vamram Samba Member
Posted: Sun Feb 18, 2018 9:48 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Tim Donahoe wrote: |
The idle dropped when you covered the intake boot? Or did it speed up? ...
... Looks like the engine is coming out again for this job. ..
Too bad you’re not in California. Warmer weather here, although it’s a bit windy today.
Tim |
Hmmph, rub it in willya. I *think* i can do this w/out dropping the engine...just wont' be much fun. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sun Feb 18, 2018 11:35 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Victor, I did it with the engine out. It wasn’t much fun. Moving the manifold out of and back into position was the real bitch. Also, managing the two manifold end pieces—getting to the nuts at the head, and tightening them back again—not easy, even with the engine out.
But, give it a shot with the engine in. You might have a lesser tolerance for being pissed off than I do .
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
vamram Samba Member
Posted: Mon Feb 19, 2018 6:52 am Post subject: Re: Yikes! I bought a '74 Super!! |
Yep, I'm going to give it a shot, engine in car. In the meantime, while i wait for the new boots to arrive, a friend recommended a temp fix brake cleaner to clean the bad boot followed by a silicone sealer. All i want to do for now is test the brakes so just need it to hold for a short time.
Anyone ever try the (gasp) split boots that can be installed without taking apart the manifold...?
Click to view image
Save the Supers!! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Mon Feb 19, 2018 8:12 am Post subject: Re: Yikes! I bought a '74 Super!! |
vamram wrote: |
I've never tried those split boots, but I might be tempted if the need arose.
When I rebuilt my original 1971 engine last year, I bought new boots "just because" the factory ones were so old. But they still looked good, so I slipped those up the manifold as "spares" so I could slide them down into position and use those if necessary. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Feb 19, 2018 12:54 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Victor, I’d try the split boots for now. If it works, it works. In the Spring, after the weather is reasonable, you can install the proper boots.
Richard O'Brien |
vamram Samba Member
Posted: Thu Feb 22, 2018 8:32 pm Post subject: Re: Yikes! I bought a '74 Super!! |
For a TEMPORARY fix, i cleaned the "holy boot" with brake clean, then used ultra-copper RTV to seal the side w/the torn half section (RTV'd all the way around the boot), and let it cure for 24 hours.
I yanked on it a few times by hand to validate that it was holding to the boot, and Yes, it's ugly as shit but guess what - it worked!! Cranked right up, all 4 cylinders happily chugging away like before. I let it idle for 20 minuites. Revved it up a few times to 3-4k, no leak, no stumble at idle.
Tomorrow I'll drive it to see how the brakes feel w/the new MC...and if the RTV survives 30 minutes around the neighborhood, I may drive to Buggy Man 20 miles south to get replacement boots!
Hands-down, this is the biggest hack i've ever done on a Bug. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Thu Feb 22, 2018 10:49 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Just like filling a cavity ... without Novocain.
Richard O'Brien |
vamram Samba Member
Posted: Fri Feb 23, 2018 1:06 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Worked. Holds w/out a problem. I'll replace w/new intake boots when the weather warms up.
Now I gotta figure out why the fuel gauge stopped working. Registers to the left of empty, the needle doesn't even move. I pulled the speedo thinking I may have disconnected something when I replaced the speedometer cable a month ago, but everything is connected as it was. Sigh.... _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Feb 24, 2018 12:02 am Post subject: Re: Yikes! I bought a '74 Super!! |
Ground the power wire at the sender to see if the gauge moves. If not, the vibrator and/or gauge is probably shot.
Richard O'Brien |
vamram Samba Member
Posted: Sat Feb 24, 2018 9:12 am Post subject: Re: Yikes! I bought a '74 Super!! |
Problem solved. When I removed the trunk liner, both wires were disconnected from the sender. I had placed a rather heavy box on tip of this area of the trunk when i parked the car over a month ago. It included 2 rear drums. Its weight was probably enough to push the connectors out of the slots. Glad i didn't strip them out! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4407 Location: Stuck in Ohio
vamram Samba Member
Posted: Mon Mar 19, 2018 4:46 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Finally broke down and filled the hole in my dash w/a $40 Pyle radio, just like in the '72 Super. Has bluetooth, aux, SD cards slot and USB. Can't beat it, for what I need.
