Bills85Westy Samba Member
Posted: Sun Sep 18, 2016 5:37 pm Post subject: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
This is the process used to extend the sliding door rear hinge to clear larger/wider tires on later vans. I thought I would share it for the benefit of others who would also like to make this modification.
Some Vanagon vendors used to sell the modified hinge. Even with the hinge, the track on the van will still need to be modified for this to work.
Some other threads on the Vanagon forum mentioned a guideline on the Brick Yard website, but the link is bad. Using internet archive, I was able to see this guideline and get a better understanding of the process, but the photos were small and difficult to really get a clear picture (no pun intended) of the various steps.
On my van, the tire barely rubbed the bottom lip of the door panel, but it was enough that I had to close the door if I wanted to move the van or drive with the door open.
This mod is for the late hinge. The late hinge is from chassis number WVWZZZ25ZFH000000 1985 model year onward. I've never personally inspected an early van so don't know quite how that compares.
There is a stop at the front of the sliding door track that causes the hinge to turn 90 degrees and bring the rear of the door into the van. The basic principal is that whatever dimension you want to extend your hinge, you need to move the stop towards the rear of the van that same distance. Searching threads, I read that people were extending hinges from between 1 1/2" to 2 1/2". I chose 2" because it would give me ample clearance for what I wanted. So, I needed to lengthen my hinge exactly 2" and I needed to move the stop backward exactly 2".
To do this, you'll need a spare hinge to cut apart and use. There are usually some for sale on the Samba Classifieds. I have a couple of parts vans so I pulled one from an 87. The are supposed to be the same, but I did find a difference......more on that later.
You'll need general hand tools, a grinder with cut off wheel, a blunt nose punch and hammer, a welder, & paint. I used a 4 1/2" Makita with thin kerf cut off wheel and second with a flap disc to clean things up. I also used a Dremel with small Forney cut off wheel to get in for the tight areas.
General steps were as follows.......
1. Remove the sliding door hinge cover. There are two phillips screws: one at the front and one at the rear accessible from underneath. Mine was really caked on with dirt. I wiggled the bottom in and out until it started to work it's way loose. I was able to use the heel of my hand to "hammer" upward on the bottom edge until it came loose. Set it aside.
2. Remove the interior door panel. There are two Phillips head screws at the rear of the panel and you need to remove the interior slider handle (also a Phillips head screw). I use a Restorer's Prybar because it has a thin edge to slip between the door and door panel to pry out. I place the prybar right next to the fastener and pry out till it pops. I also have a door panel removal tool, but like using the prybar better. Set it aside.
3. Remove the rear hinge. I used a 5 gallon bucket with various pieces of scrap lumber on top to support the rear of the door. There are two 13mm bolts accessible from outside the van at the rear of the door and one accessible from inside the door. Make sure the door is supported because it will come down in a hurry when you loosen those bolts! I also had to climb in and out from the front passenger door once I had the door loose. I had it open about 6" inches so the hinge would be perpendicular to the van and I would still be able to move the door to get access to the front bolt.
4. Protect your van! I used cardboard and red tape (I'm in the construction business and we use red tape a lot to protect because it holds well and doesn't leave a lot of residue behind). In this photo, you can see that I've protected all around the front of the track to be modified. You can also see where I've marked where I'm going to move the hinge stop back 2".
A general overview of the work area:
5. Carefully remove the hinge stop and the rail.
You will ONLY want to remove the part of the rail that it in the way to move the stop rearward. You WILL WANT to leave the bottom rail in place along with the attachment for the hinge cover. You will see in this photo that I cut the back wall of the rail down, but needed to come back later and trim it down further to accommodate the 2 guide roller chassis when it turns.
6. Once you get the rail out of the way and are ready to move the hinge stop backward, you'll realize that you've got some body work in the way. You'll need to "massage" the body where the stop needs to mount inward to accommodate the stop. For this, I used a alb hammer and a large non-hardened punch that I shaped into a blunt rounded shape. I was able to get the general shape I wanted in just a few minutes. The rail is welded to the van right at the this location and I created a small tear along the sheetmetail right at the rail. I used 3M seam sealer purchased from the local automotive paint supply house to seal along this tear.
