Yikes! I bought a '74 Super!!
Page: Previous  1, 2, 3 ... 20, 21, 22 ... 47, 48, 49  Next
vamram Premium Member
vamram is offline
PostPosted: Wed May 31, 2017 5:40 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Tim, I measured it on two different driveways and got pretty much the same results. I *think* the driveways were pretty flat. I may take it to a 3rd before I actually break it down again.
To reiterate, it's Definitely a softer ride than the urethane bushings. Anybody need a set of spring plate/torsion bar red urethane bushings? Yours for the price of shipping!
Victor
Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
vamram is offline
PostPosted: Sun Jun 11, 2017 1:02 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
I have a couple of updates, about the height and the timing.
Finally got the rear height fixed, I think.
And I swapped in the 5.5" sport rims for the rear and I like the stance much more than with the 4.5" rims. The "new" rims fill out the wheel well very nicely I think. Oh - and I decided to go w/the Silver rims rather
than matching the car's Marina Blue. That might change in the future.... Smile
I have one problem though that I hope someone w/more knowledge can chime in on: I stripped two of the spring-plate cover bolts on the left rear. I think they were pretty much shot anyway, but this 3rd reset did them in. I was hoping only the bolts were stripped and picked up a set of replacements from Top Line rated at 12.x strength, but it turns out that the frame threads are stripped. I could get new bolts turned in hand tight w/the ratchet but when I tried to torque them down the bolt ended up turning in the hole w/out ever locking down. There's only room to put a nut in back on one of these because the structure of the frame doesn't allow access to the top two, and one of the stripped ones is up there.
Is there a way to "chase" these threads so that the new bolts can actually grab and hold? Or am I stuck w/a spring plate only held on w/only 2 fully torqued down bolts? Crying or Very sad
As for the timing, I'm using a rebuilt 205c DVDA I bought from Bill, running it as an SVDA since my Bocar doesn't have the bigger throttle plate hole needed for the DVDA. I had timed it at 7.5*, but decided to do the 009 style hoses-plugged max- advance to 30* @3.+k RPM. After setting it this way, the idle timing jumped to 13.6*, total advance w/the advance host connected 36*. I know the advice on here when timing to max advance w/the hoses plugged is to let the idle timing fall where it will, but this seems high. I left it though, because the max advance I'm getting WITH the vacuum advance connected is 36*. Only 6* of advance seems a little low...
Any suggestions on the stripped threads or the timing?
Thanks!
Victor
Click to view image
Save the Supers!!
calvinater
calvinater is offline
PostPosted: Sun Jun 11, 2017 1:12 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Loctite/permatex makes a thread repair /restore kit. (PC 3967 ). Says max torque 12mm grade 8.8. 193 inch/pounds. "Use only on 8.8 metric ". Doesnt sound strong enough. ? Just a thought.
"Albatross"!
calvinater
PostPosted: Sun Jun 11, 2017 1:16 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Nah. Forget that stuff too weak. My bad
"Albatross"!
Rome
Rome is offline
PostPosted: Sun Jun 11, 2017 1:27 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Looks much better this way- the wide wheels offset the "top heavy" look with the large late bumpers. My preference also. Stick with the silver color for the rims...
As to the torsion bar cover stripped holes in the frame- although I don't have direct experience with your situation, most likely the 2 best possibilities will be to either drill and tap the frame to fit an oversize bolt (M12) which has the same length as your M10 original, or drill and tap a helicoil to use the original M10x1.5 thread size. If going for an M12 bolt, use the factory original 25 lb.ft torque rating.
vamram is offline
PostPosted: Sun Jun 11, 2017 2:34 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Rome, what about using an M10 x 1.5 thread chaser like to fix them?
Or do I need instead an M12 chaser? And if I go up to M12, can I open the whole w/an M12 thread chaser or does it have to be drilled open 1st?
This place seems to carry both, but I'm not sure how I'd reach two of the holes and be able to turn the chaser.
https://drillsandcutters.com/carbon-steel-hand-tap-sets-metric/
Click to view image
Save the Supers!!
Rome
Rome is offline
PostPosted: Sun Jun 11, 2017 8:47 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
A thread chaser or better yet, an actual tap of the same size as the original hole (M10 x 1.5) could bring back/re-form some of the threads, but the risk is that the currently stripped threads in the frame might have actual metal missing. The chaser/tap would re-form any existing metal but the full strength would not be there any more if the metal is not there for the bolt's threads to grip. You could certainly try that first, since it would be the least complicated repair. Use lubricating oil on the tap threads as you progress, and back out the tap every 2 turns so that you back out and remove the cutting "swarf" from the threads. Snug up on the torque for the M10 bolt starting at 10, then going up maybe 3 or 4 lb. ft until you get to 25. Might even want to stop at 20 since you have 2 bolts that are OK and achieved the 25 lb. ft.
