typetwotool Samba Member
Posted: Thu Nov 17, 2016 9:57 am Post subject: Re: Cylinder 5 Misfire |
You can check the resistance of the injectors (check Bentley) might confirm an issue before tearing everything down. _________________ Nathan
80 Vanagon
00 Eurovan
69 Karmann Ghia |
Mr Brown Samba Member
Joined: January 30, 2006 Posts: 161 Location: Somewhere In Canada
Posted: Thu Nov 17, 2016 7:29 am Post subject: Re: Cylinder 5 Misfire |
jpfahrstar wrote: |
Replacing the injectors requires removing the intake manifold. Right? How big a job is that? |
Not on the AAF engine anyway. I did the injector seals last year and it wasn't too bad to get at. Hardest part was getting the hoses off the fuel manifold. |
visibleink Samba Member
Joined: May 03, 2002 Posts: 1668 Location: Austin, Texas
Posted: Sun Oct 16, 2016 10:34 pm Post subject: Re: Cylinder 5 Misfire |
Summers420us wrote: |
Chime in if you have experienced cylinder 5 misfire codes for a bad injector. |
*chiming*
But I think on mine it was #3. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
jpfahrstar Samba Member
Joined: November 12, 2003 Posts: 43 Location: Columbia, MD
Posted: Sun Oct 16, 2016 5:48 pm Post subject: Re: Cylinder 5 Misfire |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Tue Oct 04, 2016 3:28 pm Post subject: Re: Cylinder 5 Misfire |
Chime in if you have experienced cylinder 5 misfire codes for a bad injector. _________________ 1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.) |
Zeddy Samba Member
Posted: Mon Oct 03, 2016 7:26 pm Post subject: Re: Cylinder 5 Misfire |
Id do the injectors. Its a bitch to get at them. You can rebuild, but if keeping for long term, just replace them all. If there are some decent used ones you pull out, maybe could sell them used to recoup the $1000 out the door |
Posted: Mon Oct 03, 2016 3:50 pm Post subject: Re: Cylinder 5 Misfire |
plugs look good.
Original wires were a bit beat. Replacements are perfecto! _________________ 1997 EVC
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Sun Oct 02, 2016 4:55 pm Post subject: Re: Cylinder 5 Misfire |
Don't trust OBD codes for misfires. Confirm by pulling wire , coils, and plug inspection. _________________ .ssS! |
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Fri Sep 30, 2016 3:53 pm Post subject: Re: Cylinder 5 Misfire |
To check for intake leaks spray something like parts cleaner around where the intake meets the head and listen for a change in RPM. Don't blow yourself up. A leak may not be very likely but worth checking for anyway.
Compression test all cylinders before messing with injectors. You can borrow a tester from some parts places. _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
Posted: Fri Sep 30, 2016 2:23 pm Post subject: Re: Cylinder 5 Misfire |
Ok... so to answer the questions above:
I know it is cylinder 5 from OBD.
I did not try swapping wires, instead I replaced with the new set and have the same error code.
Have not performed compression test.
Intake leak is interesting thing to check... how to check that?
Injector swap? Isn't it quite a bit of labor to get in there? Should I just replace with new? and do all the other while I am there? _________________ 1997 EVC
Posted: Thu Sep 29, 2016 8:09 pm Post subject: Re: Cylinder 5 Misfire |
I was in the same boat....it was the injector. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
gakali Samba Member
Posted: Wed Sep 28, 2016 6:52 pm Post subject: Re: Cylinder 5 Misfire |
Compression test? Injector swap? Intake gasket leak at that cylinder? _________________ Why do it? Because you can.
1999 Eurovan
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Wed Sep 28, 2016 5:46 pm Post subject: Re: Cylinder 5 Misfire |
i know it sound stupid, but have you tried swapping your new cables around just to make sure to see if the misfire follows a component?
i know they are new cables and plugs and all that, but even new stuff can be crappy out of the box. I've had enough crap cables in the last year to at least say you've got a chance of that being the case.... _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Posted: Wed Sep 28, 2016 5:43 pm Post subject: Re: Cylinder 5 Misfire |
How do you know it's 5? Visual, inspection, or OBD? _________________ .ssS! |
Posted: Wed Sep 28, 2016 2:30 pm Post subject: Cylinder 5 Misfire |
Cylinder 5 misfire issue. I have replaced plugs, plug wires and coil pack. What else? _________________ 1997 EVC
