a wash, so it was probably that _________________ 1965 EZ Camper |
