richierich Samba Member
Posted: Tue Sep 06, 2016 12:45 pm Post subject: Improving quarter mile time advice please?! |
Hi all. Had my Oval out on the quarter mile and need some advice. Car is a full weight 56 Oval running a 2110 type 1 motor. Motor puts out 177hp at the flywheel and I have a KCR Super Street transmission with stock ratios. Rear tyres are street tyres - 205/65/15's.
I ran:
15.0 1/4 mile at 87mph;
2.08 second 60ft;
9.68 1/8 mile at 69mph.
This engine has run the 1/8 mile previously at 7.04.
What can I do to improve these times and i assume its my 60ft that is killing me. How do I improve it? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Sep 06, 2016 1:09 pm Post subject: Re: Improving quarter mile time advice please?! |
richierich wrote: |
In THAT car with THAT setup? |
Posted: Tue Sep 06, 2016 1:27 pm Post subject: Re: Improving quarter mile time advice please?! |
ps2375 wrote: |
richierich wrote: |
Ah, I meant to say in my original post, not in this car no. I know I wont get that, i just want to improve my 60ft and overall ET. |
ps2375 Samba Member
Posted: Tue Sep 06, 2016 1:32 pm Post subject: Re: Improving quarter mile time advice please?! |
Tires and driver, may not be in that order, but those are the main culprits. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3462 Location: Paradise, Ca
Posted: Tue Sep 06, 2016 2:03 pm Post subject: Re: Improving quarter mile time advice please?! |
Need some details about the cam, heads, valve sizes, porting, carbs, and also where ya at? _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Tue Sep 06, 2016 2:09 pm Post subject: Re: Improving quarter mile time advice please?! |
What R&P are you running? 2.08 60' time sounds about right for those size street tires.
Quote: |
This engine has run the 1/8 mile previously at 7.04 |
This doesn't sound right for 177 HP 2110cc engine. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Tue Sep 06, 2016 2:35 pm Post subject: Re: Improving quarter mile time advice please?! |
I'm running:
SCAT C45 cam;
Mofoco 050 heads with 42×37.5 valves;
EMPI 48 IDA's on tall manifolds polished and match ported;
1 5/8 Merged header;
Stage 1 Kennedy 1700lb clutch plate;
Also, I'm at Sea level.
R&P is a 4.12 Klingelnberg |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Tue Sep 06, 2016 2:49 pm Post subject: Re: Improving quarter mile time advice please?! |
In what way did you get the 177? Is this an actual dyno number, or a mathematical estimate?
What type of fuel pump are you running?
Do you have any type of launch rpm limiter to monitor what rpms you're at? |
Posted: Tue Sep 06, 2016 3:00 pm Post subject: Re: Improving quarter mile time advice please?! |
[email protected] wrote: |
The hp number is an actual dyno figure at 5250rpm with muffler and belt off.
Running a Facet GoldFlo fuel pump and no, no launch RPM limiter. |
Posted: Tue Sep 06, 2016 3:11 pm Post subject: Re: Improving quarter mile time advice please?! |
Was the dyno run with this exact pump? I would say the fuel pump is one of the problems. A friends 2276 with 44's ran out of fuel about 700 ft with one of the rotary carter pumps. I would look into a much larger pump. We put a Red Holly on the previously mentioned car, and it was a completely different animal. And have at least a 3/8 feed line from the pump.
Having some type of rpm limiter can help tune your launches. My 2180 lb Super with a 1776 will considerably change 60 ft times with as little as a 200-300 rpm change from its 3800 rpm sweet spot. |
Chip Samba Member
Posted: Tue Sep 06, 2016 3:12 pm Post subject: Re: Improving quarter mile time advice please?! |
vwracerdave wrote: |
This doesn't sound right for 177 HP 2110cc engine. |
Maybe it was turbo'd in a go cart... Or dune buggy... |
jpaull Samba Member
Posted: Tue Sep 06, 2016 4:57 pm Post subject: Re: Improving quarter mile time advice please?! |
Are you running 1.1's or 1.25's? The C45 cam is really mild. Even with 1.25's the lift is only at .490.
Next, Those Mofocos. Are the ports opened up much? any pics of the intake ports? Really this will determine if you can go up on your cam or not.
You need more cam AND/OR portwork on those heads.
I would not base anything on the Dyno Horsepower. Its a great tool. All we know is that you need MORE.
richierich wrote: |
I'm running:
SCAT C45 cam;
74 Thing Samba Member
Posted: Tue Sep 06, 2016 4:58 pm Post subject: Re: Improving quarter mile time advice please?! |
That HP figure seems high or optimistic
What were your tire pressures-prob need to go much lower with street radials.
Seat time and lots of tuning are always the key.
