Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Thu Sep 08, 2016 8:18 pm Post subject: clutch/pressure plate combo question |
working on another build for a 71 bus. going to be in the 220 h/p neighborhood
last build I used a 1700 lb kennedy p/p and a copperhead disk. even with the longer clutch arm, it's a bit rough in stop and go (I realize this has no bearing on the disk itself)
overall happy with the combo. the "real" question is would a stock disk and 1700 lb p/p be asking too much? more than happy to get another copperhead, but not really doing burn outs etc (well, once in a while...maybe!) _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
slalombuggy Samba Member
Posted: Thu Sep 08, 2016 8:25 pm Post subject: Re: clutch/pressure plate combo question |
Even in my buggy I could drive through a Stage 1 and stock disk when I was flat out in 4th. I also went to a Copperhead and love it.
brad |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Thu Sep 08, 2016 8:43 pm Post subject: Re: clutch/pressure plate combo question |
Th copperhead is a great disk. I abuse mine all the time,slip it instead of downshifting, yeh it's terrible . You can slip it and get it pretty hot yet won't die. A stock disk once you get it hot it turns to gumbo and slips, maybe they can recover if you drive like grandma for a day, maybe not. Probably not. I've seen one go from new to dead in TWO stop signs.
If you manage to acquire a good pressure plate that allows you to feather the clutch easily, and you do,, then you will need a copperhead
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Sep 08, 2016 8:50 pm Post subject: Re: clutch/pressure plate combo question |
I wonder if cbs dual friction may be a Lil less aggressive? I do like the copperhead also. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
modok Samba Member
Posted: Thu Sep 08, 2016 8:55 pm Post subject: Re: clutch/pressure plate combo question |
Cb dual friction(centerforce) is almost the same. I ran the copperhead, swapped to centerforce, then back to copperhead, over a few years. I think the copperhead is a little better overall performace slightly), but the centerforce is easier on the flywheel. They are very similar. |
modok Samba Member
Posted: Thu Sep 08, 2016 9:06 pm Post subject: Re: clutch/pressure plate combo question |
BTW, with both, I had a slight vibration on engagement, when backing up especially. Only when engaging very slightly, didn't really notice it most driving. Then I re-surfaced the pressure plate and it's gone. Gone for good it seems, since that was 3+years ago. |
Howard 111 Samba Member
Posted: Thu Sep 08, 2016 9:10 pm Post subject: Re: clutch/pressure plate combo question |
I use a KEP 2100lb with a Berg, Super Street dual friction disc, and love it. Easy on the leg, but hooks up solid. This is in a turbo Ghia. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Posted: Thu Sep 08, 2016 9:53 pm Post subject: Re: clutch/pressure plate combo question |
modok wrote: |
that is one thing I noticed with the copperhead as well
and you're right, seem a bit more jumpy in reverse....
so, I guess I will just go with a copperhead. they seem pretty predictable
didn't know why I would have even considered a stock clutch. guess I was looking for options. the reality is a copperhead is what? 130 clams? cheap money in the grand scheme of things.... _________________
Jake Raby wrote: |
Brian wrote: |
modok Samba Member
Posted: Thu Sep 08, 2016 10:23 pm Post subject: Re: clutch/pressure plate combo question |
One of the FEW items that have been worth every penny.
Rigth up there with SAW torsion bars, web cams, Italian webers, 3 finger PP,
This is another item that was worth every penny, and also can touch up your pressure plate surface, so you "season it", then sand it flat, and it'll stay flat.
maui Samba Member
Posted: Thu Sep 08, 2016 10:30 pm Post subject: Re: clutch/pressure plate combo question |
For me, the copper was to heavy and neva like go in gear at 8 grand shifts and I feel it's to hard on trans so breaking R/Ps is easy if you no watch out. I use 2100 and daiken and easy on foot and major grip action and it lasted long time and trans lasted long time. Cheap insurance |
modok Samba Member
Posted: Thu Sep 08, 2016 10:36 pm Post subject: Re: clutch/pressure plate combo question |
also a good idea |
Posted: Fri Sep 09, 2016 4:56 am Post subject: Re: clutch/pressure plate combo question |
seeing it's in a bus and *really* won't be doing burn outs etc is a daiken a better choice?