I really wanted to install oil temp and pressure and voltage gauges in the radio slot, but have to make $$ choices at the moment. I'll have to replace both sets of window scrapers over the next couple of months, so gauges will wait for another day.
Oh...i'm still running w/the intake manifold seal repaired w/ultra copper silicone....I'll change that in April....maybe. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Mon Mar 19, 2018 5:02 pm Post subject: Re: Yikes! I bought a '74 Super!! |
It looks good, Victor. I got the trim piece in mine after showing off the stereo in one of my posts awhile back. It makes for a clean look, but I had to file off some inner flanges to make it fit.
Installing the scrapers isn’t too hard, but take care. The new inner scrapers are a bit more tricky than the outer ones. You need to line them up very well, or else you’ll bend the crap out of those flanges. And since they’re only four of those bendy pieces, you don’t want one getting screwed up.
I got my scrapers from Wolfsburg West. They’re pretty good, but not as perfectly fitting as the originals. Still, they’re the best out there.
Use mnusbau’s Regulator How-To for reference. That thread helped a lot.
Richard O'Brien |
vamram Samba Member
Posted: Mon Mar 19, 2018 5:28 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Thanks Tim. I normally buy scrapers from Westcoast Metric and will probably do so again this time around. They are a pain, I did them on the '72 and the '62 too a few years back. But I generally learn from the experiences and have an easier time each time (except for the damn headliner). The radio only took me about an hour and half! Took me much longer on the '72. I think the wires are easier to access on the '74. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Thu Mar 22, 2018 5:37 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Had developed a clunk when letting of the gas suddenly, over the last couple of weeks. If you've followed this, you'll remember that I replaced the tranny and engine mounts early on. I raised the rear and and checked everything, everything's bolted down solid, no loose cv joints or other things.
Moved to the front and started shaking things around. I hadn't looked at the front because this car has not shimmy. There's a tiny amount of play in the idler arm bushing, but minor. Turns out this guy was bad -
The driver-side centerlink tie-rod end was shot. Pictured is the "new" one. On the bad one, I could push up and down on the bar and it went in and out at the fat boot end, as if whatever holds it hard in place had broken inside the fat part of the end. I think this was a factory centerlink too, based on comparing memory to cheap after-market ones I've seen.
I replaced it w/another orginal VW one that I know is good and had pulled from my other Super. We'll see tomorrow on the work commute if the bad end was indeed the source of the clunk. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Thu Mar 22, 2018 6:30 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Supers have the wider track in front which always feels like it would rather turn around and go backward under power. Stresses the joints.
But that early '71 I had was the smoothest ride I've owned.
People tend to over-tighten the intake boot clamps while stretching the boots. Holding the clamp opposite the screw side while tightening helps too.
The main appeal for me with a Ghia is room on both sides to work on the motor! _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
sb001 Samba Member
Posted: Thu Mar 22, 2018 6:45 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Tim |
Thanks for that tip Tim-
I have needed to install new window scrapers for years-- they are still the original ones and are basically shredded. Also recently my driver's window has become quite stiff to try to roll up/ down so that whole thread will prove very beneficial. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
vamram Samba Member
Posted: Thu Mar 22, 2018 8:14 pm Post subject: Re: Yikes! I bought a '74 Super!! |
Volswagon wrote: |
Are you referring to the after-market split boots? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Fri Mar 23, 2018 1:30 am Post subject: Re: Yikes! I bought a '74 Super!! |
vamram wrote: |
Volswagon wrote: |
Referring to the one in the pic above. I've seen as many problems with the orange ones as the black ones, usually a heavier aftermarket manifold that's only supported by the boots. Add the pull of the throttle cable against a heavy return spring and split boots you will have. _________________ I know the pieces fit, cos I watched them fall away.
vamram Samba Member
Posted: Sat Apr 07, 2018 5:07 am Post subject: Re: Yikes! I bought a '74 Super!! |
Back to the clunk...got rid of the front clunk, still having a loud clunk when I let off the gas if I was accelerating. Managed to get this video:
Broken left rear engine mount...? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