What did your car weight with the driver? |
Posted: Tue Sep 06, 2016 7:40 pm Post subject: Re: Improving quarter mile time advice please?! |
For now, why don't we use his 177hp as a constant factual variable, and not second guess/discredit the build. I can possibly see that the conditions/environment with the engine mounted in the car, might not be duplicated from the dyno session from my question about the fuel system. If there are issues with the fuel system, or even the charging system not alowing this engine to produce the full 177, that's fine, but lets assume it made the claimed 177 on a dyno.
Tire pressures as others have mentioned can have a huge effect on 60 ft times as well. From my experience, a fully treaded radial tire will not usually increase traction below 15 psi, but it will be unstable at speed below 15. Experiment with 15-20 psi.
I would also create some type of rpm limiter to be able to adjust the rpm as the clutch is released upon the launch. My experience in drag racing has been to limit as many uncontrollable variables you can, an attempt to turn them into controllable/tunable variables. Any adjustments made to the suspension/tires will be difficult to see their effect if one time you launch at 2000 rpm, and the next at 4500. |
air-h2o-air Samba Member
Posted: Tue Sep 06, 2016 7:49 pm Post subject: Re: Improving quarter mile time advice please?! |
the easiest way....get rid of those big rear tires for starters
when staging....load trans using parking brake as you light the 2nd bulb
Use E brake as your line lock...use your feet to work throttle and clutch
slip clutch and apply throttle gently....dont go WFO on throttle and side step the clutch upon the launch |
vdubnut58 Samba Member
Posted: Tue Sep 06, 2016 8:14 pm Post subject: Re: Improving quarter mile time advice please?! |
For starters I would order a set of drag radials. Do you have 135's up front?
I would remove the belt before your pass. And buy a Braile race weight battery. I assume your suspension is stock so after the car starts to hook if it's lowered your sump and muffler will drag on the starting line so you might want some 28mm rear torsions. I would leave the motor alone and focus on the car. First pass I ever made in my car was a 13.4 and I was able to get it to it to 12.60 without making any changes to the engine/Trans. I even picked up a set of T bars in place of the bumpers. There are lots of little tricks to be found. |
Posted: Tue Sep 06, 2016 11:59 pm Post subject: Re: Improving quarter mile time advice please?! |
I will post up a pic of the dyno sheet when I get home from work later. The pulls were done with the Facet GoldFlo pump yes. I swapped it in as the motor was getting starved of fuel with the previous one at 4800rpm.
One thing, I am getting loads of wheel spin off the line in first and a fair bit in second gear too so I definitely think tyres are part of the issue. I guess like most are saying it is just practice and playing around with the setup. I don't have a weight figure for the car with me in it unfortunately. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Sep 07, 2016 3:57 am Post subject: Re: Improving quarter mile time advice please?! |
Get Slicks _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Wed Sep 07, 2016 4:48 am Post subject: Re: Improving quarter mile time advice please?! |
I am taking your dyno info as fact, I would just rather others would as well. I have seen where an engine performed well on a dyno, but had issues in the car. Using a stock 6mm line in the tunnel that could not supply enough volume of fuel, and poor charging systems not creating enough voltage/current for the ignition system at higher rpms have been two of the most common things I have seen.
For every modification there are effects on other things, some good, some bad. If you change to a different tire, the rest of the car needs to be able to work with the different tire. Is your trans a Superstreet with a 3.80 1st, or a Superstreet Plus with a 3.78 1st? Do you have a better form of torsion bar grommet, such as urethane, or one of the bronze bushing covers? Do you have some type of mid mount to capture the front of the trans? Do you have some sort of heavier aftermarket axles? Those are all things to consider that can have serious concequences when switching to a drag type tire?
Call around to scrap yards, or garbage dumps to see if they have a scale that would go down to a 1000lbs., or so, and see if they could weigh your car. |
Posted: Wed Sep 07, 2016 6:40 am Post subject: Re: Improving quarter mile time advice please?! |
I know. It's bizzare to me that people think you would make up horsepower figures. What would be the point of that? I realise that dyno figures do not mean anything when it comes to quarter mile times etc and also that just because the engine ran this or that in another car it will do the same in mine. I just want to improve and maybe have a chance of running 13's.
Yes, my transmission is a Super Street Plus with a 3.78 first gear. Axles are heavy duty and yes, urethane torsion bar grommets but no mid mount or traction bar. The fuel issue - as i say, we were having a problem with starvation with the last fuel pump and so changed to this one and ran it again with no apparent problems.
Another thing also, the 177hp is with the belt off. Belt on it produces 167hp at 5,170rpm (at the flywheel). The guy who did the pull said it was still making power past that - I had told him to rev only to 5,200 just to be sure that everything was good. Now I know everything is in good order, I have it booked in again for another session to do a pull to 6,500 and look at jetting etc. |