You will want to seal and paint this area before you weld the stop back into place. because this won't be accessible later.
If I was fully painting this van & had it stripped, I would probably have cut this section out of the donor an and reinstalled it here. There was no need for me to go that deep here....
7. You'll need to clean up the hinge stop to fit on your new modified rail. This is what the sandwich looks like welded together.
and cut apart.
I used a flap wheel to grind away the weld until I could see the joint between the two pieces and split the two pieces apart. I then cleaned it up so I just had the stop. I dry fit this onto the rail and made sure my clearances were still correct.
8. Clean the rail where your new welds are going to be. I spot welded the stop in place, checked my alignment and then came back and welded in between the spot welds. Not too pretty, but I got good penetration and it's strong.
9. Extend the hinge. I used the front of my hinge and rear of the donor hinge. I suppose you could cut a hinge and add a section, but this was a lot easier and only required one weld instead of two. I use a Hobart 140 Mig solid wire with gas. Here is the hinge extended and welded together.
I took my time grinding the weld and I use a flat file to do the final dressing so that the finish would be smooth. This is the one critical area where your poor (or good) welding skills will really show!
After I cleaned up my welds, I wire brushed, sanded and painted it.
Here is a view from the side showing how I trimmed back the rear rail wall to make more room for guide roller chassis.
10. Clean up and paint your hinge. I used a regular satin anti-rust slow dry paint over autobody primer. I also took the opportunity to really clean up the rollers and other parts of the hinge. Luckily, all my rollers were in really good shape.
11. Reassemble the hinge. Here is the hinge all back together and ready to reinstall....
12. Now it's time to put it all back together! Here is a photo fitting the modified hinge:
You will want to make sure your have the back of the door exactly where you want it positioned as you tighten down those bolts. Mine went back in exactly the same spot. There were witness marks from the washers. I installed it right back into the same place.
I did run into an issue with the rear lock strike. The door opened and closed perfectly, but if I closed it fast, the rear of the door wouldn't seem to come in fast enough and I would get a rub on the strike bar bolted to the rear door jamb. It only occurred when closing the door fast. Some head scratching and looking at the 87 donor van showed me that VW apparently lengthened the strike at some point in production.
The top (shorter strike) is the 85.
The bottom (longer strike) is the 87
After installing the longer strike, I haven't had any more issues.
My van was missing the flexible bumper in the stop, but the parts van had a serviceable one.
Make sure you have all the proper bushings, washers and parts!
Here is a photo of the new clearance to the rear tire....
And a photo of the installed hinge with the cover reinstalled....
And overall.....
I hope this is helpful to others in the future. I didn't find the work difficult, but there were a few times where I had to take some time to think through the steps to make sure everything was considered.
Also, remember to disconnect your battery when welding on your van! _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
Eric_Taylor Samba Member
Joined: January 21, 2011 Posts: 291 Location: Bend, Oregon
Posted: Sun Jul 14, 2019 2:16 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
Looking at options to fix the tire rub and came across this thread. Looks like a well done idea, but way above my abilities. Any adjustments folks recommend or is this the best option? |
Posted: Sun Jul 14, 2019 3:45 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
For options, you could look into wheel offsets, but with the tire size i'm running 225/75 R16 you are constrained between the flange on the rear control arm and the door. If you aren't running as wide a tire, a tire with a different offset can push the wheel & tire inboard & avoiding the rub.
I found Christopher with T3 Technique to be a wealth of knowledge and always willing to make recommendations.
Good luck! _________________ 89 Tristar Syncro Doka - White
kuecker2 Samba Member
Joined: September 13, 2019 Posts: 71 Location: Kansas City
Posted: Tue Oct 15, 2019 10:12 am Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
I am going to a 15" tire. And have an 84? It seems like the 84 does not need modification. Does anyone know if this is correct? EDIT: I added a photo. Does it look like this is sufficient clearance?
