Posted: Tue Oct 29, 2019 11:35 pm Post subject: Re: 1978 heater box - Heat Dump Tubes with pictures. |
Maybe by aiming the dump tubes out the back it creates enough thrust to increase the vehicle speed by .017% on a 6% grade. |
jlrftype7 Samba Member
Posted: Wed Oct 30, 2019 7:31 am Post subject: Re: 1978 heater box - Heat Dump Tubes with pictures. |
Wildthings wrote: |
Hah Hah... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
sblu Samba Member
Joined: April 08, 2019 Posts: 95 Location: Austin, TX
Posted: Thu Aug 27, 2020 9:06 pm Post subject: Re: 1978 heater box - Heat Dump Tubes with pictures. |
[quote="aeromech"]Here's some on a 1978 bus I flipped a few years ago
Folks, (and all credit to the original poster for the pic), but whats the name and part number for this 'gray pipe'. where can i buy this and the corrugated tube (guessing that one is called the heat dump pipe). _________________ 1978 Westfalia Champagne Edition Project |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Fri Aug 28, 2020 2:58 am Post subject: Re: 1978 heater box - Heat Dump Tubes with pictures. |
Didnt think much about this since Crusher is a 77 and has the domed head type. But after seeing Colins old post about cutting the head off and retro fitting some flex tubing to it, am gonna do that. This bus will be running around the Sierras and Moab area next summer. I forsee boiling fuel or pump failure without it. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
SGKent Samba Member
Posted: Fri Aug 28, 2020 11:10 am Post subject: Re: 1978 heater box - Heat Dump Tubes with pictures. |
Jetfxr69 wrote: |
Didnt think much about this since Crusher is a 77 and has the domed head type. But after seeing Colins old post about cutting the head off and retro fitting some flex tubing to it, am gonna do that. This bus will be running around the Sierras and Moab area next summer. I forsee boiling fuel or pump failure without it. |
we have a 1977 that sees high temps - never a problem. I think the folks who would be affected most would be people stuck in Phoenix or LA traffic in hot weather.
That said, the trans gets hot enough to melt bearing cages inside of an 091. Dump tubes probably help with that too. Those tubes may have been a response to smog laws too in order to slow volatilizes from evap. If you have a solid lifter cam I have read they get in the way of valve adjustments. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
