Paulbeard Samba Member
Posted: Thu Jun 15, 2017 7:58 pm Post subject: Re: Show me your USB chargers |
The plate I made for mine (in the classifieds) is 5.125 x 6.625. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
eeebee Samba Member
Posted: Fri Jun 16, 2017 3:11 pm Post subject: Re: Show me your USB chargers |
Latest project. The cover playes are still available new so i hacked it up. _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Sat Jun 17, 2017 5:47 am Post subject: Re: Show me your USB chargers |
Brilliant. Great idea. |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Sat Jun 17, 2017 9:55 am Post subject: Re: Show me your USB chargers |
Though I had already gotten one from Campin Culture, when I saw this one that Italjohn of Norway made.......I had to knock on his door and luckily he had an extra prototype sitting around, looking lonely, looking for a permanent home.
_________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
zippledippledoo Samba Member
Joined: September 25, 2010 Posts: 10 Location: Nevada City
Posted: Tue Jul 25, 2017 3:03 pm Post subject: Re: Show me your USB chargers |
That is seriously cool. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Tue Apr 17, 2018 3:59 pm Post subject: Re: Show me your USB chargers |
Who has USB-c chargers? Has anyone located an "insert" type so I replace my old USB inserts with the USB-c?
I would like to charge my laptop. _________________
....KTMs, GasGas, SPOT mtb |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Tue Apr 17, 2018 6:20 pm Post subject: Re: Show me your USB chargers |
usb to usb-c cable?
I've charged my macbook pro with a small inverter (plugs into cig. socket) using the apple power supply and it worked just fine.
I have blue sea systems 5A USB outlets now ( https://www.bluesea.com/products/1045/Fast_Charge_-_Dual_USB_Charger_Socket_Mount ), but haven't needed to charge the laptop. From what I've read it'll only charge while it's turned off. With the laptop turned on it might just maintain the same battery %. |
Nuthin2It Samba Member
Joined: December 31, 2011 Posts: 306 Location: Marietta, GA
Posted: Fri Mar 10, 2023 9:43 am Post subject: Re: Show me your USB chargers |
For those that have mounted a USB charger and switch on the refrigerator vent plate: If you are still using the original refrigerator is there a problem with heat when in LP mode? I don't think it really gets that hot but it's probably not good for the electronics, especially with the exhaust duct right next to it. _________________ 1985 Westfalia 15 degree EA288 Boxeer |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Fri Mar 10, 2023 2:30 pm Post subject: Re: Show me your USB chargers |
Blue Sea Systems double USB charging ports plus 12v port (cleverly disguised as missile launch button) — controlled with off-on toggle switch to prevent parasitic draw.. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
R0ckyMtnCamper Samba Member
Posted: Fri Mar 10, 2023 3:05 pm Post subject: Re: Show me your USB chargers |
Nuthin2It wrote: |
For those that have mounted a USB charger and switch on the refrigerator vent plate: If you are still using the original refrigerator is there a problem with heat when in LP mode? I don't think it really gets that hot but it's probably not good for the electronics, especially with the exhaust duct right next to it. |
I mounted a small 2-port buck converter behind the original vent. USB-A plugs just fit between the spaces in the grill. I also have an 80mm PWM fan hooked up to a PWM speed controller. The dial also controls a small 10mm fan inside the fridge and a larger 120mm fan near the condenser coils on the rear of the fridge. The fans help evacuate heat from the rear of the fridge and everything runs much more efficiently. No problems with the USB.
Timwhy Samba Member
Posted: Fri Mar 10, 2023 4:46 pm Post subject: Re: Show me your USB chargers |
Nuthin2It wrote: |
No problems at all.
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
