Does your steering lock work? |
Yes! |
85% |
[ 69 ] |
No! |
13% |
[ 11 ] |
Not sure/what's a steering lock? |
1% |
[ 1 ] |
Total Votes : 81 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Wed Dec 09, 2020 10:54 am Post subject: Re: Does your steering lock work? Yes or No… |
Mine works.
It was a bit of a nerve wracking moment when I told the tow truck driver it worked, as he towed my bus by lifting the rear wheels on a frame behind the tow truck and then towing it backwards on the front wheels with just the steering lock holding it straight.
That was the day I had a piece of the engine case in my pocket, where the conrod had gone through the top of the case and knocked a triangle out.
It was towed about 3 miles through several road junctions, including mini-roundabouts (left-right-left chicanes about 30 feet across)
My horn and ignition switch also work as intended. _________________ Ancient vehicles and vessels
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Wed Dec 09, 2020 12:12 pm Post subject: Re: Does your steering lock work? Yes or No… |
Mine locked when it wasn't supposed to!
It locks properly now...thanks to Skills!! _________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Whaanga Samba Member
Joined: May 07, 2016 Posts: 629 Location: Rochester, NY
Posted: Wed Dec 09, 2020 8:51 pm Post subject: Re: Does your steering lock work? Yes or No… |
I’m a little late to the game here but No, mine does not work. I have never looked into why it’s inoperable. How does one evaluate the reasons it doesn’t work? I assume the mechanism is housed at the base of the steering wheel. Also - I don’t have the original ignition switch - might this have an effect? Will I see the mechanism if I remove the blinker housing? _________________ Late 1973 Bay w/a transplanted 914 Engine
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Fri Dec 11, 2020 1:32 pm Post subject: Re: Does your steering lock work? Yes or No… |
The lock only works when a pin operated by the lock engages with (I think) one of two holes drilled in a collar welded on the central column. On my 1973 style steering column, the pin is behind the lock mechanism.
So the steering normally does not lock unless you rotate the steering wheel after locking the ignition switch and removing the key, the pin springs out.
Then because you have twist in the tyres from turning the steering wheel while the bus is stationary, it holds the pin tightly in the hole and prevents you turning the ignition key ... _________________ Ancient vehicles and vessels
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Sun Dec 27, 2020 10:19 am Post subject: Re: Does your steering lock work? Yes or No… |
Alex6373 wrote: |
The steering wheel lock on my 1973 Westfalia camper works but I unpluged the annoying buzzer! |
British specification 1973 VW Type 2 Westfalia campers like mine, are not equipped with buzzers; of the annoying variety or otherwise! My steering lock never worked for many years until I discovered that the plastic collar prevented the steering-lock pin from engaging. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
