Whaanga Samba Member
Joined: May 07, 2016 Posts: 623 Location: Rochester, NY
Posted: Wed Sep 21, 2016 7:04 pm Post subject: Tin around alternator |
Recently SGKent has helped me work through the missing cooling flaps/thermostat on my 73 Bus. He pointed out the tin near the alternator is not complete as seen in the photos. I'm looking for a photo of how this tin looks when set up properly.
Thank you.
Tcash Samba Member
Posted: Wed Sep 21, 2016 7:28 pm Post subject: Re: Tin around alternator |
Alternator Type IV (4)
Tcash
Posted: Wed Sep 21, 2016 10:18 pm Post subject: Re: Tin around alternator |
There are two different designs of plastic seals that fit around the alternator. The seal you use needs to match the tin you have. Check the classified or a wrecking yard for both the seal and its matching tin. |
Bleyseng Samba Member
Posted: Thu Sep 22, 2016 5:54 am Post subject: Re: Tin around alternator |
You missing the large flat plastic seal for the alt. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
nerdhotrod Samba Member
Posted: Thu Sep 22, 2016 8:31 am Post subject: Re: Tin around alternator |
Whaanga wrote: |
Thank you.
Im not proud of the solution... but i have mine tin tapped at the moment until I can find NOS parts to complete both of the seals.
Id suggest you get something there as a temporary solution. The alternator to engine tin seal has been impossible to find. |
SGKent Samba Member
Posted: Thu Sep 22, 2016 8:44 am Post subject: Re: Tin around alternator |
you might be able to straighten the tin a little around the oval hole then use one of these for that hole. The larger one takes the plastic. There are multiple styles of tin and I don't know which will fit the best.
http://www.thesamba.com/vw/classifieds/detail.php?id=850977
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Sep 22, 2016 9:12 am Post subject: Re: Tin around alternator |
If your alternator tin takes the flat seal, you can make a pretty good substitute for the OEM seal out of the plastic from the side of a gallon antifreeze or oil jug. |
LeeE Samba Member
Posted: Thu Sep 22, 2016 10:10 am Post subject: Re: Tin around alternator |
Here's a crude template. It's in the Samba gallery.
You should be able to print it on 8 1/2 x 11 paper
I made one from a Coleman fuel can. _________________ 1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp |
Posted: Thu Sep 22, 2016 2:58 pm Post subject: Re: Tin around alternator |
Thanks for the advise and drawing. Very helpful indeed. |
SGKent Samba Member
Posted: Thu Sep 22, 2016 3:15 pm Post subject: Re: Tin around alternator |
I copied this from one of the links TCash already provided. It is the section that pertains to the question of the tin. The link is up above. It is well worth reading when it comes time to work on the alternator and tin.
Tcash wrote: |
That would be one of them. By the looks of it there are two to pick from depending on which alt. cover plate you have. Maybe someone has some pictures of the two different cover plates.
Correct me if I am wrong.
Left=55 amp cover plate. 72-75
Right=55&70 amp cover plate. 76-79
vw76westy wrote: |
i know that this is the plastic gasket
that gos between the alt and engine tin
but where, how does this gasket go ???
is one for the 55amp and the other for 70amp ??
or does one go behind the other |
germansupplyscott wrote: |
the top one is '76-'79, the bottom one is '72-'75. |
022 903 203 Alternator seal
Quote: |
Karl wrote:
Question: Does anyone know if this is the correct p/n for the tin-seal-ring for an alternator 022-903-203?
Yes, IF you use it with the replacement 022 alt cover plate. The 021 plate used a different plastic seal ring. If memory serves me: the 021 plastic ring has a raised edge on it to fit in the hole. and is NLA. The 022 ring is flat and has a locking 'tab' to hold it in place at the upper adjustment bolt. The big hole is 2 different sizes between the 021 and 022. You cannot mis-match the rings......
From the Bus Boys site:
K. 021-119-281U Alternator Coverplate, Used 1972 to 1974
K. 022-119-281 Alternator Coverplate, New 1972 to 1979
Note: When using the 022-119-281 plate as a replacement on 1972 to 1974 models, the plastic gasket for the Alternator must be replaced with newer style - order 022-903-203. |
72-75
Adjustment cover plate - 021 119 295
Alternator sealing ring and adjustment cover plate
lostorbit
A couple of NLA parts that are hard to find. Luckily, I scored both from The Samba classifieds.
Part numbers in case you're looking for some:
Alternator Seal - 022 903 203
Custom Bus Alternator Coverplate
Posted: Sat May 27, 2017 7:40 am Post subject: Re: Tin around alternator |
I made this post last year and appreciate the feedback. I'm in the middle of a project - pulled the engine and tranny as seen here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=677577&highlight=
While doing the work I removed all the engine tins to clean and paint. I also made a gasket per advice received here. I made mine from a plastic lid for a storage bin. Does look like it will work?
Posted: Sat May 27, 2017 8:59 am Post subject: Re: Tin around alternator |
What you have is okay. The hole would ideally have been a bit larger to fit around the shoulder on the face of the alternator. Can't say how well the plastic from a 5 gallon bucket will last over the long run, but it should do well for the short run. The reason for going with an oil or antifreeze jug is that the industry has standards the plastic used in those jugs is supposed to meet. |
Posted: Sat May 27, 2017 11:57 am Post subject: Re: Tin around alternator |
The engine is still out so it's easy to change this.
The material from an oil container or antifreeze jug is much thinner
than what I used. You're right, the inner circle needs to be larger to match that found on the alternator. Will probably use the one I fabbed as a template
and look for some more durable material. |
