proofpudding Samba Member
Joined: March 02, 2012 Posts: 83 Location: Nanoose Bay, BC
Posted: Tue Oct 04, 2016 3:52 pm Post subject: Re: Restoration of my 87 GL Tintop |
Pretty close to worn through. Any idea how many miles were on that pedal and pin?? Seeing pictures like this always makes me nervous about my own. _________________ 1988 Vanagon GL Wolfsburg |
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Tue Oct 04, 2016 4:13 pm Post subject: Re: Restoration of my 87 GL Tintop |
217000 miles on odometer but not working when I purchased her, so who knows. _________________ what a long strange trip it's been |
Posted: Tue Oct 04, 2016 5:31 pm Post subject: Re: Restoration of my 87 GL Tintop |
Made backing plates for my 5 1/4 door speakers. Saw it on Samba. [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Tue Oct 04, 2016 5:39 pm Post subject: Re: Restoration of my 87 GL Tintop |
More clean and paint, mustache bar and backside of bumpers. [img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Tue Oct 04, 2016 5:54 pm Post subject: Re: Restoration of my 87 GL Tintop |
I did not like the idea of the bottom of the flywheel being exposed. So I made a simple aluminum cover, mounting bolt holes were right there, For the Subaru cover I assume. Cost $0 Old aluminum cooky sheet[img][/img][img][/img][img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Tue Oct 04, 2016 8:18 pm Post subject: Re: Restoration of my 87 GL Tintop |
Oil temp sender, water pump $149.95, cams and main seals $92.99, Balancer pulley $199.95, timing belt and idler pulleys $0 came with engine, New front belt cover $75.00, thermostat $25.40, and housing $43.32. Thermostat housing is also supposed to be the last one, so NLA. Total $586.61 Running Total $1170.96[img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Wed Oct 05, 2016 7:46 am Post subject: Re: Restoration of my 87 GL Tintop |
More light. Added some fog lamps, I've had the lights for 43 years. About time that they made some light. [img][/img][/list] _________________ what a long strange trip it's been |
Posted: Wed Oct 05, 2016 8:22 am Post subject: Re: Restoration of my 87 GL Tintop |
Installed SC dip stick and SC engine support. Both fit nice. Dip stick $79.95, Suport $0 came with engine, engine mounts $112.80, Total $192.75 Running Total $12163.71[/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Wed Oct 05, 2016 2:36 pm Post subject: Re: Restoration of my 87 GL Tintop |
More engine work, Reverse manifold $299.95, Subaru O rings $39.82, ERG valve $9.26, 100MMX94MMX3MM O ring for plenum control gate $7.67, PCV valve $12.95, Oil pressure sender $45.95, knock sensors 59.99. Total $475.59 Running Total $12639.29 [/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Wed Oct 05, 2016 7:20 pm Post subject: Re: Restoration of my 87 GL Tintop |
Had a little work to do on the throttle bracket. Enlarge throttle hole and oval one of the mounting holes, so it will clear the intake.[img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Thu Oct 06, 2016 8:23 am Post subject: Re: Restoration of my 87 GL Tintop |
Installed power steering, alt and dip stick support. New tensioner pully $69.94,belt $12.99, Power steering input control $93.05, last one now NLA.Total $175.98 RT $12815.27 [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Thu Oct 06, 2016 8:51 am Post subject: Re: Restoration of my 87 GL Tintop |
SC header go's on, added a expansion joint. Made instalation easy fit great. SC header $499.00, Gaskits to head $22.00, Flex joint $28.00. Total $549.00 RT $13364.27. I got a little ahead here, this was done after install. [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Thu Oct 06, 2016 9:32 am Post subject: Re: Restoration of my 87 GL Tintop |
Time for my transmision and throwout bearing clutch slave. I read on samba of problems with the plastic slave. So i purchased the metal part from Audi. The tranny was modified by German transaxle of Bend OR. Mods include, Brand new 4.13 ring and pinion, A 1.14 third, A .70 forth and a Pelaquin torque biasing differential. SC bell housing $0 came with engine, Dif $1175.00, Audi slave $151.00, Transmission rebuild $3640.00. Total $4966.00 Running Total $18.330.27 [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Thu Oct 06, 2016 3:13 pm Post subject: Re: Restoration and modification of my 87 GL Tintop and cost |
Shortly befor installing flywheel, I once again saw on Samba where after install, there was an oil leek caused buy main seal being seated all the way in. I checked mine and it was all the way in! New main seal installed correctly. THANK YOU SAMBA!!! Installed flywheel, pilot bearing and stage 2 clutch pack. Flywheel $0 came with engine, Bearing $23.85, Clutch kit $359.00. Total $382.85 RT $18712.62 [img][/img] _________________ what a long strange trip it's been
Last edited by vino de vano on Thu Oct 06, 2016 3:46 pm; edited 2 times in total |
Posted: Thu Oct 06, 2016 3:30 pm Post subject: Re: Restoration of my 87 GL Tintop |
Finally time to install engine trans combo. Went right in with no issues. Looks awesome. Power Flex front trans mount $54.99 RT $18767.61 [img][/img][img][/img][img][/img][list=][/list] _________________ what a long strange trip it's been |
Posted: Thu Oct 06, 2016 4:22 pm Post subject: Re: Restoration of my 87 GL Tintop |
Rear mounts get angle iron and 1/2 inch aluminum spacers. [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
pablum Samba Member
Posted: Thu Oct 06, 2016 5:35 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Most people would begin to feel growing discomfort when faced with the full extent of their folly. I don't know how you do it. _________________ The wise man learns from history, the fool from experience.
I see [a cat] in the street and i aim for the pest with my car. -- bluebus86 |
Posted: Fri Oct 07, 2016 9:53 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
It's been a lot of work and a substantial cash expenditure for sure. But being older and more or less retired gives me the time, and what else am I going to do with my money? I figure in the end I will have a almost new van. In many ways better than new. That should be fun safe and dependable. Can I recover my investment if I were to ever sell (not likely ) probably not. But thats not the point, I did it because I love my van Vino and she deserves it. Our future travels will be epic and hopefully van trouble free. It mite not make sense to some, but I am quite pleased i've made this journey. I'm quite comfortable with my decision, Folly would be if she never gets finished, but I guaranty that won't happen. _________________ what a long strange trip it's been |
Posted: Fri Oct 07, 2016 10:20 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Installed Porshe 930 axel kit $899.95 and made a heat shield- air scoop of aluminum, Used other set of empty bolt holes, perfect. Running total $19667.56 [img][/img][img][/img][img][/img][img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Fri Oct 07, 2016 11:15 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Had to modify my base box to flush mount the speaker, work on speaker cover plate and fitting the bamboo flooring. Bamboo $ 40.00 RT $19707.56 [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
