Schnage Samba Member
Posted: Sat Sep 10, 2016 8:53 am Post subject: Judson / Timing on 36 hp 1200 1960 beetle |
After all the trouble with installing the pertronix, i am unsafe with the timing? I have a timing light, an the best power i have when the timing mark on the pulley is as seen in the picture:
What do the experts think? |
Posted: Wed Sep 14, 2016 12:24 pm Post subject: Re: Judson / Timing on 36 hp 1200 1960 beetle |
No idea? |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Thu Sep 15, 2016 7:59 am Post subject: Re: Judson / Timing on 36 hp 1200 1960 beetle |
ok let me try here, what dizzy? 009 010 019 ? if so it should be timed at the timing mark which is 7.5. looks like it's timed at 10+ take a tape measure and measure from the mark to the left a inch and a half and make a mark that is about 32- 34 degrees. check the timing at 3k rpms's and see if it goes past it . if so yes too much advance and you will melt your pistons. i always check total advance to be safe. all dizzy's can vary in advance built in. . if it does not run as good there you have other problems. carb/jetting _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Posted: Thu Sep 15, 2016 9:08 am Post subject: Re: Judson / Timing on 36 hp 1200 1960 beetle |
It is a VJU4BR8 dizzy..... |
Posted: Thu Sep 15, 2016 10:56 am Post subject: Re: Judson / Timing on 36 hp 1200 1960 beetle |
ok
that is the same curve as a 019. so 7.5 is where it should be timed. that would give you 30-32 total. you need to make sure it is not over advancing. set the timing no more than 32 total. at 3k. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
