63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Tue Sep 06, 2016 8:27 am Post subject: Replacing support channel on vert with body on?? |
have a line on a 60's vert and it's sight unseen atm and was wondering worse case scenario if the channels in fact do need to be replaced is it possible to do this without removing the body??
I've never taken a body off and would rather not completely restore this thing as it appears in decent shape...
thx _________________ BUS WANTED: 13 window BUS any year considered.. |
Joined: August 31, 2013 Posts: 12849 Location: North Carolina
Posted: Tue Sep 06, 2016 11:44 am Post subject: Re: Replacing support channel on vert with body on?? |
If it needs the support channel, more than likely it will need heater channel repair or replacement. The flange with holes on the support channel goes between the pan & the heater channel, you will need to lift the body to gain access to remove (cutting, grinding, drilling, welding) & replace. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Sep 06, 2016 3:03 pm Post subject: Re: Replacing support channel on vert with body on?? |
Can do ..yes.. would I ever want to hell no..
Heater channels are welded into the main body with lots more welds and lots more support than Sedans..
Even if you simply luck up to just need to replace the rails.. lifting the body off is required.
Chances are.. it will need at least heater channel lower plates too..
Brace the body properly, lift off the chassis and replace whats bad is still the best way.
Lots more that makes a Convertible tick than just the lopped off hard roof..
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Tue Sep 06, 2016 5:36 pm Post subject: Re: Replacing support channel on vert with body on?? |
And IF you were to try it with the body on, you better have some serious skills. I am with everyone else, take the body off - you'll find more rust hidden away out of sight. Check out my thread ....
http://www.thesamba.com/vw/forum/viewtopic.php?t=572641&highlight= _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
