xavior12 Samba Member
Joined: September 25, 2006 Posts: 87 Location: Portland, Oregon
Posted: Sat Aug 08, 2020 12:35 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
Heater core huh?
I've done a few of them now, both '99-2000 and '01-'03. Not hard at all. I've always evacuated the A.C. to be able to remove the whole assembly. Be sure to loosen or remove the A pillar trim for the dash cover to clear other wise you'll brake the lower trim from dash. once the whole assembly is out, you can unfasten the clips and blow it clear and clean of trash and what not. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 10701 Location: Port Manteau
Posted: Wed Nov 04, 2020 2:09 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
Wow, it's been a while since I updated this thread. Well, I replaced the heater core, which was mostly uneventful. The van's been running great and has been on several camping trips with our local van group. I think I promised to post a pic of my updated dash setup a while back, so here goes:
That pod below the dash is a re-purposed rear heater vent cover. _________________ Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30 |
ocelotpotpie Samba Member
Posted: Wed Nov 04, 2020 3:12 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
Can you elaborate a bit on what's in the dash photo? |
CdnVWJunkie  Samba Member
Joined: February 01, 2004 Posts: 1007 Location: Sarnia, Ontario, Canada
Posted: Wed Nov 04, 2020 4:11 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
A lot going on there Casey. Looks a little like a cockpit...
I think the primary think the OP was alluding to was the Double DIN radio. |
Posted: Wed Nov 04, 2020 4:33 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
The switch in the upper left is for toggling between the radio being tied to the starting battery via the ignition switch, or the house battery. The switch to the right is for the aftermarket seat heaters that replaced my non-functioning factory units. The next row down has a rotary switch for the front aux. driving lights and rear aux. backup lights. The next switch is a placeholder for the switch to toggle the video feed on independent of the reverse switch. The next switch is to toggle between a front and rear camera--this hasn't been completed yet. And lastly, the switch in the pod is for the battery gauges. Not shown is a switch in the upper console for the display screen for the aux. heater, which ridiculously has no factory means of shutting itself off. Then another switch just above the driver's headrest to turn on a light up in the poptop.
I love running wires. _________________ Casey--
Oly Bulli
Joshwa Samba Member
Joined: November 18, 2015 Posts: 671 Location: Mountlake Terrace WA
Posted: Thu Nov 05, 2020 12:38 am Post subject: Re: I've joined the dark side: 2001 Weekender |
Funny thing about that little project is that when I was in the middle, I decided to try and plug an Audi hazard switch in there because it was from appearances exactly the same, but it wasn't. Smoke came boiling out from behind the dash. It was a fiasco. I had to dig deep into the dash to free up the harness and re-insulate all the burnt wires. nuts. Not doing that again. _________________ Casey--
Oly Bulli
Abscate  Samba Member
Joined: October 05, 2014 Posts: 15179 Location: NYC/Upstate/ROW
Posted: Thu Nov 05, 2020 2:59 am Post subject: Re: I've joined the dark side: 2001 Weekender |
ESPN button tells you that it’s already raining. _________________ .ssS! |
Posted: Thu Jan 07, 2021 9:32 pm Post subject: Re: I've joined the dark side: 2001 Weekender |
I added a GMRS radio, so we could converse with fellow van travelers while caravanning.
Oly Bulli