You access the area by removing the lower approx. 4 or 5 bolts of the fender and removing the running board rear bolt, and pulling the bottom part of the fender away from the body. For re-tapping the original holes, you could get away with keeping the original bushing cover in place. You might also need an extension for the tap end where you attach the handle to clear the overhanging body.
If this technique strips the threads again in the frame before you get to the 25 lb. ft, then you'd need to try an alternative. With those, drilling and tapping for the larger bolts or for the M10 helicoil, you should remove the bushing cover, and cover up the end of the torsion bar as well as the torsion bar tunnel so that no drilling metal debris can get in there. With this method, yes, you first drill the damaged hole in the frame with a larger drill bit that is slightly smaller than the intended tap. The larger drill bit will drill out the damaged threads and extend outwards into fresh metal. Then you slowly turn the tap in the newly opened hole to create the threads, no more than 1 turn at a time. Back out the tap to reverse out the metal that is cut from the frame in between the new threads, clean off the tap, lube with oil and continue one or two turns. Repeat until you are completely through the frame metal and you can turn the tap easily with your hand. Then you know the new bolt will also turn freely. This is absolutely basic thread-cutting practice which you can look up on the internet.
vamram is offline
PostPosted: Mon Jun 12, 2017 5:38 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Rome, thanks for the great detailed procedure. Looks like I have the next big project on my hands. Your text had one especially revealing moment for me....
Now I have a confession to make. After 5+ years of learning to work on my own Bug, I still manage to have self inflicted oh-shit moments. Some moments of revelation feels like when Luke discovers Leah is his sister, Charleston Heston discovers the truth about silent green. The revealing moment was this:
Guess who overtorqued the bushing cover bolts...? By how much u ask...? Well let's just say that I think I'm lucky I didn't shear them off. d'oh! Brick wall
Click to view image
Save the Supers!!
Rome
Rome is offline
PostPosted: Wed Jun 14, 2017 3:14 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
I checked my orange Bentley repair manual before I posted my response above. If you casually look at the rear axle section torque specs and find the "trailing arm bolts", the torque on them is 80 ft. lb. But those are shown to be M12, and are the 3 big ones which hold the rear axle diagonal arm to the back end of the trailing arm. M12 is the size of the wheel lug bolt on 5-bolt Type 1 wheels so it gives you an idea of the relative size bolt and the torque such a size can utilize. The torque chart then shows "torsion cover" or similar, using the M10 bolt, and gives that torque as 25 ft. lb. That is the component you're dealing with.
This torque mis-read happened to me as well about 30 yrs ago. The M10 bolt's head snapped off the shank after I put 3x the correct torque on it. I "think" I drilled out the bolt shank from the frame, retapped the hole for the M10 bolt, and utilized a new M10 bolt. Tedious work. I was doing a chassis swap and replaced the bushings, so at least the work access was easy without the body positioned on top.
vamram is offline
PostPosted: Wed Jun 14, 2017 3:45 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
ya got me. Embarassed
I don't know how they didn't shear off. I was able to back them out and am driving like that for now since it's my daily driver until I get the '72 back on the road, and my wife is out of town w/the modern vehicle...
Click to view image
Save the Supers!!
allsidius
allsidius is offline
PostPosted: Wed Jun 14, 2017 6:21 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Unless your car is silver metallic or black, color coded wheels never looks good on any beetle. Even the 50s cars which had part of the rim color matched, the other part was always painted a contrast color. Silver sport wheels look perfect on your Marina Blue car!
1973 1303S w sunroof Click to view image
1978 1303 convertible (sold)Click to view image
1966 1300 RIPClick to view image
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Wed Jun 14, 2017 9:19 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Agree x100
The Samba member since 2004.
Buggeee
Buggeee is offline
PostPosted: Thu Jun 22, 2017 12:48 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
vamram wrote:
Buggeee wrote:
Well Rome I didn't want to believe it but the evidence is mounting that Step 7 of Bentley's torsion bar procedure is truly a misprint...