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6358 Location: Honolulu,Hawaii and France
Posted: Tue Oct 15, 2019 10:32 am Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
kuecker2 wrote: |
I am going to a 15" tire. And have an 84? It seems like the 84 does not need modification. Does anyone know if this is correct? |
Correct, just extending the arm. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Tue Oct 15, 2019 12:33 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
ALIKA T3 wrote: |
kuecker2 wrote: |
Correct, just extending the arm. |
And extending the strike point for the hinge pivot by a like amount. A long bolt with two nuts is all that's needed to do that. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
tjet Samba Member
Posted: Tue Oct 15, 2019 12:35 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
I need to do this modification as well.
Something to keep in mind when you make your measurements: the needed clearance will grow as you move the door farther aft (open). This would be for an extreme case.
Thanks for posting this thread! |
Posted: Tue Oct 15, 2019 1:38 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
Christopher Schimke wrote: |
ALIKA T3 wrote: |
kuecker2 wrote: |
And extending the strike point for the hinge pivot by a like amount. A long bolt with two nuts is all that's needed to do that. |
So the added photo is enough clearance do we think? |
xclemjustinx Samba Member
Posted: Tue Oct 15, 2019 6:53 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
ALIKA T3 wrote: |
kuecker2 wrote: |
Do you have pics about this? I would love to get about half an inch for better tire clearance. Thanks. |
WTGPhoben Samba Member
Posted: Thu Jul 22, 2021 5:57 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
Bills85Westy wrote: |
Since the rail effectively needs to be made shorter, wouldn't it be possible to simply add a block of material inside the stop (say, by threading a hole in a little block of aluminum and bolting it into the stop via the slot on the end) rather than chopping up the rail? I'd love to have some more tire clearance but I don't know if I could bring myself to hack up my bodywork with an angle grinder... _________________ '85 Full Camper #westyjanefonda |
Posted: Thu Jul 22, 2021 8:24 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
WTGPhoben wrote: |
Since the rail effectively needs to be made shorter, wouldn't it be possible to simply add a block of material inside the stop (say, by threading a hole in a little block of aluminum and bolting it into the stop via the slot on the end) rather than chopping up the rail? I'd love to have some more tire clearance but I don't know if I could bring myself to hack up my bodywork with an angle grinder... |
The problem with that is that the end of the rail turns 90 degrees as noted by the two rollers. I think there is only one way to do this right. Feel free to reach out via PM if you want to discuss in further detail.
For what it’s worth, here I am years later and it still works perfectly!
Bill _________________ 89 Tristar Syncro Doka - White
DORIGTT Samba Member
Joined: October 01, 2003 Posts: 257 Location: Forest Grove, OR
Posted: Sun Aug 21, 2022 6:40 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
So I don't have to buy a second hinge to cut up, can anyone tell me if the hinge "rod" is solid or hollow? _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
Posted: Sun Aug 21, 2022 6:50 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
DORIGTT wrote: |
So I don't have to buy a second hinge to cut up, can anyone tell me if the hinge "rod" is solid or hollow? |
It's solid, just have a piece of rod turned in a lathe _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun Aug 21, 2022 7:07 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
That's what I was thinking. 18mm is what I measured. I'll have something made up so I can get this damned door all the way open. I'm too 'grown-up' to easily squeeze in all the time. _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9613 Location: Western WA
Posted: Wed Jun 07, 2023 12:59 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
ALIKA T3 wrote: |
DORIGTT wrote: |
It's solid, just have a piece of rod turned in a lathe |
I can't think of a good reason that the extension piece has to be a solid bar.
This would be an attractive mod if all you had to do was change to a longer link.
My door simply touches the tire and slides right past, I cannot even feel it.
So I'm gonna let it be. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu Jun 08, 2023 12:03 pm Post subject: Re: Sliding Door Hinge Modification For Tire Clearance 1985 & Later |
There's a lot of thrust into that U, at 20mm OD, you would need a tube with very thick walls, might as well go solid rod. For manufacturing purposes, bending a tube in a U shape would make the outer radius wall thinner. So, solid they went.
My machinist makes the U's for me, machining a piece of metal rod is easy for him, and it's like factory, why bother? _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
