DeathBySnuSnu Samba Member
Posted: Mon Sep 12, 2016 8:12 pm Post subject: When to sleeve lifter bores. |
I have been running an eagle cam since 1981.
2110 (82 x 90.5) and 44's
The engine finally got tired and got a major rebuild.
Now a 2387 (86 x 94)
So it got a touch more cam.
Now here is the question.
It has run since the early 80,s with a 260 at .050 cam and no measurable lifter bore wear.
Does it need the be sleeved for the 270 at .050?
It is a cb magnesium super case from the same early 80's.
I am ready to go back together with it and before I close it up I want some opion about sleeve or not. No vw specific machine shop for many many miles. So it is ship it out or buy the tooling and do it myself. I was trying to avoid that and was one consideration for getting a cam that was advertised as 266 at .050. Cam came in bigger than expected. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Mon Sep 12, 2016 8:54 pm Post subject: Re: When to sleeve lifter bores. |
I've been running a magnesium case for over 10 years with several camshafts: Engle W-120 & FK8, Web 86C, 226 & 251 and now Raptor 6908. No issues with the lifter bores yet. IIRC, at some point the mag cases received thicker lifter bores...not sure which year that change was made. Do you have pictures? _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Mon Sep 12, 2016 9:08 pm Post subject: Re: When to sleeve lifter bores. |
The most direct on pic I have of the lifter bores.
jason Samba Member
Posted: Mon Sep 12, 2016 9:31 pm Post subject: Re: When to sleeve lifter bores. |
If its in spec leave it. My brother is running that cam with some heads Jeff Denham reworked, lots of power. |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Mon Sep 12, 2016 9:40 pm Post subject: Re: When to sleeve lifter bores. |
i agree those bores look good. one thing to also look at is depending on what lifters you run some are different thickness and can fine tune the lifter to wall gap. are you also planning on giving the lifters the hoover? _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
mark tucker Samba Member
Posted: Tue Sep 13, 2016 10:03 am Post subject: Re: When to sleeve lifter bores. |
be skeerful drilling that it needs to be done at an angle from the bearing side then a short connector from the lifter side. I dont think you need to sleeve them for that cam .I wood however make sure there are no burrs on the lifters any where and deburr the cam lobes good on the edges. Ive seen w100 kill lifter bores so...it's always a crap shoot it seems.( allthough that guy likes tooling around in 4th at 18-20 mph)with a fleawayfrier trani. you might also go with some 1.34 ratio rockers too. |
Posted: Tue Sep 13, 2016 11:12 am Post subject: Re: When to sleeve lifter bores. |
Yes Mark. That is an old pic, the oil holes are all drilled and yes the one from cam bearing saddle to deep drilling had the be angled.
Cam is deburred, i will give the lifters an extra check.
I have the engle cam kit. The lifters are a bit on the heavy side but look real nice and slick.
It is full hoover and external regulator too. Full flow with no thermostat.
Have a 30mm pump set tight with steel cover.
Hope to run a lot of flow with thin synthetic oil, something like 5w30 or so. I do tend to putt around lugging it. 850lb vehicle with 3.44 ring and pinion. |
58ragman Samba Member
Joined: September 29, 2014 Posts: 404 Location: OC to ontario
Posted: Wed Sep 14, 2016 8:40 am Post subject: Re: When to sleeve lifter bores. |
when is the determination for a bronze sleeve versus a aluminum sleeve needed.In what applications are the aluminum sleeve used versus bronze sleeve.All I heard of is to bronze sleeve but i seen in some that aluminum sleeve is used like rimco |
Posted: Wed Sep 14, 2016 9:45 am Post subject: Re: When to sleeve lifter bores. |
rimco uses whatever is cheep. I would stay away from rimco, far far away. Ive seen steel sleeves that liked like holy shit on a squashed banana peal raper round with chromed dog poop for a topping. |
Posted: Fri Sep 16, 2016 6:40 pm Post subject: Re: When to sleeve lifter bores. |
Well....
Prepping it up, going together not sleeved.
You know Mark.... you may be right about checking lifters.
I bought a set one time and when I got them and looked, the surface finish was way to rough for my liking. I just did not use them. Got a set that had a nice slick ground finish. Makes you wonder if..... |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Fri Sep 16, 2016 10:54 pm Post subject: Re: When to sleeve lifter bores. |
the duration isn't necessarily hard on the bores, it is the ramp of the cam, CB cams tend to have mild ramps compared to engle. _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sat Sep 17, 2016 4:44 am Post subject: Re: When to sleeve lifter bores. |
Having too much valve spring pressure is what tears up lifter bores, not the cam. The push rods are at a slight angle and the valve springs puts excessive side loads on the lifters causing the wear. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sat Sep 17, 2016 2:15 pm Post subject: Re: When to sleeve lifter bores. |
vwracerdave wrote: |
Having too much valve spring pressure is what tears up lifter bores, not the cam. The push rods are at a slight angle and the valve springs puts excessive side loads on the lifters causing the wear. |
Some would argue that not having ENOUGH spring pressure has caused more valve train failures than having too much. Personally I'd rather err on the "too much" side than not enough.
Going from the Eagle cam you had been running to the FK-10 should be a nice bump in performance. Provided you have the heads, exhaust, induction to do it justice, it should kick a--; FK-10 is a great street cam.
On the subject of lifter bore sleeving... It is a fairly new thing to do, like in the last 5-7 years or so, has it become "popular". I think it's usually not needed. I did it to my "new" case just because I could. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Posted: Sat Sep 17, 2016 3:25 pm Post subject: Re: When to sleeve lifter bores. |
I dont know what I did with those that had flat spots from the centerless grinder and the lifter not spining all the time.. they were a real mess...gess where they came from???CIP1!!! I always inspect then polish around the head in my lathe to remove any roughness(and sometimes exsessive useless material) and then polish the body good. and always check the face for nicks&burrs too. it isant toe spring pressure that does it. although coil bind can&will do it as can rocker cup to pushrod interfearance and or push&tube interfearance. as well as a moron assembling it. |
Posted: Sat Sep 17, 2016 6:06 pm Post subject: Re: When to sleeve lifter bores. |
Don't mean to hi-jack this thread, but... I've noticed that around the oil holes in the lifter sleeves I had installed are some burrs that should be knocked down. However, getting in the lifter bore to de-burr it without nicking any other part of the bore could be problematic. Suggestions? _________________ Please check my '67 sedan project progress!
Posted: Sun Sep 18, 2016 11:23 am Post subject: Re: When to sleeve lifter bores. |
pencil die grinder with carbide ball end. and dont wory about a knick or 2. I would also add some grooves if needed for full time top end oiling. |
