reithi Samba Member
Posted: Tue Nov 08, 2016 11:58 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
With an airtight scoop, the shroud will probably be unnecessary.
I will give it a try once I layout the coolant pipes....which is another project on its own.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Wed Nov 09, 2016 12:57 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
This is great reading.
Subscribed! _________________ nothing |
Ives676 Samba Member
Joined: June 20, 2013 Posts: 274 Location: Rogers, AR
Posted: Fri Apr 07, 2017 9:50 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
reithi wrote: |
I will give it a try once I layout the coolant pipes....which is another project on its own. |
Any updates to share with us? _________________ 1974 Riviera - Subaru EJ22
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630031 |
Convoy Samba Member
Joined: March 17, 2011 Posts: 312 Location: San Clemente
Posted: Thu May 04, 2017 11:57 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
Updates? |
reithi Samba Member
Posted: Thu Aug 03, 2017 1:05 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
It's been a while since I last posted. I have been busy with work and other projects.
That said, I started with brackets to mount the radiator to the chassis. They are made from 1.8mm Galvanised Sheet off cuts that remained from the passenger floor. The brackets are folded half inch in opposite directions for increased strength and less flexing.
reithi Samba Member
Posted: Thu Aug 03, 2017 1:16 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
Finally got the radiator mounted using the stock holes for the belly pan.
It is suspended with bushes between the radiator and chassis to dampen fan vibrations.
reithi Samba Member
Posted: Thu Aug 03, 2017 1:20 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
Next up are coolant pipes.....I will first use plastic plumbing pipes and bends as templates for bending the stainless steel pipes.
Thanks for the support. |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Thu Aug 03, 2017 7:40 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
reithi wrote: |
captincanuck wrote: |
So you aren't worried about reducing the surface area of your rad by sealing it up that tight? Looks mighty nice thou. Will be interested to see how it performs |
Thanks Captincanuck.
Good question. Shroud or no shroud? Tough question. When the bus is moving the shroud with limit airflow. Without the shroud, the fan will have to work harder in traffic.
The plan is to fit it on the bus and see how it performs. If it doesn't work out, I will remove it. I guess since the scoop is airtight, it won't make a big difference. |
No shroud now I see? Your setup looks very close to mine and several others here so I will share somethings I have noticed that might make you want to reconsider your air flow setup.
On the go cooling is great. Fans never come on when on the highway or cruising around town.
Stopped if the fan does come on, it cools down the temp at an acceptable rate and then turns off. (No problem yet)
Where I think you will see a problem could be if the fan needs to come on when on the highway (AC on, climbing a mountain, crazy hot outside temps).
What I notice is that when the fan comes on, the air is deflected by the floor, forced back through the rad and out the front of the scoop.
This would obviously mess up your air flow at speed. (Unless you are leaving it with no floor, than it should work great )
Give it a shot and see if you see the same thing happening. I will probably redesign mine over the winter, adding a shroud or redesigning to air in from the top and out the bottom with a pusher fan. No real traffic or much heat over 30C up here so hasn't effected me much yet. _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
reithi Samba Member
Posted: Sun Aug 06, 2017 7:31 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
That sounds like hot air is recirculating through the radiator core. There are two ways to fix the problem.
1) Shroud
2) Scoop or deflector behind the radiator to direct hot air away from the floor.
I have the perfect hill to take it in a couple of weeks. It's about 5 miles long steep climb with no turns. |
Bansheelos Samba Member
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Aug 07, 2017 9:25 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
My radiator is scooped from below, with a puller fan above.
I've gut a chunk of plastic sheeting keeping air from blowing down through the radiator from above. It is just from the top edge of the radiator to the underside of the floor.
On my drive to and through Colorado this past week, it did well. Climbing up the passes at somewhat low speeds (following older buses) so high power, low airflow the hottest I saw the engine was about 212. Best I can tell, VW says 220 is the hightest as is "normal" for a TDI so that was pretty good. I did have the fan running up those climbs and sometimes turned the heater on. _________________ Dave Cook
1973 Wild Westerner
My Thing |
reithi Samba Member
Posted: Sat Aug 19, 2017 12:38 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
vwwestyman wrote: |
I've gut a chunk of plastic sheeting keeping air from blowing down through the radiator from above. It is just from the top edge of the radiator to the underside of the floor. |
That is the missing link on my setup Dave. I will have to drive it through torturous hills where I live before changing anything. |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Fri Oct 13, 2017 9:33 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
What temps are you guys noticing your fans coming on ? I blew over my header tank overflow (on manifold) the other day while just idling in the driveway. I must still have bubbles in the system or just need a better rad. The one I have on there now is a Visteon-Sprint-Cup NASCAR-Oilcooler I turned into a radiator. 1.5" thick. Think I should go up to a 3" one ?
Old pic for ref:
_________________ My '65-Subaru EJ20 Turbo conversion |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Fri Oct 13, 2017 10:00 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
Mine kick on around 90C/195F... |
panel Samba Member
Posted: Sat Oct 14, 2017 8:18 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
tristessa wrote: |
You have one or two fans?
Tricks for bleeding ? _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sun Oct 15, 2017 7:26 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
Two fans but they're wired in parallel to come on together. Never had any real trouble bleeding after I realized the front heater was higher than the motor and added an expansion bottle in the glovebox; fill the system, run it until the thermostat opens, shut it off to cool, top off. |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Sun Oct 15, 2017 9:26 am Post subject: Re: Need Your Help- Underbelly Radiator Design |
panel wrote: |
...I blew over my header tank overflow (on manifold) the other day while just idling in the driveway. I must still have bubbles in the system or just need a better rad. The one I have on there now is a Visteon-Sprint-Cup NASCAR-Oilcooler I turned into a radiator. 1.5" thick. Think I should go up to a 3" one ?
My guess would be that you need a radiator, not an oil cooler.
I don't understand why you would even consider using a smaller radiator meant for oil than a larger radiator meant for engine water coolant _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sun Oct 15, 2017 3:43 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
Air_Cooled_Nut wrote: |
I don't understand why you would even consider using a smaller radiator meant for oil than a larger radiator meant for engine water coolant |
wow...
yea, oil cooler designs are way, way different than that of a radiator. I would ditch that an buy a real radiator. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
panel Samba Member
Posted: Mon Oct 16, 2017 2:48 pm Post subject: Re: Need Your Help- Underbelly Radiator Design |
Thanks for the input etc.......like to get a 2 to 2.5" thick but might have to get a 3" as that seems the only one available. Should the 19 x 22 be ok then ? _________________ My '65-Subaru EJ20 Turbo conversion |
Sloride Samba Member
