vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Sun Oct 09, 2016 5:09 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Installed under floor wiring and installed floor. [img][/img][img][/img][img][/img][img][/img][/list] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 5:19 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Ground clearance, Ten inches. I think that will do. [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 5:25 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Heater and water system all installed. [img][/img][img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 5:41 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Here is a mod I saw on Samba. But it used PVC pipe with a slot to pop it on and off. I made mine out of one inch aluminum tubing. Fits perfect! Slips right over shock, not lose and not to tight. Cut a bit shorter than the length of the shock inner shaft. Unhook from van at the van, not the hatch. Slide on, reattach shock and your done. It lives right on the shock, no need to remove and store. [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 5:54 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
The hiding spot of my spare engine. 127000 miles runs like a dream. Hope I never need it. SVX $400.00 not added to running total. [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 6:18 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Another Samba idea. Used spray rubber on the under side of engine lid. Reflective tape on top. Two great ideas. Spray on rubber $18.95,reflectors $15.88. Total $34.83 RT $22828.73 [img][/img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 6:30 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
I cleaned the dash up and added a birch trim strip. [img][/img][img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 6:37 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Ducted snorkel to drivers side air intake. Instaled the tank from RMW $224.10 RT $23052.83 [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 6:49 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Gave Vino a different voice. I installed the duel horns from the SVX. [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 7:07 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Found a drink holder. A exellent fit hooked with one screw to the seat stop. It had a nice recess for my bass level control. Holder $5.99 RT $23058.82 [img][/img] _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 8:14 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
All new parts for the rear shift linkage, plus delren bushings from GW for the shaft guides. Ball lever on trans $19.00, Boot from trans to lever $9.95, Socket arm $40.95, Boot for socket $12.95, GW bushings $59.95. Total $142.80 Running Total $23201.62 [img][/img] _________________ what a long strange trip it's been |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sun Oct 09, 2016 9:08 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Dang.... I'm whupped just reading this!
Looks great! Inspiring. I like the engine compartment lid mod, great idea.
Awaiting the secret of the aluminum window blank...."will have hole"...hmmm, arrowslits in case your surrounded by menacing Winnabego's?!? Drive up coffee shack mean barista protection plate?..no? _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
rubbachicken Samba Member
Posted: Sun Oct 09, 2016 9:20 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
go buy heavy duty struts, i have a bent tail gate, a previous owner i guess forgot, and pulled down hard, it only lets water in now, when it's raining.
it's false economy, if someone else tries to shut your tailgate and does not notice the pipe on their, you will have the same issue.
vino de vano wrote: |
Here is a mod I saw on Samba. But it used PVC pipe with a slot to pop it on and off. I made mine out of one inch aluminum tubing. Fits perfect! Slips right over shock, not lose and not to tight. Cut a bit shorter than the length of the shock inner shaft. Unhook from van at the van, not the hatch. Slide on, reattach shock and your done. It lives right on the shock, no need to remove and store. [img][/img] |
_________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Sun Oct 09, 2016 9:49 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Thanks Alaskaberrys. It's been great to get to know each part up close and personal, but yes a lot of time and work. Good guesses on the window panel but not it. Hay Rubbachicken, Ya I thought of that so I put them on both struts, you would have to pull down really hard to do damage. Yours was most likely only on one, that can cause real damage. Thanks for the heads up though. _________________ what a long strange trip it's been |
Posted: Sun Oct 09, 2016 10:10 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
so now you need 3 hands to close the tail gate
Thanks Alaskaberrys. It's been great to get to know each part up close and personal, but yes a lot of time and work. Good guesses on the window panel but not it. Hay Rubbachicken, Ya I thought of that so I put them on both struts, you would have to pull down really hard to do damage. Yours was most likely only on one, that can cause real damage. Thanks for the heads up though. |
meet 'burni'
Posted: Mon Oct 10, 2016 9:18 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Sorry Rubbachicken, I should have explained that my struts are in good working order, and work as they should. I only plan to use them when it needs the extra support. I have the add a room for the rear, witch is hung from the hatch. I would prefer the hatch be solid when I use it for this. There easy to use with good struts, just lift a little, slide tubes onto body of strut. Close hatch as normal and away you go. Did you really think I would leave worn out struts on Vino? _________________ what a long strange trip it's been |
Posted: Mon Oct 10, 2016 9:53 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
The reason for my aluminum window filler is? It will have an opening two inch square, for the charcoal heater I made. It will sit on a insulated plate covering my sink. It works well but I would do it slightly different If ever make another. Not shown in pics are a bolt on elbow and two foot vertical chimney . [/img][img][/img]All air for combustion comes from out side van. _________________ what a long strange trip it's been
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Mon Oct 10, 2016 10:10 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Love this build and subscribed for more! |
Posted: Mon Oct 10, 2016 10:38 am Post subject: Re: restoration and modification and cost of my 87 Tin Top |
The reason for my aluminum window filler is? It will have an opening two inch square, for the charcoal heater I made. It will sit on a insulated plate covering my sink. It works well but I would do it slightly different If I ever make another. Not shown I pics are a bolt on elbow and two foot vertical chimney . [/img]All air for combustion comes from out side van. |
Ha! Your right, never guessed that! Hot water, cabin heat...looks like your ready to come north _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Mon Oct 10, 2016 4:33 pm Post subject: Re: restoration and modification and cost of my 87 Tin Top |
Thanks Aryana. I'm almost done with my catch up on Vino's build, and there is not to much left. But I'm vary glad you are enjoying the build. Hay Alaskaberrys. Nope not heading north, Vino is our summer ride, I just don't like cold at my age. _________________ what a long strange trip it's been |
