mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2780 Location: North Carolina
Posted: Fri Sep 30, 2016 6:28 am Post subject: Any tricks I'm missing to changing lower cylinder sleeve o-ring? |
This is with the piston in, as shown on Ben's website.
http://www.benplace.com/vanagon_engine3.htm
Mine did come unseated when taking heads off, so want to do. Seems especially important on driver's side as the water jacket seal was in pieces and afraid debris could've got in there.
I think the sequence is as follows:
1) TDC on #1
2) Pull sleeve up on #1.
3) Do what Ben shows.
4) TDC on #2.
Repeat all the way around.
What ben doesn't show is putting cylinder sleeve back into place. Does it just slide in? Need to clean the seat somehow? I was just going to blow it out real good with compressed air to make sure no debris in there, but wanting to make sure.
Thanks. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10239 Location: N. Idaho
Posted: Fri Sep 30, 2016 8:27 am Post subject: Re: Any tricks I'm missing to changing lower cylinder sleeve o-ring? |
My concern is that with an O ring, you have a need to have the groove it fits into clean and free of bits. A small chunk or drift of grundge will cause the O ring to partly unseat as you are pushing the cylinder home, or cause it to distort and leak. So you have to run something like a dental pick around and around and then rinse with something to flow the dislodged debris out. So you'll have quite a confined space to accomplish this. Doable, but don't just stuff a new one in. In the last couple months, I pulled 8 WBX cylinders and found 3 of these O rings dislodged - most likely when installed. I'd use some spray oil to rinse/dislodge after careful cleaning and good light in that tight spot. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sat Oct 01, 2016 9:27 am Post subject: Re: Any tricks I'm missing to changing lower cylinder sleeve o-ring? |
Just FYI for other rookies like me...this is just as easy as Ben makes it look in his videos. No reason not to do this. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
