Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sun Oct 02, 2016 6:14 am Post subject: Round thing on tunnel holding rubber mat or carpet in place |
When I tore out the old rubber mat I ended up destroying this round plastic disc thing on the other side of the tunnel. What do you call this, where can I get a replacement and how do these come off/install?
_________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Sun Oct 02, 2016 6:45 am Post subject: Re: Round thing on tunnel holding rubber mat or carpet in place |
That's just a plug that VW used when you don't have seat belts installed. They have a big Phillips + in the middle to unscrew. Looks like someone tried to take them out with too small of a screwdriver tip and destroyed them. Wolfsburg West has the adapter to install seat belts. On the floor, you might find threaded plates for the other side. If not, you can drill a hole and use proper hardware (Grade 8 )to attach the other end of the belt. Just search seat belt install threads, lots of good info.
If you do add shoulder harnesses, make sure you copy the late design of mounting points. The early cars had them too low, and after crash testing more, VW realized the bad design was folding spinal columns in half as the person flew forward. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
Posted: Sun Oct 02, 2016 9:33 am Post subject: Re: Round thing on tunnel holding rubber mat or carpet in place |
Thanks guys....that makes sense and I'm definitely planning on adding seat belts on this resto. _________________ 1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
