djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Sep 05, 2017 7:06 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Progress report...Day 2 (cutting & splicing @ ICU)
Out with the old:
In with the new:
Today I cut out entire 2-3 foot sections of 7 seriously burned wires & shorter sections on 4 others. Every single wire
in that harness was affected. Damage stopped just short of the 1&2 injector leads, although I will inspect more
carefully tomorrow when I'm connecting at that end of the harness to be certain things there are clean & solid.
Another day in paradise...!!!???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
kamzcab86 Samba Moderator
Posted: Thu Sep 07, 2017 2:20 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
djkeev wrote: |
(Sorry Kam, that it's so dirty) |
When I replaced the alternator a month ago, for whatever reason, I checked those two connections. One has a black plastic protector on it, the other is bare. Both were so blasted loose I was surprised they hadn't already fallen off. Cleaned them up, tightened them up, and reinstalled... good to go. But thanks to this topic, I'm now going to pull the bare connector back off and add some heat shrink just to be safe! _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Sep 07, 2017 5:20 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
kamzcab86 wrote: |
... those two connections... One has a black plastic protector on it, the other is bare... |
Must be a later production upgrade? My 86 is identical to Dave's (go figure)...
What year do you suppose the protector showed up? And perhaps the bigger question:
How many wiring harnesses have been fried for lack of that one insulated connector?
"The WonderVan"
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Sep 07, 2017 5:36 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
dhaavers wrote: |
One wonders if Vanagons with power steering had a greater occurrence of burn-ups... _________________ Jim Crowther
Vespa GTS 300 |
Posted: Thu Sep 07, 2017 7:09 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
dhaavers wrote: |
What year do you suppose the protector showed up? |
All I can tell you is that the parts catalog shows 2 in use for the MV (part #211971921) up through VIN L-045388. The peculiar part is, #045388 has a production date of December 31, 1989. Mine was built in February 1990 and has just one (certainly plausible one went missing over the years).
Brickwerks sells a retrofit: https://www.brickwerks.co.uk/wiring-connector-6-3mm-flag-white.html .
From L-045389, the vans allegedly came with a fuel injector-type connector (#357972752), which mine certainly does not have.
Moral of the story: Who the hell knows... _________________ ~Kamz
2016 Golf GTI S
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Thu Sep 07, 2017 7:47 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
I have a few of the white Tyco/AMP housings (same as the Brickwerks version) in stock if anybody needs them. $0.65ea plus actual postage.
This type of housing definitely can get brittle and fall off with age since they just snap together. A small cable tie might do the trick to keep them in place.
_________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
Posted: Thu Sep 07, 2017 7:50 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
I've been using these "flag" connectors for some other projects & will do the same here:
Uses an uncommon crimp tool, but they're very solid & perfect for this application...
Question all-of-a-sudden...any good reason NOT to use regular straight connectors?
"The WonderVan"
Posted: Thu Sep 07, 2017 8:08 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
The insulated flags are definitely difficult to attach correctly without the right crimp die.
The only reasons not to use a straight terminal would be if there isn't enough room or if it would put too much strain on the wire. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want to be happy, practice compassion. |
Posted: Sun Sep 10, 2017 8:38 am Post subject: Re: Van attempts start w/ ignition ON--switch is good |
Thinking towards the end of this project...can I test the PS switch for possible internal failure?
Is the PS switch normally closed <or> open?
Home again, so back at this today...
"The WonderVan"
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Sep 10, 2017 1:49 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
djkeev wrote: |
Post a photo of the Bentley wiring for the switch... |
OK...here's my page (NOTE/FWIW - LATE 86..."from VIN G 055 690"):
So...looks like normally open, & tests as such, so...GOOD!
"The WonderVan"
Posted: Sat Sep 16, 2017 7:08 pm Post subject: Re: Van attempts start w/ ignition ON--switch is good |
x2
I have my ATO fuse holder installed, 7.5A fuse & spare ready to go, still working on rewiring...
"The WonderVan"
