tar boards motor compartment
Page: 1, 2, 3  Next
bugheadred
bugheadred is offline
PostPosted: Fri Sep 30, 2016 6:48 am    Post subject: tar boards motor compartment Reply with quote
do your self a favor. and if you have loose tar boards . take them out or fix them ! it cost my friend his motor . the tar board got sucked in the fan and you can see what happened . I had to pound that rear main of the crank with a hammer the case is junk the pin that pins the barring is loose (junk)
grandpa pete
grandpa pete is offline
PostPosted: Fri Sep 30, 2016 7:38 am    Post subject: Re: tar boards motor compartment Reply with quote
Note ; there is an old thread on Samba that tells about having a rag used to check the oil sucked into a NEW engine and ruining it .
I found that i can stuff a small rag into the back of the bumper upright ; handy and out of the engine compartment .
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
bluebus86
Banned
bluebus86 is offline
PostPosted: Fri Sep 30, 2016 8:09 am    Post subject: Re: tar boards motor compartment Reply with quote
a head temp, oil temp, oil temp press. gage may save the day if the operator is watching the gages. install some monitoring gage to help prevent engine destruction.
grandpa pete
PostPosted: Fri Sep 30, 2016 12:46 pm    Post subject: Re: tar boards motor compartment Reply with quote
I attached a $12 " Back up Beeper " to the oil light ; when the oil light goes on the beeper does too .
63 two fold rag
bugheadred
PostPosted: Fri Sep 30, 2016 1:14 pm    Post subject: Re: tar boards motor compartment Reply with quote
not the point at all you don't need a gage a beeper or anything at all you need to do check your tar boards (its freee
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Fri Sep 30, 2016 1:36 pm    Post subject: Re: tar boards motor compartment Reply with quote
There is no need to bag on a guy that is offering free help. Maybe someone can use his idea to prevent the same damage that your friend experienced by not paying attention to his engine. Almost anyone that drives an ACVW knows and understands the signs of an over heating engine before terminal damage takes place.
Have a great weekend!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
pwmcguire
pwmcguire is offline
PostPosted: Fri Sep 30, 2016 3:16 pm    Post subject: Re: tar boards motor compartment Reply with quote
Let me warn you as well, the new tarboards with the waffle print become extremy floppy when they heat up. So make sure they are secure as well
bugheadred
PostPosted: Fri Sep 30, 2016 3:51 pm    Post subject: Re: tar boards motor compartment Reply with quote
I think when I am going to replace the ones in all 3 of my cars I am going to put the tar boards in then paint aluminum like what they use in race cars and cover the tar boards I think it will look good and stay clean
EVfun
EVfun is offline
PostPosted: Fri Sep 30, 2016 4:20 pm    Post subject: Re: tar boards motor compartment Reply with quote
A fine idea for another failure mode. However, if oil pressure fails because of over heating it is likely already too late for the motor, or at least the heads.
Wildthings wrote:
TinCanFab
TinCanFab is offline
PostPosted: Fri Sep 30, 2016 4:30 pm    Post subject: Re: tar boards motor compartment Reply with quote
Yeah I'v done a long block swap for a little old lady for this exact reason. It's not a matter of not paying attention, it's about knowing they are notorious for this.
This lady kept having overheating issues that were intermittent. She'd pull over, pop the decklid and could not find any problems. She had been doing all her oil changes and valve adjusts since 1972 religiously and very adept to problems popping up. Even after 40 years, there's always something new to learn. All the "car guys" in her family could not figure it out for weeks and tried to get her to sell the bug.
She heard about me and tracked me down, I walked up to her car, popped the decklid and yanked a huge chunk of tar board from the fan. Also checked for loose foam or pillows that are stuffed in the upper cavities, but nothing there. The tar boards were in ok shape, but the lower edge behind the shroud was flaking off.
Other things like the carb inlet pipe coming loose, battery terminals close to the seat springs, plastic fuel filter at pump.... All suspect on this near perfect 2 owner car. A lot of guys will say, "it's been good for 40 years so what?". If there's even a chance, address it now. Here we had a 1600 that was never removed, EVER and as soon as I even touched the carb fuel hose, the inlet pipe just fell out.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
modok
modok is offline
PostPosted: Fri Sep 30, 2016 7:39 pm    Post subject: Re: tar boards motor compartment Reply with quote
I'm fixing a 67 for a guy, and he put in some kind of replacement insulation, never seen it before, some kind of compressed cotton, but it was loose, so.....I ripped it out.
Yeah I feel bad, but, it's for the best.
bugheadred
PostPosted: Thu Nov 03, 2016 11:06 am    Post subject: Re: tar boards motor compartment Reply with quote
all said and done it cost my buddy 1200.00 check them tar boards
Cali_Army_Guy
Cali_Army_Guy is offline
PostPosted: Thu Nov 03, 2016 3:57 pm    Post subject: Re: tar boards motor compartment Reply with quote
Don't have them. Good to go.
2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold
toddmin
toddmin is offline
PostPosted: Fri Nov 04, 2016 10:46 am    Post subject: Re: tar boards motor compartment Reply with quote
I keep a rag stuck there too. I remember reading that suggestion here and thinking it was a good idea (you probably mentioned it).
grandpa pete
PostPosted: Fri Nov 04, 2016 11:30 am    Post subject: Re: tar boards motor compartment Reply with quote
It's nice to be appreciated ; Thanks.....
63 two fold rag
tomsbuggered
tomsbuggered is offline
PostPosted: Sat Jan 28, 2017 3:55 pm    Post subject: Re: tar boards motor compartment Reply with quote
Did a check on my bug today, to start it as the weather is above zero.
Noticed the tarboards are curled up on the sides, after only being in the vehicle for just over a year.
Did a search but saw no reference to replacing the tar board with better material (metal) to make them last. Has this been done sucessfully ?
Tom
June 1956 VW Oval Beetle
BotanyBandit
BotanyBandit is offline
PostPosted: Sat Jan 28, 2017 6:54 pm    Post subject: Re: tar boards motor compartment Reply with quote
Maybe a question that's been asked elsewhere, but I was wondering if there were any consequences to NOT using the tarboard? I am considering using tintable raptor bed liner in the entire engine compartment. That should help insulate and deaden sound. Thoughts?
Cali_Army_Guy
PostPosted: Sat Jan 28, 2017 7:00 pm    Post subject: Re: tar boards motor compartment Reply with quote
I don't have tar boards on my '66. My interior is fully dynamat'd and carpeted. Plus I have a speaker shelf in the rear that further deadens sound. With my radio on I can't even hear the fan noise. Not sure why people are so hung up on tar boards when there are other ways of blocking out engine compartment noise.
Zylinderkopf
Zylinderkopf is offline
PostPosted: Sun Jan 29, 2017 4:44 am    Post subject: Re: tar boards motor compartment Reply with quote
Chris Vallone sells his own brand of tar boards. Anyone here have any experience with these?
https://youtu.be/MnHeCHHx9B8
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
planenut
planenut is offline
PostPosted: Mon Jan 30, 2017 2:32 pm    Post subject: Re: tar boards motor compartment Reply with quote
How many of you actually keep a constant check on your oil pressure light when you're cruising down the road. Especially on a long trip in the bright sunlight? I think the beeper idea is an excellent idea. Most all modern aircraft use some sort of attention getter when a warning light comes on. If you lost oil pressure 30 seconds after the last time you looked, it'd save your engine.
Page: 1, 2, 3  Next
