orwell84 Samba Member
Joined: May 14, 2007 Posts: 2528 Location: Plattsburgh, New York
Posted: Tue Sep 27, 2016 6:09 am Post subject: How to remove side cover v channel bracket |
Don't what its called exactly. I would like to get it off without wrecking it so that I can get everything free of rust. I would love to find something better to hold the covers on. Those pieces are rust magnets. Thanks for the help. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16922 Location: San Diego, California
Posted: Tue Sep 27, 2016 6:23 am Post subject: Re: How to remove side cover v channel bracket |
I wish I knew what you're talking about _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Tue Sep 27, 2016 6:37 am Post subject: Re: How to remove side cover v channel bracket |
the clips that hold on the rear beltlines? under the side rear windows? |
Posted: Tue Sep 27, 2016 6:55 am Post subject: Re: How to remove side cover v channel bracket |
yes thats it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Sep 27, 2016 7:25 am Post subject: Re: How to remove side cover v channel bracket |
Invest in a spot weld cutter and start cleaning, there's a spot weld down in each of the notches. You may have better luck drilling small pilot holes from inside the bus, the welds are in the wavy section below the windows, the waves are there to make room for the spot welders electrodes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 27, 2016 8:01 am Post subject: Re: How to remove side cover v channel bracket |
yes thats it. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Tue Sep 27, 2016 8:26 am Post subject: Re: How to remove side cover v channel bracket |
orwell84 wrote: |
I would love to find something better to hold the covers on. |
Please let us know what you find. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Sep 27, 2016 8:32 am Post subject: Re: How to remove side cover v channel bracket |
can you take pics- I still don't know what your working on or the "covers" your are talking about. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Tue Sep 27, 2016 8:45 am Post subject: Re: How to remove side cover v channel bracket |
he said it was the clips that hold on the rear side beltlines.
the beltlines being the removable pieces under the side rear windows
Posted: Tue Sep 27, 2016 1:21 pm Post subject: Re: How to remove side cover v channel bracket |
I always wondered about the wavy lines. I have found replacements so I may just grind them off. I do have a resistance spot welder too. Not sure if the tongs are long enough. Thanks. |
1967250s Samba Member
Posted: Tue Sep 27, 2016 6:33 pm Post subject: Re: How to remove side cover v channel bracket |
Looks like most of the rust is above the groove section on the window outer section. If you carefully remove it, treat/remove the rust, you might be able to re-use the original piece. It looks to be in pretty good shape. _________________ '72 Elm Green Deluxe |
Posted: Tue Sep 27, 2016 7:23 pm Post subject: Re: How to remove side cover v channel bracket |
I've only see a 2 bolt and a 3 bolt design for holding that piece Also saw a wedge rod with screw to suck it long the shelf. and wedge the piece in place. will try to get you some pics-- the wedge rod was on the 68 bay parts carcass I got for the roof.
Would not weld or glue that piece as pretty sure you'll wand to take it off in the future
Here is how the wedge lock works-
.[img][/img][img][/img]
If you brighten up this next pic 9it wouldn't load for me ) you will see a small nut holding the side cover in place just on the body near that pointy thing.
[img][/img]
This panel on the passengers side with the sliding door only has 2 philips head screws and a small nut holding it on- one on the back welded tab, one on the cast bump latch stop down low and the small nut. a quick rap with a dowel and hammer will pop it off. The passengers side may have 3 screws. and a nut- again just tap it straight up. _________________ some days I get up and just sit and think. Some days I just sit.
Don't step in any!
Posted: Wed Sep 28, 2016 3:45 am Post subject: Re: How to remove side cover v channel bracket |
Thanks that would be helpful. |
Posted: Wed Sep 28, 2016 5:31 am Post subject: Re: How to remove side cover v channel bracket |
I found this. Seems like I could bolt these on so that I could remove them if rust ever became a problem again. Properly painting and sealing and installing the plastic trim would no doubt help too.
http://www.busdepot.com/8320 |
Posted: Thu Sep 29, 2016 2:30 am Post subject: Re: How to remove side cover v channel bracket |
Many thanks WilliamM! |
Posted: Fri Sep 30, 2016 12:10 am Post subject: Re: How to remove side cover v channel bracket |
my 73 didn't have the wedge bar , just a tight fit in the channel with the bead in there. the 78 didn't have the bead- just the channel and screws and one nut. _________________ some days I get up and just sit and think. Some days I just sit.