Hey Buggee - not sure if you saw the latest posts on my '74, but I unfortunately never made it to the torque table after step 7 in Bentley. Rolling Eyes Seems like the 3rd time was the "charm" for me - I stripped two of the 4 threads on the driver side spring plate cover after redoing replacing the urethane bushings w/rubber ones then having to redo the driver-side angle. They withstood the 1st two torgues to 80 lb but gave up the ghost on the 3rd one. Crying or Very sad Embarassed
Sooooo....good post for others about the 55 foot lb typos that Bentley's never bothered to fix!!
Yes you are right Vanram it is a good post for others innocently heading down the path we followed - So here it is for others watching your thread too.
Hey Samba peeps get out your markers and fix Bentley's Step 7 before it fixes you!
1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote:
Every setback is an opportunity to learn stuff and to buy new tools.
vamram is offline
PostPosted: Fri Jun 23, 2017 5:52 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Thanks Buggee - good idea to include that reference in this thread as well.
Click to view image
Save the Supers!!
garyt
garyt is offline
PostPosted: Sat Jun 24, 2017 6:16 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Agree also about body color wheels too.
I also dislike two tone beetle body colors.
vamram is offline
PostPosted: Sun Jul 30, 2017 9:10 am    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
I decided to add a rear sway bar and know I should've replaced the pivot bolt bushings in the 1st place when I did the torsion bushings...but since i've proven time and again that I'm a glutton for punishment, I didn't and here I am again.
I also replaced the rear soft brake lines which you might be able to tell in the pivot bolt picture. the old ones were shot and I could tell by the pedal all was not right.
Next, I'll be replacing all of the old urethane bushings in the front end and installing 1" lowering springs. I got the bushing kit from Topline but the springs from CIP1.
Click to view image
Save the Supers!!
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sun Jul 30, 2017 7:46 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Let's us know how it does on turns, Victor.
Tim
Let's do the Time Warp again!
Richard O'Brien
vamram is offline
PostPosted: Sun Jul 30, 2017 8:30 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
Tim,
I can already tell you that it will be an improvement over uneven/rough pavement and on turns. I've had the same rear sway bar on my '72 for a number of years now as well as top line sport springs on an otherwise stock Super. Definitely an improvement. I want that same handling on my '74 though I'm guessing it may feel different since the '74 has the 2-bolt struts and the tires I think are a tad further out than on the '72.
It'll be 2-3 weeks before I'm done with the front freshening up and can drive it but I will definitely post back my experience.
Victor
Click to view image
Save the Supers!!
Epilog79
Epilog79 is offline
PostPosted: Sun Jul 30, 2017 9:31 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
I too put in the rear sway bar on my 79 super convertible. I had been looking at that upgrade for years and just didn't know if it was worth the money, time and effort. Wow, was I surprised at the difference. I felt the difference not just in the turns, but it just made the car feel tighter, more planted. Was super easy to install. I too have been upgrading the suspension components over the years. Topline adjustable struts with the red tapered springs. It is set 2 inches down. Bigger front sway bar, and strut brace.
Good luck with your upgrades.
vamram is offline
PostPosted: Sun Sep 03, 2017 1:53 pm    Post subject: Re: Yikes! I bought a '74 Super!! Reply with quote
I got all of the suspension done. All new top line bushing kit up front, new 1" drop strut springs from cip1, re-packed rear and front bearings, new rear nexen tires, and new top line pivot bushings in the trailing arm. One note about the top line pivot bushings - they're black urethane and designed to take the place of the interior of the stock rubber bushing. Not knowing this to start, since the red ones I used on my '72 replace the complete bushing, I removed the complete old factory bushing and destroyed it in the process. Fortunately I had a pair of new stock style ones from when I replaced the ones on my '72 four years ago. I ruined the 1st pair trying to press them in and went urethane and threw the 2nd pair on the parts stash. Found and pressed them in without destroying them (I work"smarter now Smile ), removed the interior piece, and the top line ones were a perfect fit. The car drives great now. Have to get the alignment tweaked cuz it's pulling left a bit.
I also swapped put my beloved 34-3 Bocar for the 34-3 German soles rebuilt by volkzbitz 3 years or so back. Runs fantastic. Caravaned to the Bug Out south of Fredericksburg, VA today with a few of the local AirCooled Hooligans dudes, 65 miles each, purred like a kitten both ways, oil temps a healthy 190-200 at the end of each leg. Here's a pic from the show, next to another sweet yellow '73 Super.
H
Next - gauges, radio, and steering box adjustment.
Click to view image
Save the Supers!!
Page 21 of 49
