dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Sep 04, 2017 9:14 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Leapfrogging from another thread... ( https://www.thesamba.com/vw/forum/viewtopic.php?p=8548420#8548420 )
After eliminating any obvious relay issues in that (^) thread, search led me here with same symptoms as OP.
Got to this point and the "always-on" starter issue went away with the following:
crazyvwvanman wrote: |
...In the engine compartment at the relay box there is a 2 pin connector plugged into the front edge of the box. Should be a red and a red/black wire. Pull that connector away from the relay box and try the key again... |
Now starter runs as normal (only with key in "start" position, off in "run" position)...YAY!
Of course, with the 2-pin connector unplugged, the fuel pump does not run at all, so I need the next
diagnostic step to get the fuel pump back on line but keep the starter from behaving badly yet again...
I'll be perusing Bentley wiring diagrams & hanging around the van all day, so feel free to chime in...
Happy Labor Day, all y'all!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Mon Sep 04, 2017 9:20 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
djkeev wrote: |
That relay under the seat..... that's the relay for house power isn't it?
Nothing to do with starting the Van. |
Except that Mark knows about an unusual "no-start" condition involving auto trans, cruise control,
the stock fridge relay AND an aftermarket hard-start relay... He's an amazing man, that one...
"The WonderVan"
Posted: Mon Sep 04, 2017 10:36 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Progress!!! ...(???)
At the 2-pin connector to the relay box I've now reconnected the red wire but left unconnected the red/black,
and...I now have fuel pump and NORMAL STARTER & IGNITION SWITCH OPERATION... Huzzah!
Q: Any reason I can't -or- shouldn't just leave it as is & run it this way long term?
FWIW: This also seems to have eliminated my "always-on" (!)BRAKE dash light, but I'm still wondering
how & why all this is related...??? I know...I'm a pest and a curious sort but I try to learn a little something
every day...and these vans definitely give all of us all something to think about!
I look forward to any ensuing discussion. SAMBA! Time for lunch...
"The WonderVan"
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Mon Sep 04, 2017 11:16 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
You should try unplugging the ICU, idle control unit. That may be the source of the problem. It may be flooded inside, or failed. If unplugging it fixes the starter issue, open the case and have a look.
Mark |
Posted: Mon Sep 04, 2017 11:38 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
^^^ Try this now (with red/black disconnected @ relay box) -or- try after reconnecting red/black @ relay box???
"The WonderVan"
Posted: Mon Sep 04, 2017 11:41 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Connect the relay box 2 pin harness normally.
Mark |
Posted: Mon Sep 04, 2017 12:07 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Will do! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Mon Sep 04, 2017 1:13 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Well, here we go...
In the process of getting to & cleaning the ICU, came across this new feature:
So, I guess I'll spend some time cleaning this up & get back to you...
"The WonderVan"
Posted: Mon Sep 04, 2017 3:00 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Seems to be the PS idle boost circuit...one wire crispy for about 12", the other
is fully toasted nearly the whole length, from switch to within 12" of the ICU...
So, seems like I'll be wrangling a new PS idle harness tonight... <shrug>
"The WonderVan"
Posted: Mon Sep 04, 2017 3:13 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
That kind of damage to the Digifant harness is commonly from the power steering switch wiring. Look closely at those 2 wires at the switch and where they enter the harness bundle. Look at the full length of the harness cover for evidence of melting inside.
This is why I wouldn't stop looking just because you found that unhooking the red/black at the relay box "fixed" the starter misbehavior. That misbehavior could be only a symptom of a more serious issue that could have burned down the whole van.
There IS NO FUSE for the power wires in the fuel injection system and that includes the power steering switch wiring. The power steering wires and wire ends are vulnerable where they plug into the switch and many vans have suffered a melted harness when the wire or wire end shorted out to metal.
Mark |
Posted: Mon Sep 04, 2017 4:00 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Indeed.
As I dug into that harness I found at least half-a-dozen wires burned, but PS wiring is obviously
the cause. Too much work for just tonight, so I'll have to piece it together as I can this week...
As always, I'll keep you posted...thanks again, Mark!