it really doesn't matter to me what I use, just want it to be reliable. why would you say the copperhead was rough on the transmission? rough engagement or a weight issue? _________________
Jake Raby wrote: |
Brian wrote: |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Sep 09, 2016 5:08 am Post subject: Re: clutch/pressure plate combo question |
The copperhead is a heavy disc, and can be rough on the syncro's, hubs, and sliders if you're trying to shift fast. The dual friction disc (berg, I've not tried the CB) is lighter; and the Daiken even lighter. I weighed them last year and posted the results, might search it if you're interested. I decided on the Daiken, and it's nice for stop and go traffic. i haven't slipped it with a 1700lb plate and trust me I've tried. _________________ modok wrote:
Posted: Fri Sep 09, 2016 10:44 am Post subject: Re: clutch/pressure plate combo question |
esde, I tried a search and came up with nothing, unless I am using the wrong terms....
I am not opposed to a daiken either. if it's easier on the transmission I am good with that
*EDIT*
this is the disc you guys are referring to, correct?
http://vwparts.aircooled.net/Daikin-200mm-Rigid-Cl...m-b503.htm _________________
Jake Raby wrote: |
Brian wrote: |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3292 Location: Rapid City, SD
woodoctr Samba Member
Posted: Fri Sep 09, 2016 11:56 am Post subject: Re: clutch/pressure plate combo question |
I run that Super Daiken with a Stage II Kennedy and long arm with my supercharged rotary. 265 h.p. at the rear wheels, no slip, good engagement. Also have everything pretty firm in the back with it.... Mohr mid mount, heavy duty trans. mount with CB Rhino mounts, and Kafer brace system. This is a VW based kit car.... all up weight around 1800 lbs. Only other discs I was looking at were the Copperhead and that dual disc set-up. I felt that the Daiken with the stage II was going to be the cheaper "safety valve" in my drivetrain. |
Posted: Fri Sep 09, 2016 2:29 pm Post subject: Re: clutch/pressure plate combo question |
I think I would try the Daiken first, a guy can never have too many clutch disks can he? I don't speed shift so the copperhead hasn't been an issue but ya, they are heavy and even mcmscott will tell you they eat parts.
brad |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Sep 09, 2016 4:17 pm Post subject: Re: clutch/pressure plate combo question |
Copper head or black magic are the worst thing you can do for your trans. Those disks are HEAVY, mass in motion tends to stay in motion, your synchro rings have to control that mass in motion. A stage 2 with a stock unsprung disk are good for 11.60's in the quarter in a full weight sedan, how much more do you need? _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
modok Samba Member
Posted: Fri Sep 09, 2016 4:26 pm Post subject: Re: clutch/pressure plate combo question |
That's true, if you want to shift fast then you want a light disk, but, do you want to shift fast?
What if your syncros are ALREADY dead? |
Posted: Fri Sep 09, 2016 6:37 pm Post subject: Re: clutch/pressure plate combo question |
mcmscott wrote: |
Copper head or black magic are the worst thing you can do for your trans. Those disks are HEAVY, mass in motion tends to stay in motion, your synchro rings have to control that mass in motion. A stage 2 with a stock unsprung disk are good for 11.60's in the quarter in a full weight sedan, how much more do you need? |
ok, so this is going in a bus...worstfailure to be exact.
so, a 1700lb kennedy and a daiken should fit the bill then? the super disc should be a decent compromise?
the only thing it will be doing is dragging the bacon to the campground
I'd like to snap off second from time to time, but the reality is it isn't a bug/ghia/T3 so it isn't exactly agile _________________
Jake Raby wrote: |
Brian wrote: |