"The WonderVan"
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Mon Sep 04, 2017 5:12 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Yeah..."GREAT" find, indeed...
FWIW, I bet most van owners could prevent this issue with a quick look at the PS pressure switch connectors.
From the factory they are bare crimps, uninsulated, subject to all manner of dirt/dust, moisture/corrosion,
vibration & all the heat of the engine bay. Mine were obviously in poor shape & turns out the connector on
the mostly (nearly completely) burnt wire was hanging on by just a few strands of copper...
I assume my repair is simply a matter of cutting out the burnt sections & reconnecting the loose ends with
similar gauge wire...any pro tips/pointers here? Any words of advice always appreciated. I figure insulated
spade connectors will provide better protection & longer service when I get back to finishing at the switch.
I'll be using weatherproof (adhesive/heat shrink) butt connectors for all splice joints.
Don't worry, Dave - just get in there & replace (more of) your suspect connectors...
"The WonderVan"
Posted: Mon Sep 04, 2017 7:30 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Related issue & prevention: https://www.thesamba.com/vw/forum/viewtopic.php?t=647443
Guess I'll also do some fuse/holder shopping. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Sep 05, 2017 4:17 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Sure, NOW they tell me... (note highlighting):
I'm pretty sure this needs to be added to the list of "What to do to keep your van from burning"...
"The WonderVan"
Posted: Tue Sep 05, 2017 11:09 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
I pored through the Bentley wiring diagrams today.
Be aware that you cannot make a blanket statement about the wires that applies to all 2.1 units.
I inadvertently searched the early 86 diagram only to find out that there are significant differences from early to later 86 units and some mixing even!
Anyway, I sorted it out. The main unfused power to the Distributor box (as Bentley calls it) is terminal O-21 this is a thread rod with a nut + connection inside the Distributor Box.
There are wires on the back side as well as wires in the box.
The smaller of the red wires on O-21 feeds the injection and fuel pump relay box above the ignition coil. I've lifted it out with my finger...... I will cut this wire and install an inline fuse, 7.5 amp is suggested.
This is a 1.5 ga wire fed by a 2.5 ga wire.
The 1.5 runs to both the fuel pump relay and the fuel injection relay.
I do wonder about fuse size?
The 7.5 amp seems small to me for the fuel pump AND the injection system.
Is there logic in protecting the fuel pump with a larger fuse?
(A 1.5 ga wire handles a maximun of 15 amps in runs under 10 feet)
If so, should a smaller fuse be added before the injection relay?
The injection wiring varies in size from 1.5 down to 0.5 ga.
(A 0.5 ga wire handles a maximum of less than 10 amps on a 10 foot run, hence probably the 7.5 amp recommendation)
The Power Steering wires are 0.5 ga.
(As a side note: I've yet to figure out the blue wires with the yellow connector)
I remembered seeing an inline fuse in that box. Sure enough! A 5 amp fuse is there. Turns out it feeds the Crankcase Vent Heater. (Something not found on the early 86 wiring diagram, it took some head scratching)
As a "Bonus Find", I found corroded ground wires in my T7a/ connector!!
These ground wires are for the Coolant Level and Temperature gauges.
You people with odd temperature gauge action? Just maybe you should check your T7a/ connector for corrosion.
I'll add this T7a/ corrosion to the forums ground location list.
Anyway, any fuse size thoughts??
Ghia
Vanagon
Beetle
danfromsyr Samba Member
Posted: Tue Sep 05, 2017 11:52 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
blue wires w/yellow connector are the alternator light (energizer) wires.
image stolen from google image search
https://i.pinimg.com/originals/f8/3f/8f/f83f8f2f9d739656d55b19ff33aebc21.jpg
*NOTE also to note that the Alternator wire from the Alternator to the post in 83.5-85 vans is woefully under rated and should be upgraded. I've serviced more than a few vans with that harness melted from the Alt loads. _________________
Abscate wrote: |
Posted: Tue Sep 05, 2017 4:41 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
djkeev wrote: |
...littlefuse Led fuses... glow when they blow... |
Link, plz?
"The WonderVan"
